Question about Kenmore Kitchen Ranges
I own a Kenmore gas range/oven. 317B6034 Gas is on, range works but oven does not.
catriver
  • 878 Answers
SOURCE: Kenmore Gas Range Oven not Working Properly
greg, sounds like your needle valve is not seated. Remove the bottom drawer. Look back to the base of the burner where the shutter air adjustment is. Right under there is the valve which should have a 1/2 inch or 7/16 nut. (I Forgot what size). Turn this nut clockwise until the flame is adjusted to the correct size, should be a nice blue flame. The nut maybe hard to turn because you are seating the needle. Catriver..post back
Posted on Dec 23, 2006
fridgetech
  • 473 Answers
SOURCE: clock,timer and oven does not work on Kenmore gas Range
Unplug the unit and see if this will reset the board. If this doesn't work then replace the oven control board.
Posted on Oct 05, 2007
fridgetech
  • 473 Answers
SOURCE: kenmore gas range
You need to turn the orifice on the safety valve down (clockwise) and this will make the flame smaller. The orifice is what the burner for the oven sits on at the bottom. The valve is # 214 on this diagram. http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0124111&brandID=0582&modelDesc=GAS%20RANGE&modelNumber=3627331890&documentID=10033508&documentTypeID=PLDM&documentClassCode=PM&titleType=BURNER%20SECTION&titleID=00001&. Hope this helps.
Posted on Nov 04, 2007
james klgr
  • 362 Answers
SOURCE: Kenmore Gas Range - burners won't ignite
its possible your gas regulator is bad or the gas line to the ignitor is stopped up look at the line and see if some type of food has blocked the outlet
Posted on Dec 08, 2007
aborcass
  • 2651 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
bad oven ignitor is the most common cause of bake failure, located onthe side of hte burner bar itself, if youd like with a multi-meter, you can check the wires leading to the ignitor for 110v. if you have power and nothing was glowing from ignitor theres your problem
Posted on Nov 23, 2008
The gas stove model 317b6034 keeps clicking like when you turn on the burners what might be the problem
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Aug 25, 2011 | Microwave Ovens
I have a GE Profile Gas Range model 317B6034. The top / range works fine, but the actual oven will not turn on at all. I don't smell gas nor is there any sound when I turn the oven on. Basically,...
It sounds like you have a bad ignitor in the oven. Hope this helps get you going in the right direction.When you turn on the oven the ignitor should glo.
May 16, 2011 | Ovens
Kenmore free standing gas oven. Burners will
It sounds like the erc electronic range control has failed. Try this link it will walk you thru checking and replacing the erc http://appliancehelponline.com/ovenerc.html
Jul 16, 2010 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
How to use kenmore gas range during power outage
just use a match to light top burners, the oven will not work or pass gas if you have a electronic ignition range
Feb 06, 2010 | Kitchen Ranges
Oven won't work
sounds like electronic ignition is worn out
May 26, 2009 | Hotpoint 30" Self-Cleaning Freestanding...
Oven not working
Your electronic control panel must be replaced.
Feb 27, 2009 | Kenmore 73422 / 73424 / 73429 Gas Kitchen...
Kenmore gas range model # 362.7121191 oven
Could be the thermostat, glow bar, valve or wiring but usually the glow bar
Feb 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Gas oven problems
The oven probably uses electric start. There might be a breaker in there that popped.
Nov 30, 2007 | Kenmore 71414 / 71419 / 71410 / 71412 Gas...
Kitchen Ranges Logo
309 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
