Question about RCA P52926 52" Rear Projection Television
Chirping noise I just moved into a new house and my tv is making a "chirping" nosie. It started after being here for about 5 days.
  • RCA Master
  • 8,617 Answers
You need to replace the horizontal output transistor or the flyback. the flyback is the most likely cause. Let me know if you need more information
Posted on May 13, 2008
Hi we have a 720 Magnavox flat screen tv that is about 5 years old. When i went to turn it on the other day the picture started flasing and making a chirp noise.. and won't fully
power supply problems does it have a separete power supply if so you can try to change or if you have someone with the same you can ask to try it.if its internal power supply it needs to be fixed.
Aug 20, 2012 | Magnavox 37MF437B37 37 in TV
My manual 5 speeds only makes bearing noise when at highway speeds . repairman says it is a bearing but i thought a throw out bearing only makes noise when pushed in ,
Are you sure hes not talking about a wheel bearing for your front wheels. A throwout bearing will sometimes make nosie like a rattleing if it is not engaged. When engaged it will sound like a roaring nosie. I would check in to were this nosie is coming from first.
Feb 09, 2010 | 1999 Jeep Grand Cherokee
Washer makes loud, thumping noises during spin cycle.
support bracket that supports the tub is breaking. stick your hand inside and push up and down and see if its coming apart. if u look at it when it runs does it wobble?(the tub) if not take a look at the pulley on the back and see if its wobbly.
Jun 22, 2009 | Washing Machines
Can a alternator PULLEY make a chirping noise?
It's possible that the alternator is making the chirp noise (bearing) but I would try this first. Start the engine and allow the engine to idle and open the hood and take a spray can of WD40 and shoot a short burst onto the bottom side of the belt and pulley. Dont spray allot as this will cause the belt to slip. The WD40 is to lube the pulley grooves and belt a slight bit. Hope this works!
Lefty64
Apr 09, 2009 | 2000 Dodge Durango
I have a RCA D56D20 tv will not power up it blinks three times
You have 2 more caps in same circuit you need to replace cp114---cp120 both are 220uf 35v. Also chirping nosie means Shorted hori output NTE 2324 .On second ribbon on deflection board make sure it is connect good or it will make a squealing noise and TV will not come on. Happy New Year.
Dec 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv makes loud chirping noise but does not turn on
cost i about $100 from $50 just to look at it. not really worth it especially if it reaches $300. this is a transistor problem
Dec 26, 2008 | RCA F32650 32" TV
Power on samsung plasma tv
Where did you move from and to?
Mar 07, 2008 | Televison & Video
Television making chirping noise
Chirping or hissing from the TV is caused by a faulty CRT base socket in 95% of the cases. Replacing the base socket is an easy job, but care must be taken to get the same replacement base socket. You better desolder the existing base and take it to the shop to get one with the similar connections. Good luck.
Jan 22, 2008 | Televison & Video
Making Loud noises
Got the same problem with my second TX-S3082WH Slimfit...the first had the same problem...it was deemed unrepairable and I was advised to return it to Circuit City...now a year and five months later Samsung support has been less than helpful as I am 5 months out of warranty...don't know what I'm going to do...any advice would be appreciated
Dec 02, 2007 | Samsung TXR3079 TV
Samsung PCL5415RC Chirping noise
power supply discharging.even after the set is unpluged.
Sep 13, 2007 | Samsung PCL5415RB 54" Rear Projection...
RCA P52926 52" Rear Projection Television Logo
62 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
