Question about Dryers
Dryer won't even turn on. It is a Heavy Duty Maytag LDE9900 with electronic control panel and is a gas model. We had a power outage, and then the dryer wouldn't turn on. Checked the breakers, the washer is still running, and is plugged into the same plug. :(
  • 230 Answers
Most likely it is a problem with the thermal fuse. An open thermal fuse kills power to the motor circuit in most dryers.
However, try these troubleshooting steps first:
Has a household fuse blown or has a circuit breaker tripped? There may be 2 household fuses or circuit breakers for the dryer. Check to make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse or reset the circuit breaker. If the problem continues, call an electrician.
Is the correct power supply available? Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but not be latched. Push on the door to engage the latch or latches.
Duet® Dryers have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start or Hold to Start button firmly pressed?
Large loads may require pressing and holding the Start button for two to five seconds.
Is the Cycle Control knob set on an Automatic Dry or Timed Drying cycle?
The Cycle Control knob must be set in an Automatic Dry or Timed Drying cycle. The dryer will not start if set on Wrinkle ShieldTM control setting.
Is Control Locked status light on (on some models)?
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Locked feature.
Did you recently install a power supply cord on the dryer?
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
If the above steps did not correct the problem, it is most likely the fuse. If you know how, it should not be too difficult to replace it. But since you said your machine is new, the best recommendation I can provide is to contact your manufacturer or point of purchase and get them to take a look/replace the dryer. Opening up the machine could void the warranty.
You can contact Whirlpool customer support HERE.
Hope that helps! Thank you for using FIXYA!
Posted on May 13, 2008
  • 796 Answers
Check whether the connections to the main control and the motors are proper,...
also check the fuse
U plug the machine without programming it just start spinning
Hello. To help you accurately I need the make/model number of your unit. However, based on the symptoms you describe, it sounds like the main control board or timer is shorted. Did you have a power outage within the last 3-4 weeks? A power blink? If just applying power makes the unit start spinning, it is an un-controlled occurrence. Even the older, mechanical-timer type of units required power to the drive motor to be routed through the timer. The more modern electronic counterparts have on-board computers that apply small voltages to energize relays. These relays handle the heavy-duty current required by the various pumps and electric motors. I hope I helped you!
Sep 05, 2015 | Washing Machines
Control board sparks, smokes and smells when trying to start
Did you have a lightning strike near by? Or power outage with a power surge. Could have shorted the board.
Mar 13, 2015 | Maytag Epic MGD9700S 27 7.3 cuft. Gas...
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Dryer has no power.  i have reset the breaker and made sure the door is shut
I just cleaned my kenmore heavy duty dryer out. to like new. IT's a 2004 model.
I didn't see any fuses. I did see several sensors in there. One even looked like an optic one, pointed at the heating coil. I just cleaned them all off and vacuumed it all out.
I got a pretty good grasp of electronics, and I'd have to say, unless you are good with a volt meter and can decipher the technical spec sheet in the dryer, you should let a pro tackle trying to find out which sensor is out and replace it.
At the very least, call and get a few quick estimates.. it might not be as expensive as you think, for an hours service time.
Dec 18, 2008 | Maytag HYE3658AY Electric Dryer
Turn off buzzer
some models have a buzzer in control panel which can be unpluged wire sealed off ather built into time and can not be turned offf good luck
Mar 04, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Smell Gas.
you need to clean out you venting is most likely clogged or filling up
Jan 02, 2008 | Maytag MDG2706A Gas Dryer
Dryers Logo
235 people viewed this question
Top Dryers Experts
