Question about Kenmore 23822 Top Load Washer
Need to replace lid switch how is that done - Kenmore 23822 Top Load Washer
  • Kenmore Master
  • 2,605 Answers
Welcome to FixYa.
Here`s a helpful link for changing it out,
http://videos.wittysparks.com/id/3098139337
The lid switch will look like this...
Let me know what you find and if I can assist you further.
Good luck.
Regards,
Macmarkus :)
Posted on Sep 06, 2010
  • Kenmore Master
  • 3,361 Answers
First you give us a complete model number so that we can reference the correct machine.
DID AUTO TEST MODE RAN THRU CLYCLE SOLID GREEN DONE LIGHT IS ON NO OTHER LIGHT'S CAME ON
lift the lid. done light indicates that test cycle is complete. If you are getting done light only, all the time, control board is not recognizing that lid was lifted, allowing it to go back to normal operational mode. check lid switch and control board.
Jan 12, 2015 | Amana NTW4501XQ 3.4 cu. ft. top load...
Lid lock broken can I overide?
Washer not starting Cycle:
I would have to slam the washer lid before the washer recognized the lid was shut.
What I did to fix:
1. Ref the link below for Schematics
http://blog.kennyluong.com/Tricking-A-Maytag-Bravos-Washer/
2. Looking at the Lid Lock section of the Schematic:
Place a jumper between pins 2 and 3 of J15
This engages the 1st switch (Lid Lock) so, I don't have to slam the lid anymore
3. Since my Lock switch (2nd switch), which is engaged with a magnetic, is working, my work is done.
If you find that your machine is still not starting the cycle, you will need to
replace the Lid Lock mechanism or ref the above link for temp bypass.
Mar 30, 2014 | Maytag Bravos Top Load Washer
Maytag bravos x lid lock overide or bypass
dpthom's wife is the smartest woman on earth! :)
Feb 11, 2013 | Maytag Bravos Top Load Washer
Whirlpool ultimate care 2 - will fill but no cycle or drain, can hear the timer running
most likely you have a broken lid switch,close the lid,then open it around 6 inches,close it and open it a few times,as you do this if you don't hear a clicking sound the switch is bad,part number 8054980 and it's around 25 dollars.
http://www.youtube.com/watch?v=PZAbg9uftos&feature=BFa&list=PL946F2AC904989088
watch this video, when you click on it look down on the left side it will say replacing new style,click on it and it will show you your model.it will show you how to make sure it's the lid switch but if you don't hear any clicking when you open and close the lid the switch is bad,also if the lid is pushed in from putting the laundry basket on top of it open the lid and wack the center of the lid to pop it back up,i've done this before when the lid is dented in and this fixes the problem,the arm that's connected to the lid doesn't hit the switch correctly with the lid dented in but usually the switch is bad and needs to be replaced.
http://www.youtube.com/watch?v=MFsvLiuTniU
watch the first part of this video and it will show you how to open the top console,this is different from your lid switch this is just to get you into the top so you can change the switch.good luck,if you need anymore help let me know and i hope this helps you out
Apr 28, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Wont drain wont spin
This problem can be caused by a few things. first I would check the lid switch. You should be able to hear a clicking sound, this is the switch actuating. If you can't hear it, chances are you may need a lid switch. The machine won't spin but it should drain. part number for the lid switch is 8054980. The second problem could be that there is something caught inside the drain pump and now won't drain. It is also possible that the damage has already been done to the pumps impellers and can pump little or no water. If however you are hearing any sort of loud banging noise. this could indicate that your direct drive coupler needs to be replaced. part number for the coupler is 285753. These are common problems and can be easily diagnosed and replaced by a technician.hope this helps.
Thanks
Oct 21, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag top loading washer will not agitate
My rule of thumb: Take what you paid for the washer new and divide by number of years without repairs. That is your cost per year for the washer. If the repair will get you another year and is less than the number above do the repair. If you have done more than 2 major repairs in a year it is time to think new. eric
Aug 10, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Need to reset lamp counters on a sharp XG-V10WU
1 turn projector switch off
2 remove lid and remove lamps
3 replace lid with out lamps
4 turn main switch to the on position
5 press the on switch on top
6 press enter
7 flip main switch to the off positon
8 replace lamps and lid
your done!!!!
Aug 03, 2009 | Sharp Projector Lamp for XGV10WU
Broken disk lid
Not sure if you can find a replacement lid but you may be able to play DVD's if you manually depress the small switch that the lid would engage if it were closed. The switch is located where the lid hinges at the right side, you should see a small rectangular hole. The switch can be depressed through that hole. Of cousre, your DVD will be spinning with no lid to protect it but just don't touch it while the disc is playing. When done playing, you can just turn the unit off or remove whatever you used to engage the small lid switch.
Greg
Nov 06, 2008 | Spectroniq PDV-808
Whirlpool Cabrio Washer flasing "lid"
sounds like a defective lid switch,unfortunately the only thing that can be done is to replace the lid switch.the switch is wired into the main control board and if you mess with it,you could possibly void your warranty.best advise is to wait for service tech.sorry
Sep 25, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore 23822 Top Load Washer Logo
247 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
