Question about Kenmore Refrigerators
I acquired a kenmore refrigerator (1069517650) (1991) which I was told had been running fine within days of me picking it up. When I got it home it ran fine for about 30 minutes before the compressor kicked off. It seemed to be cooling fine. I assumed that the compressor stopped due to heat cutoff due to the long on time, but exactly when it cut off I received a mild electrical shock as I was wiping down the front. I continued to wipe the frig down, but received additional shocks. I unplugged the unit at that time. Note that the cord I used to power the frig was missing the gnd connection. I plugged the frig in the next day and noting happened, no compressor noise, no fan noise, but the interior light was on. Any clues as to what is wrong?
  • 116 Answers
SOURCE: Sears Kenmore 53652300, doesn't cool
This usually indicates that the compressor is working too hard and drawing too much current. The click that you hear is a safety shut-off. Possible causes of this are numerous and usually require having a professional come in to fix the issue, it can range anywhere from a faulty compressor to a bad start relay.
There is in most cases a temporary fix, it is called a hard start relay/capacitor. It is usually available from an appliance parts retailer for around $15 to $20. Installation instructions are included, just be sure to unplug your refrigerator first and make sure that someone following you can repair from where you left off. This relay assembly can normally get you up and running but it should not be used as a permanent fix. This will not correct for a refrigerant leak in the system.
Check your refrigerator owners manual before making any repairs or modifications to your refrigerator, there may be an extended warranty on the sealed system and compressor.
Posted on Aug 01, 2008
  • 1122 Answers
SOURCE: Refrigerator not cooling properly
you need to turn the frezzer downso it lets more cold air into frig. and put the frig setting back in the middle,aslo vac off your coils under the frig.all this should work,if not let me know,also check to see if you have any frost buildup on the freezer walls-mike
Posted on Oct 14, 2008
repairman45
  • 130 Answers
SOURCE: Kenmore 596.50692001 side by side stopped cooling.
You most likely have a fried overload, it is the small white square shaped piece on the compressor, to tell if it is bad, remove it and smell it for electric burning smell, or if you shake it and it sounds like sand shaking around it is definately bad. costs around $25 to replace. You can purchas this at http://www.reliableparts.com/ using your model number.
Posted on Dec 01, 2010
heatman101
  • 43501 Answers
SOURCE: Water leaking from freezer box
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 11, 2011
  • 5 Answers
SOURCE: water leaking from freezer onto top shelf of frig.
You probably have a blocked or frozen drain hole in the freezer. This means that the water formed during defrost can't drain down to the evaporator tray beneath the fridge and instead goes through overflow holes into the refrigerator.
I posted about how I solved this problem in another post:
http://www.fixya.com/support/t8706684-water_leaking_inside_refrigerator
Posted on Mar 19, 2011
The compressor runs and freezer is cold, however the refrigerator side isn't cooling well. Doesn't feel like any air is blowing in the fridge, only the freezer. I tried turning off/resetting the system...
Your model numbers are a waste of time...
Kenmore 5522 / 655224 / 55222 / 55229
Side by Side Refrigerator... PICK One...!!!
"The" fan...??
There should be TWO fans running...
and the FAN that REALLY make the difference in your
described symptoms ... will not run with the DOOR
open (your evaporator fan).
Possible issues:
Fan motor, blades/air blocked by ice, broken blade,
defective door switch or control board...
I always preach... giving a troubled refrigerator
a THREE DAY defrost... but the other day I found
a solid ice block sitting all SNUGGLY in the middle of
an evaporator...
If you are not willing to do that... (3 day defrost)
open it completely and have a REAL GOOD look
around the EVAPORATOR & FAN.
Never use HOT air... soft plastics can be easily ruined.
Take your MODEL NUMBER...
And look on:
Appliancepartspros:
Search Over 2 1 Million Appliance Parts
PartSelect Appliance Parts and Repair Help
repair clinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Happy hunting...
Carnac the Magnificent
Aug 16, 2017 | Kenmore 5522 / 655224 / 55222 / 55229 Side...
Hello, a few months ago I brought a new laptop and I got Office home and student 2010, nobody told I had to install in within 30 days, so I was wondering if anybody had a Product key.
I believe you misunderstood the license conditions. The Office product you purchased along with your laptop is most probably a trial version limited to 30 days of function. The normal Office Home & Student does not come with a requirement to be installed within any time frame.
You cannot upgrade the trial for free, you need to purchase a full version of Office and install it.
If the seller told you differently when you acquired your laptop, you should hold him liable.
Jan 07, 2011 | Microsoft Office Home and Student 2010
Up box freezer works fine but low box refrigerator doesn't work
Good day,
2 hours isn't enough time. Doors open, unplugged, minimum of 24 hours, Ideally with a floor fan blowing into the machine.
Jan 15, 2010 | Kenmore 64802 Top Freezer Refrigerator
Kenmore elite water dispenser not working
We had the same problem after 4 months. A technician came out and told us that our water line within the refridgerator was frozen and that every once in a while we'd have to take a hair dryer to it (!). Of course we told him that was unacceptable so they sent a second tech out who replaced some parts by being walked through the repair over his cell phone. He was unable to tell us what happened or details about the repair. 11 months later our water line froze again and we resorted to a Brita water pitcher.
Aug 04, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Fan running, weak air, fridge not cold enough, freezer working fi
it sound that your fridge is cloged of ice if so defrost it by unpluging it for the day to defrost completlyb with freezer door open then replace defrost timer if to much ice is formed on coil air does not cuculate properly thanks from gille
Feb 15, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
New refrigerator
A refrigerator must get rid of condensate and "frost". There is a collection pan under the back of the unit where there is also a fan that helps removes the excess moisture back to the atmosphere.
Jan 05, 2008 | Kenmore 44273 Side by Side Refrigerator
Refrigerators Logo
62 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
