Question about Samsung HCM4216W 42" Rear Projection Television
I have a samsung hcm4215w , just put a new convergence board in . when i hit picture perfect it say no sensor data. how do i fix
Using the OEM remote, for the TV, power on the TV and press
Posted on Sep 25, 2010
Picture seems to be offline( curved down) also everything seems doubled and you can see the red, yellow and blue colors of the lenses on the screen
Tv have a problems known as a convergence problems it is dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the board that call the convergence board it is dead.This convergence board require service must be replacing parts 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the tv picture convergence problems mis alignment.The tvs shops,will cost u like around $300-350 for parts and labors.
May 28, 2011 | Samsung HCM4215W 42" Rear Projection...
"Perfect Focus" problem on Samsung HCN4727W
You have a bad sensor, a bad digital convergence board, or the new board is not working correctly. I would start by swaping out the convergence board or exchange it for another one. Good Luck
Nov 08, 2007 | Televison & Video
We have a HCM4215W 42' projection TV that we purchased in 2003. Our picture has color shadows. Perfect focus doesn't work and neither does manual convergence. This happened in 2006 when it was under...
If your TV looks 3D, warped, or distorted it likely has a convergenge problem. If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured. You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 24, 2011 | Samsung HCM4215W 42" Rear Projection...
Samsung 42'' HCM4215W image looks like it's in #D
Ill have to look up the part numbers , but it is a common problem caused by the convergence board at the back of the device. replace the TDA*** for the color that is faulty and the problem should be solved.
After replacing the TDA*** you need to adjust the convergence again and perform an auto-fucus and convergense adjust again
Jul 08, 2009 | Samsung Televison & Video
Samsung HCM4215w has wavy red lines and bowtie effect
Are you saying that after installing a new convergence board, you still have the same issue? If that's the case, another new board isn't going to resolve this. Also, you can't do a factory reset. Doing that would lose all the convergence and geometry data in the TV and would require a qualified technician hours of work to restore the settings. If you've installed a new board and have the same problem, suspect a problem in the TV's power supply. All convergence circuits require 2 voltages to operate. There will be a postive and a negative voltage of the same value. If you're missing either of these voltages, your convergence will never work properly.
michtech
Feb 17, 2009 | Samsung HCM4215W 42" Rear Projection...
Perfect focus reads "no sensor data"
hope this helps check out this above links
please check out this links
for convergence board ics reparing it your self
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
and for convergence settings
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
thanks.
Oct 09, 2008 | Samsung HCM5525W 55" Rear Projection...
Replaced convergence brd but now picture goes dark and audio stays on
I would suggest to go back and make sure that all the connectors are firmly inserted in their respective plugs.
Let me know if you need further assistance.
Apr 09, 2008 | Samsung HCM4215W 42" Rear Projection...
Samsung HCN4226W blue color outlines
Samsung parts for convergance problem
http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
This convergence board works with the following Samsung television models: HCM4215W, HCN529WX, HCN559WX/XAA, PCN5425R, HCN4226WX, HCN529WX/XA
Mar 10, 2008 | Samsung HCN4226W 42" Rear Projection...
Double picture
Convergence amp ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Feb 06, 2008 | Samsung HCN4226W 42" Rear Projection...
Convergence
Im trying to install that same board on the same tv how did you do it?
Apr 06, 2007 | Samsung HCL4715W 47" Rear Projection...
Samsung HCM4216W 42" Rear Projection Television Logo
Henry  Thomas
Henry Thomas
