Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Left Side of range top won't work
No matter what type of module, grill, or burners, It won't work. I know it is electrical. For some time, I was able to use the grill element, but now I can't even do that. We had someone come to look at it, and he said it needed a part. Hew was going to order the part, and never showed back up.
The right module burners work fine. I even purchased a new ceramic 2 burner module in case it was the module, but it wasn't.
Is there a part that I can order to fix this?
  • elargill May 13, 2008
    what is the best way to figure it out?
  • 1,073 Answers
It is either the wiring to the switch the main terminal block or the switch that is bad have to look and see or call a different servicer
Posted on May 13, 2008
Left front range top burner temerture control issues
Good Morning Friend,
I understand that you are having trouble with the left front burner on your Frigidaire range, model# FEF355. I see that the burner heats up to a glowing red hot temperature, no matter what you set the dial to. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes.
When power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "Clock" button, then within 5 seconds press and hold the up or down arrows until the correct time of day appears.
Once you have set the time, turn on the left front burner, on the lowest setting. If the burner is still glowing red hot, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your range and determine what is causing the burner to glow red hot on all settings. Hope this is helpful.
-Best Regards-
May 15, 2014 | Frigidaire FEF355 Electric Kitchen Range
Kenmore 79096011407 ceramic cook top. When front left burner is turned on, it goes to high and does not turn off. Had to use main breaker panel to turn off electric to the range. Can not find parts list...
Sounds like the switch for that burner needs to be replaced. Its possible that something else may be shorting out but usually its just the switch. Your ranges burners and switches are standard switches and burners for this type of range so the switch should fix it. Hope that helps.
Aug 29, 2011 | Kitchen Ranges
I have a Jenn Air S160 stove and the burners stopped working. Is there a reset button? The grill does work on one side but the burners do not. Thanks, Pam
Try switching the grill to the other side if it works the ceramic burner is bad replace the ceramic burner. burners and grill coils unplug when you pull them out. The left one pulls out from the front the right one pulls put from the rear. you can enterchange the burners on either side.
Oct 07, 2010 | Jenn-Air Kitchen Ranges
Left rear stove top electric burner does not work. burner element good. no power from stove to plug in module that has front and rear burner. front burner works.
ok you have a fun one becuase the sockets could be bad you need to check for 220volts at the plug in for the serface burners if no power there then bad switch
Jun 02, 2010 | Jenn-Air JES9750 Electric Kitchen Range
Jenn-Air model svd48600. Gas stove top, electric oven. Why would the exhaust fan turn itself on whe either of the left burners is lit.
The switch for the optional grill attachment is activating...pull the tray/pan on the left side that holds the two burner grates toward the should shut off. To correct the problem permanently, you'll need to adjust the position of the switch. The switch gets lose over time and slides on its mount until it gets out of range. The purpose of the switch is to activate the blower continuously when using the optional grill accessory. When you remove the left-side grates and the tray/pan the grates set'll notice a protruding piece of metal on the front of tray/pan that fits into a hole in the cavity where the tray sits. Inside that hole is the switch that is out of position. Getting at the switch to adjust its position is not difficult, but you need to remove the upper front panel...KLS
Dec 13, 2009 | Jenn-Air Kitchen Ranges
I have a Kitchenaid electric range Architect Series II. Seems every time I use the large burner on the right side there is some sort of residue left that is very hard to get off. I have already made a...
What are you using to clean the stove? Only cleaners made for ceran type tops should be used according to directions. Do not use enamel coated pans or glass pans on your cooktop.If you have a boil over, turn off the burner and change to a different burner immediately. Clean up the spill completely before cooking on that burner again. Use a flat edge razor to clean tough residue. Your cooktop will look new for years to come, even with heavy use.
As far as the scratch, don't use abrasive cleaners on the top and only use pots and pans with flat bottoms. If you do use cast iron pans, never scoot them around on the top.
Nov 30, 2009 | KitchenAid KESC307 Electric Kitchen Range
No spark on any burner. no spark in oven. How to troubleshoot with multi-meter? Assume I have basic electrical skills (have EE degree)
no need to troble shoot
your spark module is shot,
but to check this ensure you have
proper voltage into the spark module
voltage in,,,, nothing out replace
right under the top mounted on the left side wall
Oct 13, 2009 | Amana ARGS7650 Electric Kitchen Range
Viking range burners won't light
All of these ranges have a spark module at each burner sight and they all click when ever you attempt to light one burner. Therefore, it can not be assummed that the spark module for those nonworking burners are actually clicking. Remove the burner covers and actually look for the sparks. If there is no spark make sure the connections are nice and tight. IF they are, you most likely need to replace the spark module.
Apr 30, 2009 | Viking VGIC485-6G Gas Kitchen Range
2 burners work, 2 don't
ok, first check that the ranges are seated properly , clean the connectors , do a test , if it still doing the same problem , then you need to replace the modules of each range thats not working,in this case 2 modules.
Nov 15, 2007 | Kenmore 96213 Electric Kitchen Range
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
67 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
