Question about Uniden TRU9480 Cordless Telephone
Phone rings. No one there. No dial tone!
So the phone rings and I answer it. Can't hear anything. When I hang up, there's no dial tone. It comes back on by itself OR I once unplugged the power and replugged it back in and the dial tone came back on. This doesn't happen all the time. Just occasionally, randomly.
The base is plugged into the same outlet as the fridge--could this be related?
It's definitely at the base as I plugged in a corded phone with a dial tone at the same time the uniden cordless was unable to get a dial tone. It wasn't until I unplugged the power that I got the dial tone.
  • alejo8322 Aug 05, 2008
    Same issue reported by "ajroszak". The phone rings and when I answer the call the phone dies...nothing....kaput. I have to disconnect/reconnect to the AC power then it goes back to normal It happens to me fequently, several times during the month....very annoying.
    I have corded phone that worked fine while I had the issue with the Uniden, so can not blame my phone carrier.
  • perthgent Aug 11, 2008
    I have the same problem exactly, and would like to know the solution. I believe this is a crappy product, since this fault is obviously common. I have used this phone only maybe 50 times in total since new. My previous cordless, a Panasonic, lasted many years without defect.
  • 86 Answers
SOURCE: Uniden TCX805 Cordless "loses" dial tone
Sounds like the switching mechanism that creates the link is stuck. When you answer your phone, you allow the voltage to complete it's path and you either answer the phone or you hear dial tone. If that switch is stuck closed, even though you hung up the phone, the connection is still alive. When you try to pick the phone back up later, the connection is still closed, but your phone has already passed it's "if you would like to make a call" message and you hear no dial tone. Unplugging the power to the phone resets this switch and all is good again.....that is until it gets stuck again. I have seen this problem with phones after a near lightening strike at the house. Sounds like you need to get a new phone as I don't think this is repairable.
Posted on Jan 20, 2008
jadyn08
  • 12 Answers
SOURCE: Uniden cordless phone. No dial tone.
Hi peddler65, did you plug your phone into another area to see if there is a dial tone. Then if not call the phone company or find the D-mark (where your dial tone ) comes into your home and put a jack on that and plug a phone in with all phones in the house unplugged.
Thanks.
Posted on Nov 15, 2008
  • 16 Answers
SOURCE: Uniden 1725 no dial tone
I had the same problem as long as they are plugged in correctly and you put the #2 handset into the #1 cradle to register it to your base then try hanging the phone up several times. These are expandable phones so that I believe you can keep adding other handsets. So sometimes they think you have a few more handsets than you really have so when you hang up it may not know what handset you are hanging up #1 #2 or #3 #4 etc. So I had to keep hanging them up until it finally hung up. Then I had to re install them so it knew I only had 2 hand sets. So then you start from the beginning, like when you took it from the packaging. I hate these phones. I ended up replacing them with different ones. Plus I always keep a rotery phone laying around put away because during a power outage you still can plug in an old dial phone and it will work! Nothing like old technology.
Posted on Feb 15, 2009
  • 7993 Answers
SOURCE: Have a uniden DECT 6.0 with a corded main base and
You might have missed some relevant information while troubleshooting. Here is a link to the manual.
http://www.uniden.com/index/manuals_results.cfm?cat=59
Select model and download manual.
Hope it helps.
Posted on Sep 14, 2009
  • 79 Answers
SOURCE: I have no dial tones on our two uniden 5.8GHz
Make sure the phone and the phone base is turned on. Check the phone cables at the back of the phone base where you charge your cordless phone. It should be properly connected to the phone jack on the wall and at the back of the phone base. Try unplugging and replugging it back in. If that fails, try changing the phone cable. If still there's nothing, try to connect another phone on the phone line. If you get a dial tone, it means you have a problem with the wireless phone set, if not, contact your phone company.
Posted on Nov 11, 2009
WHEN I CALL MY HOUSE PHONE IT DOES RING BUT YOU CANT HEAR ANYTHING AND THERE IS NO DIAL TONE IN IT
you have a line fault. Phone your telecoms company. Often they can fix it at the exchange or on a pole, or the junction box outside your house.
Feb 02, 2016 | Lands Phones
Why can't I rec or make calls?
What is happening when a call comes in are they getting a busy signal? If so your line is shorted out.. unplug all phones and see if caller hears a ring.. Then 1 at a time plug phones in. Check for a dial tone and press a digit, hang up and check and see if dial tone returns, repeat this on all phones, until you get to the phone that does not give you dial tone back after dialing a digit. That will be your bad phone... If the line was ring busy after all phones unplugged, call repair service..
Aug 10, 2015 | Lands Phones
How can I get more than 3 rings? I am in my 70s and disabled. I can not get to my phone to answer in 3 rings. I miss calls due to this.
  1. Pick up the home phone receiver, wait for dial tone, and dial *94. You'll hear 3 beeps followed by dial tone.
  2. Enter the number of rings you want (between 2 and 9).
  3. Listen for 2 confirmation beeps and hang up.
Dec 11, 2014 | Vtech CS6719-16 Cordless Phone with Caller...
Merlin BIS-10 no dial tone and can't answer but phone rings
I have a dial tone but can not make calls. and if the phone ring they can hear me but I cannot hear them
Apr 01, 2013 | Avaya MLS 12D Corded Phone
How does one forward incomming calls on a uniden 2.4ghz cordless phone?
Cordless phones can not 'forward' a call to an outside line.
Forwarding must be controlled by the ATT, Verizon, or landline provider.
Please contact your provider to determine if you have call forwarding feature built into your service package.
Then, follow the instructions of your landline phone provider.
Here is the instructions for Verizon:
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
  1. Lift your telephone's receiver and listen for a dial tone.
  2. Press star.gif7.gif2.gif.
    Dial 1172 on rotary or pulse-dialing phones.
  3. When you hear the tone, set or change the Call Forwarding number by dialing the telephone number where you want your calls transferred.
    You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
  4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
    You will hear two short tones telling you that Call Forwarding is activated.
  5. Hang up the receiver.
Feb 16, 2011 | Cell Phones
When dialing with my logitech skype phone I can't hear any sound until the other person answers the phone. It only happens with skype to skype calls. It works perfectly calling regular phones.
This is probably because dial tones and ringing tones are part of an archaic system. Your cell phone still makes these noises as a courtesy, and you hear the dial tones/ringing tones when you make regular calls because your phone is communicating with the standard phone system.
Jul 12, 2010 | Logitech Cordless Internet HandsetĀ for...
My phone rings but i can't hear anything on the end
i have a GE 6.0 cordless telephone, i know tha it's ringing the number comes up on my television but I can't hear it ring?
Sep 23, 2009 | Uniden DECT 6.0 Cordless Telephone...
I need to retrieve my home phone messages from cell phone
2. Press *7 2.
In some areas you must use 72#
3. At the tone, dial the telephone number where you want your calls transferred.
Deactivating Call Forwarding
Turn Call Forwarding off when you want to receive calls on your home phone.
2. Press * 73.
In some areas you must use 73#
Dial 1173 on rotary or pulse-dialing phones.
3. Listen for two short tones.
Call Forwarding is now off and you will receive your calls at your home number.
Dec 01, 2008 | Uniden Cordless Phone
Answering phone system cannot handle nuisance calls
i have problem with my phone (TX TCA115UA B)
i can not turn on the tone regime (now is on pulse regime when i dile the number)
Feb 05, 2008 | Panasonic KX-TG5632 Phone
I've lost my manual and need troubleshooting help
Our phone decides to call screen people so the answering machine goes on after 2 rings. We can't find the manual.
Dec 10, 2007 | Uniden TRU8885 Digital Answering Machine
Uniden TRU9480 Cordless Telephone Logo
678 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
