Question about Linksys Wireless-G WRT54G Router
I have the S2 router and my mac isn't picking up the wireless signal.
    Sergeant:
  • 284 Answers
Did u checked ur wireless setting in router???
Posted on Sep 06, 2010
My wireless network isn't working
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Apr 19, 2012 | Toshiba Satellite Pro L300 Notebook
I have a wired network in my house. An aerial on my roof picks up a wireless signal from a transmitter/receiver unit in the village. I can also pick up a wireless signal from the same aerial. I want to...
You can, in most cases, connect a Wireless router to your POS and let your provider know the MAC address of the device and then go from there for setting up your network. If you don't wish to replace your current router you can connect the wireless router to the current LAN router and establish a wireless network from there. Make sure you set up WEP or WPA security on your Wireless network to keep other people from hacking or using it without your knowledge. This is normally the only requirement Service Providers place users establishing a wireless network.
Oct 12, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
Router cannot find wireless network
1. check if you have cloned the MAC address in the either the Advanced or basic setup page.
2. After verification of the MAC clone restart the router
3. after router is restart then log in to the router >> go to status page and verify IP Adress.
If no ip address from cable modem then pwer cycle the cable modem >> then power cycle the router.
Apr 25, 2010 | Linksys Wireless-G WRT54G Router
I have a dell Vostro 200..I want to go wireless with a Airport, Just got a Mac with the airport, will this work?
The airport is just a receiver that picks up wireless signals.
If you want your computer to pick up wireless, you need a wireless
router, and a wireless card that goes into the computer so it can see the router and get the signals.
There are tons of wireless products, and it depends on the slots you have on which kind of wireless card you get.
Feb 11, 2010 | Dell Vostro 200 PC Desktop
I cant seem to pick up a very strong signal. Do i need an antenna booster?
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arid welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Oct 24, 2009 | Linksys Wireless-G WUSB54G 802.11g/b
Symbol MC9090 unable to connect to wireless network...
check in your router MAC security
if in your router MAC security is enabled then only those can connect whose MAC addresses are in allow list in router.
you can access your router with following link
http://192.168.1.1
or
http://192.168.1.0
for belkin router
http://192.168.2.1
type user name as "admin" and password as "admin" or blank or "password
then go to wireless advanced security then check MAC security if enabled then add your moto MAC in allow list.
Let me know .
Jul 29, 2009 | Symbol Motorola MC9090 Mobile Computer
I have bought a laptop from someone and it has a edimax EW-7305Pg wireless LAN Cardbus. I am having problems connecting it to a netgear wireless router supplied by sky. I have sky broadband. I uninstalled...
is the mac address registered through your wireless router, your router maybe running wireless mac filter, if not try registering your wireless mac address on your router then try reconnecting your computer to your router.
Feb 01, 2009 | Computers & Internet
Can't find wireless Signal
Make sure her router is configured to broadcast the SSID as that can either be disabled or enabled. Once thats enabled and you still cant see it try and set it to different wireless channels and change the wireless network mode to 'mix"
Jan 03, 2009 | HP Pavilion dv6000z Notebook
DI-524 wireless router no signal missing antenna
tat dlink device is a good device i shld techinically still produce signals
but wat happened to antena if it is broken u might as well go for new router
as far i remember u wont get antena seperatly
on ur mac book scan for signal see if u are pick up signal
if yes you are lucky it shld still transmit else go for a new router
Dec 08, 2008 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Linksys Wireless-G WRT54G Router Logo
27 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
