Question about Panasonic NN-P994SF Microwave Oven
We have a panasonic NN-P994SFR that has worked great for four years. A few days ago the machine went completely blank. No power, nothing. The circuit TO the microwave is totally fine. Is there a fuse or something that may have blown inside the oven?
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic NN- A712 combination Microwave 1000w - Switches off after 20 seconds
The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
SOURCE: Panasonic NN-CS596S Convection Combi Steam Oven
Thanks for this. Thats exactly what I did. It didn't work at first, however, I think it was my impatience! After selecting the Microwave, you MUST wait until you are told via the screen to input the time. It now works fine. Thanks again. Just needed perseverance! Mike
Posted on Aug 18, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave Panasonic Genius Prestige Model
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
The TCOs you need to be concerned usually with have all black or white wires only. Please reply with photos of your interior if you have questions.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can order Panasonic parts here.
You can find an authorized Panasonic servicer here.
Posted on Sep 28, 2008
SOURCE: Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Posted on Oct 21, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Hi, I have a NN-C784MF
Chances are there are other bad parts blowing the diodes, most likely a MOSFET.
Also, the ESR of the electrolytic capacitors should be checked and all board connections must be checked and resoldered if suspect.
If you're not experienced in troubleshooting switched-mode power supplies (inverters) then you can probably save a lot of timer and money by replacing the whole inverter.
You can find the nearest spare parts supplier by selecting your country then the support links at Panasonic.net.
Posted on Jan 02, 2009
Power shuts off completely
Microwave NN-SD697S; Went i push start switch, some time start and some time not, power it fine. thanks for replying
Feb 02, 2013 | Panasonic NN-SD688 Microwave Oven...
Panasonic NN-SD277. Almost 3 years old. We pressed start, it went for about a second (may have made a sparking sound) and then it just lost all power. There is still power to microwave but no lights are...
We also have this same microwave. It is less than 3 years old. We've had nothing but problems since we purchased it. In November 2010, the microwave made a crackling sound and then BOOM! Nothing. I have been back and forth with Panasonic. I refuse to pay for the repair on an appliance that is less than 3 years old. It's ridiculous!
Anyway, the problem t is an issue with their inverters. Google it and you will find page after page of the same story.
Jan 21, 2011 | Panasonic Microwave Ovens
My model nn-p295wf microwave stopped working ,all power just stopped, about a year ago. I took it to a repair shop and they replaced the DIODE and the fuse, then it worked again. Afew weeks ago it happened...
Replace the magnetron, safety fuse and diode as a set and check the door interlock switches.
That should get it working for another year or so.
Don't forget microwave mains fuses are special sand filled and semisurge type.
Nov 16, 2010 | Panasonic NN-P295SF Microwave Oven
Panasonic Microwave NN-T993SF has no power. Was working and suddenly the power went out like it was unplugged. It is not our fuses or cord but something in the microwave itself. Is there a fuse or...
most microwaves do have an internal ceramic fuse either 15 amp or 20 amp the cover has to come off to locate it usually at the top just behind the control board. do not touch the high voltage capacitor as it holds a charge even when the unit is unplugged.
Nov 07, 2009 | Panasonic NN-T993SF Microwave Oven
Same Problem - Suddenly Died ~2yrs old, very light use.
Probably a fuse inside the unit. Can be caused by overheating or by door switches not working properly.
Sep 10, 2009 | Panasonic NN-P794SF Microwave Oven
Panasonic microwave oven NN-S235WF modle
just replace micorwave power out let.
Dec 30, 2008 | Microwave Ovens
No power to Panasonic NN-S252 microwave oven
follow the incoming mains lead into the microwave their is a small pcb with a fuse their check this first
Nov 14, 2008 | Panasonic NN-S254BF Microwave Oven
Jul 14, 2008 | Panasonic NN-S753 Microwave Oven
Panasonic NN- S760BA heating problems
Chances are it has a bad magnetron. If you decide to have it serviced, I would definitely recommend that you contact a servicer who is authorized by Panasonic. You can find them here: http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001 Good luck.
Feb 20, 2007 | Panasonic NN-S762 Microwave Oven
Microwave Ovens Logo
540 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
