Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I have had the"ld" message show up repeatedly. when this happens all of the water is drained. It appears that it locks up and wont start the next cycle. I have been unplugging the unit to reset it and i works fine for a while. what can i do so this does not happen any more
  • 347 Answers
Ld IS AN ERROR CODE FOR LONG DRAIN. The computer thinks it is taking to long to drain.These units are famous for getting small clothing items sucked up under the wash basket. The only sure fix itto remove the wash tub and remove the obstructions keeping it from draining properly,and start using a mesh bag for smaller items..To remove basket use a stiff putty knife to open the top about 1and 1/2 inches in on each side of the top push in on clips .Remove tub top cover ,just clips on outer tub. pry loose center cap in center of wash plate remove bolt holding wash plate pull out wash plate..then just pull up on wash basket nothing holding it ( its designed to float) the remove whatever is under the basket ,sounds like a lot of work but its really not i have done it a hundred times,,,GOOD LUCK
Posted on Sep 07, 2010
LD ERROR CODE AND WONT DRAIN LID WILL LOCK
try any button sequences yet . try holding start button and a cycle button hold both down to reset
Apr 01, 2013 | Whirlpool Cabrio WTW6800W Washer
LD is showing.Does not do the washing.When started, it stops and LD shows and just keeps on beeping.
Ld - Long drain - Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Press STOP/CANCEL to clear the display.
Mar 13, 2011 | Washing Machines
The code LD appears and washer will not drain
LD is long drain error usually an indication of an obstruction in the drain hose or the pump is not working check the drain hose first from the pump to the outside of the unit if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Feb 25, 2011 | Maytag MAH6500 Neptune Front Loading...
Whirlpool Calipso model clothes washer shows a LD and doesnt run
The OB indicates and out of balance condition has been detected by the motor control.
One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 05, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Ld code appears intermittantly
ld is a long drain time...you may have something in he drain or a bad inpeller in the drain pump...it is taking too long to drain out
Sep 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore (Calypso) Elite Washing machine shows LD and LF!
LD means long drain and according to the manual your drain hose could be clogged or kinked.
LF means long fill. check your water hoses and the screens to make sure they are not clogged. Had that happen to me once and i had to change the hoses. several months later same thing happened and it was the motor pump part # 8054968, this you can fix yourself.
Dec 10, 2008 | Kenmore Elite 21086
Wont drain says Ld
I was having the same issues, I replaced the motor/pump, cost about $145.00 and replaced it myself, A repairman will charge up to an extra $100.00 for an hour of work. I ran a load of towels and it ran great and sounded quite. Woohoo im the hero, not!! the very next load the error "LD" came back at the 7 min remaining mark. so i pulled out all the wet clothes and ran a quick wash and watched the progress,the washer was draining but again at the 7 minute mark, it seemed the washer was struggling and not spinning. At this point im thinking i have to replace the spin motor and belts. But i kept getting the "LD" code which does'nt add up. So i crawled behind the washing machine again, took the back off, this time i disconnected the Long drain. I found the best way to get rid of the water in the tank is to unhook the long drain from the back of the frame, there are two(2) white clips on the inside and one(1) black "C" clip on the hose on the back where hose comes out. I used our carpet cleaner, lowered the hose till water started coming out and poured water straight into the hose for the cleaner. Im sure a shop vac will work as well. If you don't have a cleaner or shop vac, just use a large cup you'll get most of the water out, keep a towel handy for some clean-up. After the water level was below hose level in tank, i took the hose off, (you'll need pliers to squeeze the clamp from hose). There it was, my problem, not one(1) but two(2) bra wires stuck in the drain port, causing the float valve ball to be jammed and sending the message to the machine brain to shut down due to a blockage at the drain. Duh hench the code "LD". Somehow the bra wires made there way over the wash plate through the quarter size holes on bottom of wash basin and thorough the tank to the drain port. After reassembling the drain hose and washing machine, my wife has completed several loads of laundry and im on the hero status again. I sure hope this fix will help you get on the hero status and save you $145.00 or more.
Jul 08, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Dishwasher LD-14AW2, stopped working mid cycle
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Sep 15, 2007 | LG 24 in. LD-12BW5 Free-standing...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
387 people viewed this question
Dan Webster
Dan Webster
Sal De
