Question about Bruder Cat Skid Steer Loader
I am changing the tracks on a CAT 277B skidsteer. I gat the old one off but cant get the new one on. What is the trick?
Driver door window cables kits. Cable seems to short and will not go back together
I been there it takes some doing but it will fit just kept trying you can do it
Jan 22, 2013 | 2004 Volkswagen New Beetle Convertible
New holland ls170 skidsteer runs but will not move and hydralics do not work
Could be very expensive to fix. Check that there is hydraulic fluid in reservoirs/pumps. Check seals on all hydraulics. Check hydraulic pump. Leaks? I'm not an expert, but I almost bought a used skidsteer for next to nothing, but consulted a local excavator-guy I know on it. He steered me away from it saying "It may only be priced at $3000, but it could cost you $10,000 to fix it.
May 27, 2012 | Toys
I have a New Bright caterpillar(1985 vintage) "The Cat 245", and I am looking for the rubber tracks. The cat works, but the rubber tracks are broken. Looking for a company that makes tracks for...
I got the same problem with tracked toys. They seem to stop producing those tracks, what I did is to buy a new set of tracks from a model kit store, usually tracks from a 1/25 scale model kit battle tank. You could buy the accessory tracks from the hobby store and bring your old one to comape it.
Hope that helps you out!
Thanks for using Fixya!
Dec 17, 2010 | Toys
Need to find replacement for broken belt/track.
Belts for cleated tracks are no longer available from arctic cat. You will have to find a used belt on EBAY, at a salvage yard, or upgrade to a rubber track. An Arctic dealer can look up pieces needed to upgrade to rubber track from the old accessory parts listing to do the upgrade. You will need to replace your drive sprockets and possibly the drive axle to run a rubber track with out cleats.
Oct 24, 2010 | Interactive Toy Concepts Crossfire Arctic...
Replacing glass and regulator on 2008 nitro cant find how to releace window track to install new glass what trick am i missing??????
there should be screws on the bottom of the track on both ends mid way, once loosen glass will slide up and out. hope this helped tim
Oct 15, 2010 | 2008 Dodge Nitro
I want to change the time zone from utc to cat or gat
Double click on the Time/Date in the bottom right-hand corner of your screen.
When that loads, select a new Time Zone from the drop down load in the middle of the dialogue.
May 21, 2010 | Dell Vostro 1310 Notebook
The printer is showing a message unable to clean 46 i cant do anything and i cant switch off the printer.
you have 2 options.
Take it to a repair center, or just replace it with a new one.
Sorry to say no way to fix that yourself.
Dec 11, 2009 | Brother Office Equipment & Supplies
Coolant indicator light is on and alarm is beeping
You have to clear the fault code in the engine ECM. Even though you filled up the coolant and solved the physical problem the computer stored the code. I'm not sure about the Cat skid steers, but my TL130 did this and I disconnected the battery overnight and it went away. I'm sure if you contact your local CAT dealer they will tell you how to clear it, just have your machine serial number handy cause they're gonna ask for it. Hope that helped...
Mar 20, 2009 | Caterpillar American Construction...
Purr pals
HOW TO FEED A PURPALS CAT
I figured out how to FEED A PURRPALS cat, use the to stylus drag the food box over to the arrow hoovering above the food bowl on the touch screen and move it left and right quickly thereby 'shaking the box' this will fill the bowl and FEED the cat.
ps I was doing this for ages before i figured it out.
happy feeding
Oct 15, 2008 | Crave Entertainment Purr Pals for DS
Bruder Cat Skid Steer Loader Logo
386 people viewed this question
Top Bruder Toys Experts
ptpumpman
Marc Taylor
Colin Stickland
Colin Stickland
Are you a Bruder Toy Expert? Answer questions, earn points and help others
