Question about Xerox WorkCentre Pro 416 All-In-One Laser Printer
Error Code Call For Service
We have a 416DC that was working fine until this error code came up ... "Call For Service". I was able to find out that it was a "CA1" error code. We followed your instructions about 0-8, enter 400, etc. but they did not work. You then mentioned something about perrforming the following checks, but I did not see them listed. Do you have any further suggestions? Thank you so much, Tom
  • Anonymous Aug 22, 2008
    The Pro 416 needed drum cartridge replacement & once it was replaced it gave a "call for service" message. Error code CA1. What do we have to do now??
  • davidtek Feb 24, 2009
    Error code CA1 I tried the other code 400 but what is the code for DT
    President:
  • 2,072 Answers
Most likely the laser has failed and needs replaced. Here is the documentation.
CA1 Indicates that the polygon motor in the ROS has failed.
Error Code Call For Service - arrwup.gifProcedure Enter output test, code 103, GP 10.
The polygon motor runs. Yes No Unanswered
Perform the following:
  • Check the connector CN26 on the Interface PWB. Refer to Wiring Diagram 4.
  • Check the harness and the pin connectors.
  • Check the Interface PWB for damage.
  • Install a new ROS, PL 9.10 Item 15.
  • Install a new Interface PWB, PL 9.30 Item 5.
Check at connector CN26 pin 4 on the Interface PWB for a low signal. Refer to Wiring Diagram 4.
The signal is low. Yes No Unanswered
  • Check all the connectors to the interface PWB are pushed fully home.
  • Check the interface PWB for damage.
  • Install a new interface PWB, PL 9.30 Item 5.
Posted on May 13, 2008
  • 239 Answers
For this problem, the software has to be the latest version.
A Xerox Service rep can solve this problem.
The problem is the timing on the scaner is not right, the software can correct it.
The right main board needs to be compatible with the software.
Changing the Ros is not the total solution. This problem can come back even when changing the Ros. Also, the right part(The Ros) needs to be installed on the right model machine.
Good luck.
Posted on Dec 12, 2009
Sharp photocopy machine showing error code Sc 542
SC 542 Basically the machine is telling you that the fuser did not reach its target temperature in a specified amount of time. In normal circumstances this code will appear if the thermistor is not maintained or replace periodically or in abnormal circumstance the heat lamp blew. This is a Service Tech reset code. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won't come ready until the prior error condition is cleared. basically you will have to care a service tech to clear it
Aug 03, 2015 | Sharp Office Equipment & Supplies
We have Error Code CA1
you need to replace the laser unit and upgrade firmware
Sep 21, 2010 | Xerox WorkCentre Pro 416DC Copier
Konica 7020 error code f-26-2
Says that it is a PCL connector problem. Look at all of your connections and make sure they are ok.
Jun 24, 2010 | Office Equipment & Supplies
Error sc 547
Found this from:
http://slayo.com/ricoh-cl4000dn-error-code-sc542.html
Ricoh CL4000DN Error Code SC542
Turns out error SC542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won’t come ready until the prior error condition is cleared.
A few phone calls with our local Ricoh service rep, and he admitted that the printer might trip this error in a power brownout.
The printer was less than 30 days old and the error was caused by the brownout or the fuser failed. I kept calling the Ricoh rep, and they finally gave me the magic keystrokes over the phone.
I did the magic keystrokes, cleared the error code, and the printer worked fine. It’s been working great for a year now.
I hope someone else who has this problem finds this page and is able to fix the problem also. I didn’t find any help on the net when I searched.
The Fix In order to clear error SC542, you must perform procedure 5810.
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
The error code is now cleared.
Hope this helps!
WizardRepair
Jul 17, 2009 | Ricoh CL4000DN Laser Printer
Error code on my blackberry 8330
Keep getting error code 0x80043ac9 when sync'ing my BB Curve 8330. Won't let me finish sync'ing address book. Stops at 2906 of 3814 contacts. Calendar won't update either. Worked fine until 8/10/10. Back up works fine.
Jul 06, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Error code E5 41 on Ricoh copier model 4527, or FT 4527
It is a fuser error (low warm up temp), often caused by fluctuating voltage.You have a blown fuse, lamp, or thermistor. Can only be reset in service mode after the problem is solved.
Mar 11, 2009 | Ricoh Office Equipment & Supplies
SHARP AR C250 Digital Color COPIER HAS SERVICE CODE H4 00
Press P-interrupt-C-interrupt and enter test command 14 and Execute to clear your error. Let your machine reboot. If it comes back you have a problem with your fuser. Most likely it's dirt or toner caked on your tempature sensors and they need to be scraped off.
Mar 17, 2008 | Sharp AR C250A Color Copier
Kodak Easyshare 5300, fatal error 3812
That's an error with the ink. Try updating the firmware on the printer. Here is the link to the latest firmware from the Kodak website.
http://www.kodak.com/global/en/service/downloads/dln_ekn033540.jhtml?pq-path=9106
Dec 25, 2007 | Kodak EASYSHARE 5300 All-In-One InkJet...
Xerox WorkCentre Pro 416 All-In-One Laser Printer Logo
600 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
