Question about De Dietrich DOC310 Electric Single Oven
De Dietrich Oven - Clock tripping back to 00:00 means I cant turn on my oven!
I have a De Dietrich DOC310 and the clock keeps tripping back to 00:00. Each time I reset the clock it trips back so I can not actually turn my oven on at all. Has anyone had a similar problem?
  • 4 more comments
  • mundo222 May 16, 2008
    i have exactly the same problem!
  • stevebull Jul 05, 2008
    I Have exactly the same issue...... anyone have a solution
  • bbhewee Aug 06, 2008
    I have the exact same problem...
  • JULIE KINNIS Nov 05, 2008
    I have the same problem, but have 2 ovens side by side, first the display on the clocks to both went at the same time, now they keep flashing and I can't use the ovens at all.
  • neile Dec 07, 2008
    We have a double oven model dod338 the timer clock has gradually got fainter & fainter over the last few weeks. Now the main oven has stopped working & we are unable to reset display. You can set the correct time but when trying to store it just bleeps & dies.
    Anybody got any ideas ??? PLEASEEEEEEEEEEEE
  • Anonymous May 22, 2009
    its really the same problem that we have now.
Its a fix more than a solution but you can bypass the clock thus allowing the oven to operate again
unplug at the mains and remove the oven from the housing remove the two fastening screws from the metal lid on the top of the oven ,and remove the lid
you will see the timer back panel with 3 wires coming to it, 2 are black (switching line) and 1 is red (Live feed to timer )
If you pull the connectors from the 2 black wires from the timer board and connect the ends together using a connector block, the timer switch becomes inactive and allows the oven functions to operate again.
you will have no timer functions but its a cheap fix and who uses the timer any way
good luck Andy B
ps if anyone has a set of operating manuals for ths oven i would be glad of a copy
Posted on Sep 26, 2008
  • roh077 May 04, 2011
    thats a good idea, lets tell people who dont know anything about electricity to start playing about with the inside of their oven, rather than getting somebody who does. oh and what happens if the oven comes into the hands of another owner who doesnt know the clock has been bypassed. so they set the timer to cook something while they are out and come home to several fire engines putting out their house. cool!!
    Problem Solver:
  • 5 Answers
The problem is on the Big 1,5 uF Condenser/Filter. Just replace the condenser and it will be as good as new.
Posted on Mar 05, 2009
  • Roi Abrevaya
    Roi Abrevaya Aug 15, 2013
    how do you do it ?
Same problem here!
Posted on Aug 06, 2008
De dietrich oven clock tripping out
I already explained, you need to replace the big 1.5uF Capacitor that
is reponsible for the voltage drop from 220V to about 10V. You need to
remove the timer controler module from the oven, in the meanwhile you
can shunt the 2 wires that usually are shunt by the relay, and then
buy a new capacitor and replace it with a soldering iron.
Good luck.
Apr 11, 2013 | De Dietrich DOC310 Electric Single Oven
What is the telephone number of De Dietrich support in Israel?
You can eother log a call with them on their customer service page:
http://www.dedietrich-heating.com/services/contact_our_customer_service
Or, the customer service rep in israel is:
Israel
MODCHEM Ltd. AGENCIES
Hararit - M.P. Misgav 20182
Israel
Phone +972-4-6782777
Fax +972-4-6782770
nachum@modchem.com
Jul 19, 2011 | De Dietrich DOC310 Electric Single Oven
The oven is working except for when the fan oven setting is used only cold air is being emitted. Does that mean a new element is required?
Yes it does require a new element to be fitted.
This is located at the rear of the oven compartment behind a removeable cover.
Feb 05, 2011 | De Dietrich DOC310 Electric Single Oven
Why does my De Dietrich oven trip the RCD fuse?
You need to replace the oven element, as this is what is causing the prob.
Please rate my solution.
Thanks.
Nov 06, 2009 | De Dietrich DOC310 Electric Single Oven
The part that needs replacing is the clock timer.
FIRST: ISOLATE THE CIRCUIT.
The front fascia is held on by three clips. Take off the two knobs and gently pry away the fascia fron the left, right and top centre.
The clock timer is held in by four plastic push clips at the top and bottom about 1cm in from the end. Push them in and pull the timer out.
There are now three wires on push clips attached at the back.
Do not take the colours for granted. On my oven just repaired the Live was Black and the Neutral was Red! The black marked 'C' is the input. The side by the trip switch is the output. The Red goes on the other side.
When the timer trips it causes the circuit between the input and output to break.
You have two options now:
Read the serial number of the timer and try and order it (expensive), swap the cables over.
Carefully run an electrical cable between the push clips on both black cables making sure you leave no exposed wire. Your timer and clock however will never work, the oven just does not care about it anymore.
Note: I am not an oven engineer, I am an electrical engineer in another field and have tested voltages and current and believe this to be safe. I have done this on my own oven.
Sep 12, 2009 | De Dietrich DOC310 Electric Single Oven
The oven won't come on, the digital timer just flashes continuous
Hi
have you tried setting the clock as the oven wont work if the clock is not set. hope this helps
regards dan
Mar 19, 2009 | De Dietrich UMP404 Powerclean Stainless...
Clock problem
had same problem but didn't fix it because i don't use the clock. after a few months it got worse, can't set the time (clock always flashing) so the oven doesn't work.
Jan 21, 2008 | De Dietrich DOC310 Electric Single Oven
De Dietrich DOC310 Electric Single Oven Logo
3,379 people viewed this question
Top De Dietrich Ovens Experts
ashburton
Shehu Pro
Shehu Pro
ray gallant
Are you a De Dietrich Oven Expert? Answer questions, earn points and help others
