Question about Solo Garden
I have a solo 119 line trimmer do I change the spool or restring it
  • 3 Answers
SOURCE: changing spool on weed trimmer
unscrew the knob on the bottom(turn cc wise) pull bobbin straight out . To restring pull start rope gently to see what direction it turns and wrap string in the opposite direction. Re insert the string into the corresponding hole(s) and screw up knob by hand until tight.
Posted on Nov 19, 2007
useless
Posted on May 10, 2008
  • 313 Answers
SOURCE: Black & Decker Grass Hog Electric Trimmer
the problem is the white lever may be broken. its located at the bakc of the spool line,
Posted on Jun 01, 2008
  • 3 Answers
How do you replace the white lever, and how do you know if it is broken?
Posted on Jul 14, 2008
SOURCE: how do I wind trimmer line on double spoools for ryobi
Okay, so the good news is that YOU are probably not stupid. If you have a Ryobi trimmer like I do, it might have taken you a while to figure out the "secret" on how to rewind the line. If you only had to learn the lesson once, you are smarter than I am. (I'm leaving myself a note for next time).
If you wind the line the wrong way, you go through line really fast until it clogs up inside the bump head and you are forced to try again. The trimmer has an arrow on the spool for the direction to re-wind the line. Think of it this way, TURN THE SPOOL IN THE DIRECTION OF THE ARROW! Don't do what I did and rewind the line in the direction of the arrow, that would be wrong.
Whether this is a "mistake", a way to sell more trimmers/parts/line, or simply bad tranlation from Japanese to Engrish, it really doesn't matter. You don't need to buy anything with the exception of new line.
Good Ruck,
Mark
Posted on Aug 18, 2009
How to restring cordless weed trimmer
Make a sharp bend in the line and insert it into the hole in the spool hub. Start wrapping the replacement line in the direction shown on the spool.
Jul 25, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
HOW DO I RESTRING MY 2 LINE HOMELITE 13" CORDED TRIMMER
On trimmers I have you take out the spool by pushing in the lock ears and pulling out the spool. Then put the end of the line in a little hole in the spool and wind the line in the direction shown on the spool till it is full. Do the same for the other line. Leave a little slack so you can put a few inches of line through the hole in the cutter head as you snap the spool back into place.
Jul 31, 2013 | Garden
How to restring a husqvarna 224L
To remove the head to restring, push in the bumper cap/side tabs on the strimmer head, the top should then just pull off exposing the inner spool.
Jul 24, 2012 | Husqvarna Weed Trimmer 224 L 4-stroke Line...
Need to restring spool
The spool should come off pretty easily. Make sure you go with some of that green line, I put that on my Stihl FS 90 R and it whacks through anything, also lasts a very long time.
Aug 10, 2010 | Husqvarna 28cc Gas Line Trimmer
How do I open the spool to restring a Troy Bult line trimmer
They come with a rig pin to lock the spool in place, then turn the large platic ball on the bottom of the trimmer head COUNTER CLOCKWISE. do not try to fill up the spool with line it will only get stuck and melt together. You should also sprinkle the line with baby powder as you wind it up as it reduces sticking too.
May 25, 2010 | Troy Bilt Tb70ss Gas Trimmer
Have a grass hog that has two lines in the spool. How do I restring the spool
wind in direction of arrow on spool. Use 2 separate pieces. 1 at top and 1 at bottom. Feed 1 through each opening in hub when done.
Apr 10, 2010 | Black & Decker 14" Grass Hog Xp...
I NEED HELP TO RESTRING THE TRIMMER PLEASE,THE CRAFTSMAN 74534
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Jun 16, 2009 | Craftsman Garden
Remove head to restring
you need to locate the black knob at the trimmer head and turn it coun ter clockwise and remove it to access your string spool you may have to chase the knob with pliers because some are more than hand tight
follow arrow on the spool for line winding direction
May 26, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
500 people viewed this question
Top Solo Garden Experts
Jim Parker
Jim Parker
Colin Stickland
Colin Stickland
Are you a Solo Garden Expert? Answer questions, earn points and help others
