Question about Chevrolet Vehicle Parts & Accessories
I have an aftermarket alarm for my Blazer. It is a Silencer 6908a. My old remote is no good and have purchased 2 new ones. I need help programming the new keypads so I am able to use my alarm. They didn't come with any instructions.
3 Suggested Answers
SOURCE: Free programming instructions for Prestige remote
YOU can call prestige tech support at 1800 225 5074.. or just put the key in the ignition turn the key all the way to the right without starting the car then flip the vallet switch usually located at the bottom of the dash drivers side, flip the switch on and off three times, you will hear a chirp then you should press the first button on the remote for 2 seconds then flip the swith on and off one more time , then press the second button the remote for 2 seconds then flip the switch again on and off one more time then press the 3rd button on the remote for 2 seconds... After which... remove the key from the ignition and your done... Try the remote to see if it works the way it should if not do it all over again..
MSB....
Posted on Oct 22, 2008
MECP Guy
  • 344 Answers
SOURCE: Someone programmed their remote into my Bulldog 2010
Your model will only keep 4 remotes in memory, so in order to deactivate there remote, you need to have your remote programmed 4 times into your unit
Posted on Jan 28, 2010
I can't get my older garage door remotes to program with the new unit.Do I have to buy new remotes?
SORRY TO SAY.THE ANSWER IS YES.
THE NEW OPENERS ARE NOT ON THE SAME FREQUENCY.
YOU CAN PURCHASE REMOTES THAT WILL WORK WITH BOTH OLD AND NEW OPENERS (DUAL FREQUENCY).
BUT, OLD REMOTES WILL NOT WORK WITH THE NEW OPENERS.
Dec 29, 2014 | Craftsman Sears Liftmaster Garage Door...
I have New Keyless entry remote for my 1998 Toyota camry. FCC ID-ELVAT6B, but do not have programming instruction.
why not read the operators guide in the glove box.
if missing?, get one.
or if really savvy, get the FSM , the factory service manual
get it read it and , bingo its all there, every word.
most cars, you need 1 key or 2 to make a new key, DIY.
that too is covered. , in the FSM.
Dec 12, 2014 | 1998 Toyota Camry
Need to know how to program new ignition switch & cylinder
At you year make and model the factory alarm was just the pellet that disabled starter,the alarm was part of the ignition switch if anything you will need to replace the aftermarket alarm. A repair will cost you more than to replace the unit,You will have to cancel the aftermarket alarm under the dash and restore the ignition wire that is spliced for the alarm relay.
Mar 25, 2012 | Cars & Trucks
How to program a am 7 automate remote 474a
I purchased a automate 474K remote from Autozone and the instructions were to find a single button under the dash and set the new remote to the old settings. There is no single button, as far as I can see. But there is a large 2 x 3" wiring block where the antenae wire plugs into. There are many other wires also plugged into this "Automate" block. But no button.
What do I do ?
Feb 24, 2012 | Televison & Video
I can't shut my alarm for my dodge stratus rt 2002, I don't have a remote control
If it is a factory alarm it can be disabled by locking and unlocking either the trunk or drivers door. if it is an aftermarket alarm (one installed after the car was purchased) you would have to get a new remote and get it programmed or take the car to a mechanic and have it removed
good luck
Jun 04, 2011 | Dodge Stratus Cars & Trucks
Will not start. Battery good all lights come on starter will not engage no clicking at all
if you have aftermarket alarm/keyless entry/remote start try hitting the unlock button on the remote twice when trying to start may need to replace starter
Feb 19, 2011 | 2001 Chevrolet Blazer
I need to program my transmitter to work with the db dlm-3 for a 2003 suburban. The transmitter is also operating a silencer alarm model 6918a. It is a silencer 4 button transmitter
the db-dlm3 is a module to make your door locks work with any alarm. the transmitter is not programed to the module but to the alarm if you need to program transmitter turn key to on position push valet 5 times then hit lock button on remote
Dec 10, 2009 | DB-DLM-3 Door Lock Module
REMOTE DOOR LOCK 1997 ES 300 LEXUS
Even if the remote is fairly new they can lose their programming you may have to have it re-programed
Mar 17, 2009 | 1997 Lexus ES 300
Trying to replace the remotes for my car alarm
it is possible, you need to find an audiovox retailer first. then you MUST know the model number of your specific alarm. then retailer or installer can find you new compatible remotes, but you or them will have to find manual for your model to get your alarm"brain" to properly "learn" the new remotes. it is always a very specific procedure, not universal to all alarms.
Jan 14, 2009 | Audiovox Vehicle Parts & Accessories
Vehicle Parts & Accessories Logo
100 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
