Question about KitchenAid Dishwashers
Clean light is blinking. Is this a problem I can fix on my own? The book says the dishwasher is malfunctioning..Call for service to check heater circuit.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 07, 2010
Clean light blinking
If the clean light blinks four times and then pauses and then blinks four times again and repeats, the problem is your pump motor. If there is water under the DW the pump clamp has probably failed and sprayed water onto and inside the motor. Call a certified Kitchen Aid repair service.
Aug 13, 2014 | KitchenAid Dishwashers
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
The clean light is blinking and it wont turn on
There is a malfunction and it is recommended to call for repair, tell them what is happening the manual suggests to call for service to check heater circuit. I am sorry if this is not much help.
Jan 02, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
Green light on control panel constenly blinks
This condition can also apply to a dishwasher that has had the electronic control replaced.
A heater fault detection program has been added to the
electronic control to check for temperature rise and shut
down the dishwasher if a temperature rise is not detected.
The cycles have been modified to add 8 minutes 45
seconds of fixed heat at the beginning of the main wash.
If the temperature rise is less than the criteria, then
the unit will drain and blink the clean light 7 times. The
detection will be ignored if the temperature is out of its
normal range, 64° - 160° F, or the door is opened during
the fixed heat.
Once a heater fault is detected and the condition resolved
the electronic control must be reset by initiating a service
diagnostic cycle.
Sep 17, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Blinking Clean light in Whirpool dishwasher
Control is programmed to stop running and not allow any further cycles if it detects a water heating problem (no temperature increase detected in heated Main Wash on 3 consecutive cycles). Control blinks the Clean LED 7 times repeatedly and disables the Start/Resume key until cleared. Running Diagnostics clears the control and allows it to operate again. The water heating problem must be fixed or the control will stop running again. See potential causes below. Heater circuit problem: ■ Open in heater. ■ Open connection or component in heater circuit. ■ Faulty heater drive circuit on control. 1. Check operation of heater in Diagnostics cycle. 2. Unplug dishwasher or disconnect power. 3. Check resistance of heater and all components and connections in the water heating circuit or heat dry circuit.
dont forget to vote hope this helps thank you
Jun 20, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Blinking clean light
if the unit is brand new,i suggest you should avail the warranty package that comes with your unit.
May 28, 2009 | Dishwashers
Kenmore dishwasher Troubleshooting
Watch the light closely. If it blinks 7 times then pauses, this indicates a heater or door latch issue.
  • Press the following buttons in sequence: Hi Temp Wash, Heated Dry, Hi Temp Wash, Heated Dry, Hi Temp Wash.If this doesn't work, check the tech sheet. (should be stuck to inside of the bottom toe panel)
  • All lights should illuminate then a diagnostic sequence will start.
  • Listen carefully, as soon as you hear the water begin to fill, open the door and feel the heater. if cold, check the heater for continuity (should be around 10ohms)
  • Also, bend the door catch on the dishwasher tub downward, this will engage the door latch better. Don't bend too far as it will hit the door while closing.
Jun 23, 2008 | Kenmore Dishwashers
Press the following buttons in sequence: Hi Temp Wash, Heated Dry, Hi Temp Wash, Heated Dry.
Jun 15, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore 16039 - "Clean" light is flashing & dishwasher won't start
Jun 15, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Whirlpool GU2548 green light flashing, nothing working
I have had the same problem with my the same dishwasher. The manual says that "the dishwasher has malfunctioned. Call service to check heater element". I called service and they are saying that replacing the heater element and possibly the electronic panel may be required. Total cost (part + labor) = $350-400!! I am very very upset with Whirlpool right now.
Jun 11, 2007 | Whirlpool 24 in. GU2548XTP Built-in...
Dishwashers Logo
180 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
