Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Wont pump water - Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
  • 4 Answers
Take the water tank off, you should see 2 spraying nozzles. You need to get to these and clear them out with a needle or something. Did the trick for me.
Or could be the pump itself. Confirm this using the hand tool - if it sprays water then the pump is fine.
Posted on Sep 07, 2010
My oreck steemer carpet cleaner xls465q wont dispense water or shampoo
You seem to have a clog in your pump. It is possible that left over soap and minerals from your water have brought your machine to a stop. I would go into the pump it self , and clean out any obstructions, then check all your feed lines for the same. I believe that going into your pump and cleaning inside will solve your problem. Take your time. GOOD LUCK FRIEND.
Jan 10, 2015 | Oreck Vacuums
My PowerSteamer PowerBrush Deep Cleaner 1694-W wont spray water
Well what I had to do was replace the pump motor you will have to take it apart and look to see if it has ant rust then look at the pump witch it is a white canister looking thing see if it ceased up and then use 3n1 oil or wd40 on it and work with it tell it is free spinning! Then it will work
May 03, 2014 | Bissell Carpet Cleaner Powerbrush Deep...
Aqua mate II wont spray water
It is always best to run hot clean water through the wash cycle to flush out all soap when finished. This helps to prevent soap from drying in the lines and pump. You can also try this to help free a pump that is not working correctly.
Our tech. team is available if needed... Contact Us
RainVac
May 02, 2014 | Rainbow E series Canister Wet/Dry Vacuum
My shark vac and steam wont pump water to steam
Likely you have used tap water and there is now mineral deposits blocking the flow. I posted a video on how to take it apart to clean it.
www.youtube.com/watch?v=S4NglGXVv50
ALternatively, people have had success in putting CLR into the tank or Vinegar and pumping the unit and leaving it overnight in attempt to clear the blockage that way. I gave up and just took it apart and found a significant amount of mineral deposits blocking things up.
Jan 10, 2013 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My Bissell proheat wont vaccum up the water when cleaning the carpet
1) see if therea are water with the properly mixing
2) lint trap clogged repair
3) pump is prime, test it
4) pump belt worn, replace
God bless you
Jul 06, 2012 | Bissell 8910 ProHeat Clear View Upright...
Cleaner wont release or **** up water off the floor
There are a few different problems this could be. Usually when someone says it won't extract water off the floor it is because it is not squirting any water. If it is not doing either then you have more than one problem. You can try to pour some water from a cup onto the floor to see if it is extracting water from the carpet. water not squirting could be clogged jets. Look underneath at the red jets and make sure they're not covered with hair or dirt. You can remove and clean them. It could be the pump is not working properly. On some Bissel units the pump has a cogged belt that turns the brushroll. If sometihing gets caught in the brushroll it can strip the teeth off of the pulley on the end of the pump which means you have to buy a whole new pump. Another problem I occasionally see on this unit is the pump gets full of soap suds and will not pump water. Sometimes I can get it working agian by removing the lines and flushing out all the suds.
Jul 18, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Why wont my hoover 2320LAUS washing machine drain water
Sounds like the water pump is not running either from power lack or defective pump motor.
Nov 15, 2009 | Hoover My Dad Can Arrest Your Dad Kids...
I have a bissell pro heat water wont come out
The pump may spin but the vanes inside could be broken or worn enough that they are unable to push water through the pump system. I am repairing a Bissell Model 8920 Pro-Heat 2X that has this very same problem.
I tested all the hoses to verify that they were not plugged. I then hooked the water and cleaner tub from the rear directly to the pump and held it above the pump assembly and water barely went through it with gravity feed and the pump was visibly spinning. The pump assembly can be acquired from AE Carters for $10.00.
I do not give any guarantee that this is the only problem.
Ron Goodrich
May 16, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissel proheat no water will dispense
Check all your hoses and make sure that they are not blocked and everything can run freely through your sstem
Apr 25, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water wont dispense from bissell carpet cleaner
Ensure you have water in tank and solution (or water in solution tank). When you start the vacuum up, the pump starts to prime itself. If you have air in the system, it takes a little longer to prime. Allow the vacuum to run for 1 minute before attempting to pull the trigger. Then pull the trigger.
If this doesn't work, you'll need to open the unit up and check the hoses for any clogs, and next test the pump to see if it is functioning.
Dec 22, 2008 | Bissell 9200 Upright Vacuum
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
121 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
