Question about Samsung HT-A100T Theater System
What to do if my SAMSUNG HTA100 always displays region error
I need the region code and process to unlock my samsung DVD P490 player
  1. Power on your player with no disc in the tray
  2. Press REPEAT for 5 seconds
  3. Enter the corresponding combination for your current RC (see top of the page)
  4. Current RC should be displayed
  5. Press the button for the desired RC (9=multi-region)
  6. (Press OPEN)
  7. Power off your player
Mar 27, 2011 | Samsung DVD-P190 DVD Player
Tip
Samsung BD-1600 region free code
I used it on my brand new Samsung BD-1600 today and it
worked on the first try using the code below.
My unit is a Region 2 (UK) machine.
1) Press the POWER button on the remote to turn on the
machine (no disc in the tray).
2) Wait till the player has booted up and the Samsung logo
screen is displayed.
3) Press the OPEN/CLOSE button on the remote twice, to open
then close the disc tray.
4) As soon as you see "No-Disc" displayed in the top left
corner, press the REPEAT button followed by the 5 digit code
for your current region as listed below.
(Mine was 57538 for region 2)
Don't press the REPEAT button for too long, just smoothly
press REPEAT 5 7 5 3 8.
If it doesn't work straight away, keep trying, mine worked
on the first go.
5) If you're successful, your current region code will be
displayed in the top left corner of the screen.
6) Press '9' to make your player region free.
7) Turn the player off, then on again and test with a
different region disc, or if you don't have one to test
with, just repeat the hack and instead of your old region
code appearing in the top left corner of your screen, you
should see '9' if you've been successful.
The hack can be repeated to turn your machine back to it's
original settings or to a particular region if the disc is
sensative to region free machines.
Region Codes
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
on Mar 07, 2010 | Televison & Video
I have a samsung HT-Z120 it show a PROT error
This error means that you are trying to play a region-protected disc that is not in the same region as your player.
It is possible to "hack" the region on your DVD player by following these instructions:
http://www.videohelp.com/dvdhacks/samsung-ht-z120/10244
Please rate my answer.
Thanks,
Chris
Mar 05, 2011 | Samsung HTP-1200 System
Code for unlocking dvd regions samsung r155
hi,
1.Turn on R155 without disc inserted
2. Press and hold Play and Stop for 5 seconds then release
3. Press menu
4. enter code for current region as above i.e if you have a region 4 type: 7, 6, 8, 8, 4
5. The region is displayed in the top right.
6. You have about 5 seconds to enter the new region (1,2,3,4,5,6 or 9 for multiregional)
Region codes for Samsung:
RC 1: 2, 9, 3, 3, 4
RC 2: 3, 8, 7, 6, 7 (or 5, 7, 5, 3, 8)
RC 3: 5, 6, 7, 3, 2
RC 4: 7, 6, 8, 8, 4
RC 5: 5, 3, 8, 1, 4
RC 6: 2, 4, 4, 6, 2
Thank u
Oct 07, 2009 | Samsung DVD-R155
I want to unlock the region on my samsung bdp 1600 blu ray player
Not sure of this works on the very latest models but here it is :-
on the first go.
Region Codes
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Sep 25, 2009 | Samsung BD-P1600 Blu-ray Disc Player
Samsung dvd htx200 region error
no solution but i have exactly the same problem - the system has suddenly stopped playing any dvds at all including ones it has previously played - i get no sound or picture just a circle with a + sign in the middle on the dvd digital display
did you find any solutions elsewhere?
Aug 28, 2009 | Samsung Televison & Video
How to solve region code display by samsung home theater
if you bought unit in usa it is fixed in region 1 not changeable.
Jun 04, 2009 | Samsung HT-TZ312 Theater System
Samsung P480 dvd player- To Play all region dvds
how can I play *.mp4 files in samsung dvd player model no P480?
Mar 11, 2009 | Televison & Video
Region Error
please try if this helps:
1. Remove disc from tray.
2. Switch off player and unplug from mains.
3. Wait 30 seconds, then reconnect mains.
4. Turn on player with remote. Wait for player to finish loading and display 'no disc'.
5. Press enter on remote. (There will be no on-screen response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be no on-screen response.)
7. Press enter on the remote. Player will automatically shut off.
8. Turn player on.
9. turn off.
10. Turn player off then on again.
11. Player is now region-free.
Nov 02, 2008 | Samsung HT-X250T Theater System
Need setting to change regional code on samsung DVD P172
This works to change region code 5.
This is how it works.
1)Power on player.
2)Ensure that there is no DVD inside the player.
3)The tray should be closed.
4)Press "Subtitle" on the remote control.
5)Press 53814 for region 5 (For other regions see any of the other cracks)
6)The region code 5 will be displayed on the left top corner of your screen.
7)Now press 9. A 9 will be displayed on the top left corner of the screen.
8)Press Subtitle on the remote again
9)Power off the player.
10)Power it on again and you are region independent!!
Worked for me.
Mar 13, 2008 | Samsung DVD-HD870 DVD Player
Samsung HT-A100T Theater System Logo
94 people viewed this question
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
