The machine starts to fill up then stops and the door light starts to flash, but it does drain and let me get the clothes out.
    Genius:
  • 1,073 Answers
What is the model of the washer
Posted on May 13, 2008
My maytag washer does not spin fast enough to get the water out of the clothes. Please advise
Randall, the high speed spin failure can be caused by a number of issues. I would suggest starting the machine without any clothes in it. Once it has filled, make sure the door lock light is on and that the door is, in fact, locked. If the light is not on, or if the door is not actually locked, either the door lock assembly or the control panel is at fault.
If the light is on and the door is locked, stop the wash cycle and start a drain and spin cycle to see if all of the water is pumped out of the drum. All water should be pumped out within 10-15 seconds. If excess water is in the drum, the high speed spin will not start.
Mar 06, 2015 | Maytag Washing Machines
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Sep 08, 2014 | Zanussi Washing Machines
Whirlpool duet washer fills with water (maybe overfills) then stops and the wash light flashes an 8 then 1 type sequence
Hello, we are sorry to hear that you are experiencing this problem. We would recommend having a certified technician out to take a look at the Washer and give the appliance a proper diagnosis. If you would like further assistance you can send your name, phone number, address, model/serial number and the date of which you purchased the Washer to Whirlpool_Reviews@Whirlpool.com.
Apr 18, 2017 | Whirlpool duet Washing Machines
KENMORE ELITE WITH CATALYST FILLED WITH WATER AND WILL NOT DRAIN AND SPIN
REPLACE THE DOOR SWITCH . IF THAT DOES NOT WORK REPLACE OR CLEAN THE DRAIN PUMP..
Apr 25, 2017 | Kenmore Washing Machines
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
When started, pump functions to drain, but, does not stop and start to fill--after a period of this, the door stays locked with all lights flashing. Essentially, the machine does not cycle correctly.
ok, sounds like you should be seeing an error code flashing in the display with the lights. this will be an F followed by a number. or letter abbrev. like dL
With the pump starting with a new cycle started and draining but you get this light sequence (error) I believe the problem would be that it is seeing water in the tub and not seeing it leave, like a pressure sw problem.
Apr 26, 2009 | Kenmore HE2 Plus Front Load Washer
The machine fills and drains on wash cycle but willnot spin
C1. Your motor was stopped due to overloading, inbuilt device, reduce weight of clothes (put less clothes). Press 'stop' & 'cancel' to clear the display.
How abt a good rating? Thanks
Mar 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
HOTPOINT WASHER DRYER WD440G
That means that the machine detected a problem at a certain point of the cycle and stopped.
If the machine stops when filling check the inlet valve and the water supply.
If it stops because ofervilling check the water level switch.
If it stops when the cycle is hot water only , then check the heating element.
If it stops when draining, then inspect drain filter, drain pump , and drain hose. You access the drain hose removing a panel at the front side of the machine.
If it stops when motor is supposed to spin faster (rinse) then it is motor control unit or motor coupler.
If it is none of the above, then it is a defective control board.
Feb 16, 2009 | Hotpoint Ariston WD440G Front Load...
I have a WF220, 1200 spin washing machine (3.5 years old and very little use) which does not complete the washing cycle. Each light comes on as the programme progresses until all the lights are lit...
You may find that the internal filter is blocked & that by stopping and starting the machine you are giving it extra time to complete the drain cycle. The filter is located at the bottom rear of the machine & is secured by a large hose clip to the bottom of the drum. Try filling the washer with no clothes in & then switching to the drain programme to see if the water drains properly
Nov 03, 2008 | Washing Machines
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
