Kenmore elite 110.24982300 washes cloths - drains - does not always spin dry agitator does not spin always if we rock machine then spin cycle starts is it clutch - motor coupler?
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite Model 110 washing machine will not stope the agitate cycle
If the washer fills but does not agitate or spin, this is usually a symptom of a bad lid switch. The switch will either be located on the right hand side of the washer tub opening, or in the rear on the left hand side under the console. If you have a right hand model, examine the lid and make sure the plunger that activates the switch when it is closed is still intact. The plunger is a plastic piece that is physically mounted on the lid. Sometimes they break off. If the plunger is intact, try taking a small object (like a screwdriver or popsicle stick and push down on the lid switch contact while the lid is open and the timer knob started. You should hear a distinctive "click" when you push on the switch and the washer will agitate. Sometimes the switch can become loose and no longer make good contact. If this is the case, simply tighten the two mounting screws on the tub opening. If the switch relay is not clicking you may need to replace it. The part runs about $35.
If you have the left hand style switch that is enclosed under the console, the contacts are closed by a small metal bar on the back of the lid. Sometimes this bar becomes bent or loose. Open and close the lid and listen for a distinctive "click". If you don't hear anything, you may need to adjust the metal bar, or replace the switch. This style of switch tends to cost a bit more.
If you can provide me with your model number (located under the wash lid along the tub opening), I can research the part number for you and let you know where you can get it and give you step-by-step instructions on how to replace it. This is a simple repair job that the average consumer can perform with simple instructions and a few household tools. First, determine if this is the cause of your problem. Post back with comments and let me know if this helps you.
Posted on Nov 24, 2007
  • 62 Answers
SOURCE: My Kenmore Elite Model 110 23032102 sometimes will not wring the clothes dry
Before you do anything else...have you fully checked the pump system...thats starting at the pump to the termination of the drain hose. Coins and objects can cause partcial blockage which can cause the symptoms you described. Let me know how you get on.
Posted on Jan 03, 2008
jumptrout51
  • 3361 Answers
SOURCE: Kenmore Washer 90 Series Super Capacity will not agitate or spin.
http://appliancejunk.com/forums/index.php?topic=3437.0
Yes, you have a direct drive coupling problem. Use this video to replace your part.
EZPZ.
Posted on Aug 13, 2009
Testimonial: "Thank You! The diagnosis confirmation and repair video helped. There were some differences between my Washer and the repair video, but figured it out"
  • 1937 Answers
SOURCE: My Kenmore elite model # 110 washing machine will
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission. It's used as a fail safe device and consists of three parts. Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning. It will also make a noise as the plastic prongs hit each other.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Oct 18, 2009
Testimonial: "I now have a place to start. I had not a clue where to begin. Thank you"
  • 127 Answers
SOURCE: Direct Drive Kenmore Washing Machine will not spin
its possible the ears on the top of the drive tube have worn alowing the basket drive block to slip and not turn the clothes basket with authority, or the basket drive block has just worn from overloading and needs replacing.. is easy to verify by looking..
best of luck,
ttfn
Posted on Oct 25, 2009
Kenmore Elite Mod # 110-26962500 goes thru all cycles perfectly. Recently there is always soap left in the clothes even after 5 or 6 rinses. How to find the problem.
dose the drum actually turn & spin? if not then most likely the machine's clutch is worn or broken...go to you tube for repair video.
Jan 11, 2018 | Kenmore Washing Machines
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite H3E Washer Drain/Spin Problem
hi
it is the belt problem
check it///thank u
please rate it
Jul 04, 2009 | Washing Machines
Washer will not turn on...
My washer makes a wierd clinky sound during wash and rinse cycle and it has began to stop spinning the water will drain but clothes will be soaked. Also sometimes during spin cycle it will agitate instead of spinning
Jun 22, 2009 | Kenmore Elite 45986 Front Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore elite front loading machine
Even replacing pump is not always the answer,in fact most of the pumps are replaced when they are just clogged.Dont waist any more money.Did the servicer check inside the hoses.In the drain cycle can you here a pump running>?
Jun 08, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore front load wet clothes
Before going further it is important to determine if the machine is reaching full spin. Make sure the unit is set to MAX extract and watch the inner tub. The tub should be spin really fast (1000 rpm's or better) during the final spin. If not you have lost one of the phases on the motor.
Jan 08, 2008 | Kenmore Elite 45986 Front Load Washer
Open Questions:
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
