Question about Electric Earthwise Corded Lawn Mower 20in. Deck
My lawnmower is just 4 months old it stopped working and it smokes
My electric lawnmower sometimes does not start, just humms. Then I TURN IT OVER, AND TURN THE BLADE A LITTLE BIT. the blade feels hard at first but soon feels loose. then it wil start as normal
The lawnmowers electric motor has a bad spot on the armature. You need to replace the electrical brushes that contact the motor. If you are lucky you may just need to clean them and reinsert them in to brush holders.
Nov 25, 2013 | Electric Lawn Mower
Model 917.370410 won't start
Sounds to me like this model is a POS. I also have this same model, purchased last August have used only 5 or 6 times , has the same symptoms: hard pull, puff of smoke, won't run , etc. Even brought this to an authorized dealer to get it to run, but then it only ran a couple more times, dead again. Does anyone know of any recalls fro this lemon? I can appreciate everyone troubleshooting , but you shouldn't have to tear apart a 5 month old lawnmower which will only result in your warranty being voided.
Oct 04, 2012 | Craftsman 675 Torque 190cc 21" Briggs ...
I have a 4 month old mcculloch with a briggs and stratton 450c engine , it starts no probs but then starts to blow out black smoke
Hi, check your air filter, also check your oil level is not over full as it may have become diluted with fuel. Let me know. Regards Phil.
Aug 30, 2012 | Briggs & Stratton Briggs Stratton...
Champion 35 lawnmower hunts
Clean the air filter (foam type) in warm soap water then apply some oil soaked in, it will smoke afterwards for a short time. Or possible minor adjustment too the mixture screw on the side of the carburetor spring loaded. Allan
May 09, 2012 | Garden
I tried to mow the grass even though it rained this am. our grass was really high and i saw a little smoke come out of the lawnmower. is that because the grass was still a little wet or the grass was...
Nope. If the grass is too high, knock it down to size with a weedeater first. These electric mowers cannot handle the tall, high stuff. If you do, you will surely burn it up.
Aug 14, 2011 | Black & Decker 18", 6.5a Electric Mower
Have a victa lawnmower 4 stroke engine when i started it recently it spits out oil and overheats pretty quickly its only 6 months old. checked oil it was full but i tried to turn it on again the same...
Check that the oil level is not too high, further than that do not do anything. As far as I can remember, Victas have a one year guarantee. Rather than try to repair it or look into it, call the dealer or take it back to him as you will invalidate your warranty if you do anything to the unit, and that is not worth it. Let the dealer worry about it.
Apr 07, 2011 | Garden
Electric Lawnmower stopped working.
You were NO help at all. I asked for a location to have an electric lawnmower repaired in my area. You gave me a source 2500 miles away. Obviously I cannot count on assistance through this site. What happened to REAL PEOPLE who can offer some intelligent reply? If I could repair a lawnmower, why would I need to ask you?
Dec 02, 2009 | Black & Decker Garden
Lawnmower is spewing white smoke
white smoke means that there is water in the fuel air mixture during combustion. a bluish white smoke means oil is being burned during combustion. take another look and make sure which one it is. since all mowers ive seen are air cooled the only way water can be getting in the fuel air mixture is through the gas cap. check your gas tank and gas can for water. may be best to empty both and start over with fresh fuel
Jun 09, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Car dies if accelerator is not engaged
the starting problem could be head gasket if it got really hot..... black smoke wouldn't be oil, and gas would stink but not black smoke if it's old, it wouldn't really matter if it had been sitting for 4 months. black smoke is probably caused by a gas mixture problem, or maybe a stuck fuel injector.
Feb 20, 2009 | 1990 Ford Taurus
Electric Earthwise Corded  Lawn Mower 20in. Deck Logo
Top Electric Garden Experts
Steve Oakes
dannydoesita
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
