Question about Whirlpool Duet GHW9150P Front Load Washer
My gwh9150p whirlpool fills with water when turned off
  • 15,935 Answers
It appears your dual inlet water valve has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
My Whirlpool Ultimate Care II Washer doesn't stop filling with water
If this only happens when the machine is turned on,the tube from the tub to the water level switch is pinched or broken. If the clear plastic tube is not pinched or broken,the water level switch in the control console is bad. If the machine lets water through when it is in the OFF position,the water valve where the hoses connect are bad.
Dec 27, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Turned on whirlpool duet washer, came back to FH as realized forgot to turn water on. Have tried all the suggestions, but each time I plug the machine it tries to drain water and the motor hums. I cannot...
Make sure both hot and cold water supplies are turned on. Select a cold wash cycle and start the wash cycle, do you get cold water? Now select a hot wash cycle and start the wash cycle, do you get hot water? If you only get cold water replace the hot water fill valve. If you only get hot water replace the cold water fill valve. If you get neither replace both fill valves.
Jun 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washing machine (WTW5200SQ0) temp problem
I turn off the cold water during the fill up, and then turn it back on after it has filled. I hate this washer too because of that.
Jan 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My Whirlpool front load washer keeps filling with water when off.
turn off water supply taps when not using machine
Dec 21, 2009 | Kitchen Ranges
Washer will not turn on
You have some scale or something keeping the water fill valve open most likely. If it still tries to fill unplug the machine if it still tries to fill do the following. Remove the fill valve and disassemble it. If you see the dirt or rust flush it out when it looks clean reassemble it and before you attach the hoses put them in the washer and turn them on to flush out the lines then reattach hoses and try it.
If this helps you please rate me with as high a retign as possible. If not please restate your problem and help me understand better what trouble your having. Thnks for using fixya and good luck.
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dishwasher wont fill
I fit won't fill then apparently you're not getting any water to it, which means it not's fixed. Did you turn the service valve back on since the repairs were made? Sometime when you turn a service valve off they fail to re-open. Crack the inlet water line and verify that you have incoming water.
Jan 18, 2009 | Whirlpool 24 in. DU1050SS Built-in...
Whirlpool washer continuouse water water runninng into tub
try turning the mach off while it is spinning and filling.if it continues to fill or drip heavy,the mixing valve is not closing completely and needs to be replaced.if the water stops when the mach is turned off,there is a problem with the pressure switch.
Sep 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Duet GHW9150P Front Load Washer Logo
Sal De
Gerry Harvey
Gerry Harvey
