Question about Maestro Lutron Dimmer 600 Watts Ma-600-wh
I've had several MA-600 tap panels that stopped working, causing me to replace the unit. Is this a common failure mode ? Are there more robust models available for multi-control dimming ?
    Novelist:
  • 107 Answers
It would be helpful if you clarified what "stopped working" means. Regardless, their tech support center at 1-800-523-9466 can help you figure out why its happening, is available 24/7, and will more than likely replace the units for you.
Posted on Oct 18, 2010
TMA 8006Model T315xw03V3 Unit keeps turning off
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 11, 2015 | Televison & Video
I think its on stand by mode I have power lights but no picture the TV was gave to me no manual
- Flickering screen
- Dim screen
- Slow start
Mar 06, 2015 | Hitachi Televison & Video
My 42 inch tv when it turns on half is black then color lines show up and down then I'll just tap it slow on top and picture comes on like something is loose inside some times it doesn't work
- Flickering screen
- Dim screen
- Slow start
Feb 04, 2015 | Televison & Video
Tv power button lights up then go's off
Hey Craig,
I've seen this common problem in several models of flat panel TV's, especially 4 to 5 year old Walmart Black Friday specials. The capacitors in the power supply dry out and fail, causing the power supply to fail. When you try to turn the TV on, the power supply refuses to start and the unit shuts off. This problem that the local (in Phoenix) Fry's Electronics sells a power supply capacitor replacement kit for several models of flat panels. If you are compelled to check it out, the units are typically easy to disassemble, and the power supply PCB (printed circuit board) is normally well marked.The caps are blue and/or yellow cylinders, mounted on end. Defective ones, in this use dry out, overheat, and swell up, causing the top to noticeably bulge out. Without knowing more details I would suggest that this is a most likely failure for your TV. Thanks for using fixya. I hope it helps. Dan
Nov 28, 2014 | Televison & Video
When Im driving my car it stops then I have to turn the car off put it in park then restart the car again
If several repair shops have not gotten close to finding
something
We can not guess over the internet,sorry
It is a very old car & wiring corrodes etc
$600 is not a lot to spend, diagnosing something
like that
$600 spent at several shops total, is a waste of
resources & the car is only worth that much
Sep 05, 2012 | Mazda Cars & Trucks
Vertical lines no picture
Unfortunately this usually involves a digital failure in the array that drives the display - they're not normally repairable. if it responds to a "tap" it could indicate a poor cable connection within the screen that could be repairable, but it's usually a component failure. I've seen several recently where the manufacturer's warranty solution was a credit towards a new one.
Jul 14, 2012 | Televison & Video
Could Rear end damage from a wreck cause my speedometer and gas gauges to stop working?
You must understand that collision stresses the ENTIRE vehicle. Just because it was hit from behind, does not mean that there is not collision damage in the front. I had a vehicle in my shop several years ago that was hit from the rear. The engine began knocking shortly after. It turned out that the collision had jarred the engine hard enough to cause the crankshaft to crack. This type of damage is extremely rare, but can happen. Trying to convince the insurance company that this was collision damage was a real trick.... On the other hand, fuel sending unit failures are quite common (without any collision) and can cause your fuel gauge to stop working.
The only way to determine if your problems are caused by the collision would be to first diagnose the problem. Only then can it be determined if the current failure is caused by collision or possibly caused by a more commonly known failure type.
Dec 15, 2011 | 2009 Chevrolet Malibu
I am trying to install two Lutron dimmers in the same box. The dimmers are models MA-S8AM-WH and MA-600WH. I can get get the MA-600-WH to work but not the MA-S8AM-WH. Anyone have any hints.
My first thought is that if you were using these devices to replace existing light switches, the MA-S8AM has an additional electrical connection that wasn't necessary with a light switch or the MA-600. The MA-S8AM has an addtional screw on it (I think its silver in color) that connects to the neutral wire in the circuit. Hopefully you have a bunch of white wires all wire-nutted together in the back of the box - pull a connection from there and attach.
If that's not the issue, then I would call Lutron's tech support. They're available 24/7, so you may as well. They're at 1-800-523-9466.
Aug 25, 2010 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
I purchased a replacement MA 600 3 way dimmer. The old ones had wires, this one screws. Can you tell me how they map?
http://lutron.com/CMS400/page.aspx?id=16977
The black screw is the common (either power or switch leg depending on which side of the 3-way you are working with), the brass screw is one traveler and the blue screw is a low voltage communication lead (second traveler). I have attached a link to Lutron's wiring diagram pages, just select your dimmer.
Nov 29, 2009 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
Stop button problem
This was a common failure with this model and requires replacement of the control block assemble. This is an assembly with several functions tied together in one preformed unit with a flexible cable arrangement. This ordinarily is a pro repair situation. They have an upgraded part for this. Could be a bit pricey however. Good luck, magic seadog
May 28, 2007 | JVC GR-DVP1 Mini DV Digital Camcorder
Maestro Lutron  Dimmer 600 Watts Ma-600-wh Logo
165 people viewed this question
Top Maestro Electrical Supplies Experts
jdthefixer
ken skalski
Are you a Maestro Electrical Supply Expert? Answer questions, earn points and help others
