Magic Chef CER3725AA Electric Kitchen Range Logo
Posted on Sep 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I use the self cleaning on my Magic Chef conventional oven
Anonymous
Level 3:
  • Magic Chef Master 43,501 Answers
  • Posted on Sep 07, 2010
Anonymous
Magic Chef Master
Level 3:
Answers
43501
Questions
0
Helped
10835100
Points
101584
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Her do I find the model number on my magic chef electric oven. Red light is on staying on? Burners and ovens are all off, What's or how do I find out what's wrong?
Possible locations shown in article at the web link below:
https://www.hunker.com/13409112/how-to-find-a-model-number-on-a-magic-chef-oven
How to Find Model Number on Magic Chef Oven Hunker
Quoting the link above:
Step 1 Open the oven door. At the top, left-hand corner of the open oven, locate the model number tag.
Step 2 Check under the burners. Lift each burner on the stove off to see if the plate is underneath. Do this if the plate is not located on the inside of the oven.
Magic chef self cleaning stove showing code f2
Hay wendy , tech sheet says to replace oven temperature sensor , ( make sure the fans are running properly ,good luck APPLIANCES R EN
How to use a self clean magic chef oven bought 24 years ago
Self Clean Magic Chef Ovens, clean by Nuking the baked on grime etc... As I recall, invoking the self clean (some models will allow you to specify a time - 2 hours for light cleaning to 4 hours for heavy), will ramp the oven temperature up to as high as 900 degrees F (as opposed to the mid 300 norm). YOu probably want to remove any racks etc before hand, and wipe up crumbs etc...
Once completed, and cooled, wipe out the ash that is left over, witha damp cloth.
I pressed self clean on magic chef ceramic range oven and get a dr code.
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Magic chef gas oven range 6498xvs oven no longer works.
i have a magic chef gas range. broiler work, burners work, fan works when you turn the oven on, but oven does not get hot. could it be the electronic ignitor or does even have one.
May 20, 2009 • Ovens
4helpful
SELF CLEANING MAGIC CHEF OVEN BOUGHT 24 YRS AGO
That's fairly typical but I would suggest removing the shelves and cleaning those with oven cleaner if they need it at all. Expect the door to remain locked for additional hours for safety.
The temperature rises to > 900 degrees F and is necessary to start the catalytic process that consumes the crud.
Sorry I didn't see your message earlier-
3answers
Missing my manual
I suggest you read this link before you use the self clean cycle. http://www.fixya.com/support/t241114-oven_will_not_heat#SameProblemContinued
I used mine for the first time two days ago on model KEBC147 and it will not heat now.
You might not want to try self-clean unless you have time to call for repair afterwards before
using your oven again.
Very disappointed in KitchenAid in Texas ...
DBN
1helpful
Broken glass top on Magic Chef range
all i want to know is how to turn on the self cleaning oven to clean it. i can't remember and i can't find the book
1helpful
Magic chef range
if you give me a model number i be might be able to help try here get your model number off the serial plate from the range http://www.maytag.com/support/manuals_literature.jsp if that dont work reply to this thread with model number
Top Magic Chef Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
