Question about Ricoh Aficio GX3050 GelSprinter
GX5050N. Printer turns on. Then 5 seconds later, green light flashes and printer turns off.
I am trying to solve this problem right now. Ricoh says it is mostlikely a short in the print head which unfortunately means trash the printer. If your printer has a full ink collector you can reset it. go to www.conde.com and look at tech tips it is very simple.
Posted on Sep 24, 2010
P1102 reser counter
  • I take it you are refilling the toner cartridge...
  • Switch the printer off.
  • Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
  • Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
  • Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
  • Open and close the lid of HP printer once. The light will start blinking.
  • Press the green button. Your HP toner cartridge chip will be reset.
  • Apr 25, 2014 | HEWLETT-PACKARD Hewlett Packard P1102...
    Is not working more
    Jan 29, 2013 | HP DeskJet F4280 All In One Printer InkJet
    My epson tx700 printer dispaly ink pad at end of life and printer not start
    A fix from a forum:
    Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
    1. Turn off your printer, ensuring that the print head is at it's home location and locked in place as normal;
    2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
    3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer's power switch was 'on' - switch it off and return to step 1;
    4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
    5. When the paper-out LED flashes, release the buttons;
    6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
    7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
    Procedure 2
    2. Hold down the paper feed button only;
    3. Turn on the printer;
    4. As the paper feed light starts flashing, release the button;
    5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
    6. Allow printer to complete it's processing, then turn off for a few seconds, and back on again for a newly working printer!
    Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
    1. Switch off printer with panel switch;
    2. Switch off printer at mains switch - leave off for 20+ seconds;
    3. Hold down roll feed and sheet feed buttons;
    4. Switch on at mains;
    5. Switch on at printer panel;
    6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
    7. Switch printer off and then, after a few seconds, on again at mains switch;
    8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
    9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
    10. Release the roll feed button and all should be well.
    Apr 25, 2011 | Epson Printer
    Orange light flashes 5 times then green flashes once then repeat Can't get printer to do anything else. Have unpluged it for ten minutes no luck Have removed print head and replaced it, no luck....
    1. Turn off printer
    2. Hold down Resume button and press Power button.
    3. Keep holding down Power button and let Resume button go.
    4. Press Resume button 2 times then let BOTH buttons go.
    5. Green lights will flash and then stop blinking.
    6. When green lights are solid, press the Resume button 4 times.
    7. Press the Power button and the printer should turn off, if not, press the Power button once more.
    8. Your printer should respond as normal.For printer
    Mar 22, 2011 | Canon BubbleJet i560 InkJet Printer
    When i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked...
    when i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked normally after being off for a couple of days, but now it is doing that again.
    Amber light flashes 7 times, then green for a couple of seconds, then amber 7 times etc.
    Jun 02, 2010 | Canon BJ I6500 InkJet Printer
    The printer flashes orange light five times, and green once
    Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
    1. Start with printer OFF
    2. Hold down RESUME and then hold down POWER
    3. Release RESUME
    4. press RESUME twice, then release POWER
    5. let green light blink until printhead has finished moving.
    6. Select functions below with RESUME, execute with POWER
    0 presses - green light - Test Print (exit service for i960)
    1 press - orange light - EEPROM info print
    2 presses - green light - EEPROM initialise
    3 presses - orange light - reset waste ink counter.
    This also applies to the i550, i560, i950, i960
    Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
    Kyocera fS-920KX. Not printing
    There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
    1) Green On, Red Off = Printer Ready.
    2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
    3) Green Fast-Flashing, Red Off = Printer off-line.
    4) Green Slow-Flashing, Red Off = Processing Data.
    5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
    6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
    7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
    8) Green Off, Red Off = Printer power is off.
    9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
    10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
    So what is your printer condition? Better know what is going on your printer so can solve the problem
    YBC (/\)
    Jun 01, 2009 | Kyocera FS-920 Laser Printer
    Epson C66 red light stays on for ink
    The first time you install ink cartridges, the printer must charge its print head for about 90 seconds. Wait until charging finishes (the green power.jpg power light stops flashing) before you turn off the printer, or
    it may charge improperly and use excess ink the next time you turn it on. If the printer stops moving or making noise, but the green power.jpg power light is still flashing after 5 minutes, turn off the printer. If the light is still flashing when you turn it back on, contact Epson.
    Turn off the printer, then make sure the ink cartridges are inserted completely and the ink cartridge cover is closed completely. Also make sure no packing material remains in the printer. Wait a moment, then turn the printer back on to clear the error.
    Nov 13, 2008 | Epson Stylus C66 Photo InkJet Printer
    My canon ip2000 won't reset
    Canon IP 2000 / reset Hi there you can try this.
    1. Turn off printer
    8. Your printer should respond as normal..
    All the Best Pineworks
    Apr 06, 2008 | Canon PIXMA iP2000 InkJet Printer
    Ricoh Aficio GX3050 GelSprinter Logo
    393 people viewed this question
    Top Ricoh Office Equipment & Supplies Experts
    OfficeServiceAjnc
    OfficeServiceAjnc
    fares
    Level 1 Expert
    CheckitRight
    CheckitRight
    Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
