Toshiba Satellite X205-S9349 Notebook Logo
Posted on May 13, 2008
Will not boot up and can,t format - Toshiba Satellite X205-S9349 Notebook
  • Anonymous Jan 30, 2009
    when i turn on my toshiba x205 i get the toshiba leading inovation page the hard drive light flickers a little then it just freezes on the toshiba inovation page.
A
Anonymous
Get it fixed by a professional 4 hours tops
Aluminum foil is congealed on my stove top. Is it worth it or even possible to replace the top.If so where can the model number be found.
Computer Ko Format Kaise Kare? - ????? Laptop Format Karne Ka Tarika ????? ???!
???? ??????? Hindi Sahayta??? ???? ?????? ?? ?? ?? ????Computer Ko Format Kaise Kare?? ???? ??? ??????? ?? ??? ?? ?? Windows 10 Ko Format Kaise Kare ?? ???? ??? ??????? ??? ?????? ?? ?? ???? ????? ????? ???? ??????
???? ?? ??? ??? ????? ????? PC Format Kaise Kare ?? ???? ??? ?? ??????? ?? ???? ??????? ???????? ?? Knownledge ?? ????? ?? ?? ??? ?? ????Computer Format Karne Ka Tarika????? ????? ?? ?? ?? ???? ?? ????? ??? ??? ???? ??? ??????? ?? ???? ??? ????? ????? ?? ????? ?? ????
???????? ??? Virus ???? ?? ???? ???? ?? Problem ??? ???? ?? ???? System Hang ???? ???? ??, ???????? ???? ?? Restart ???? ???? ??, ???????? ?? Speed ?? ?? ????, ????? ???? Pc ?? Data Delete ?? ???? Etc. Problem ?? ???? ?? ?? Problem ?? Solution ?? ??? ??? System ?? Format ???? ????? ?? ???? ???
Contents [ show ]
?? ???? ?? ???? ? ???? ???? ?? ???? ?????? ?? Format ???? ???? ?? ???? ?? ???? Windows Update ?? ??? ?? ?? ???? ??? Drive ?? Format ???? ????? ?? ?? ?? ??? ???? ?? ???? ???
?? ???? ?? ?????? ??? ???? ? ???? ??? ????? ?? ?? Pc Format Kaise Karte Hai ?? ???? ??? ????? ????? ?? ???? ?? ??? ?? ????? ????
?? ??? ??? ???????? ?? ???? ??? ?? ????? ?? ????? ???????? ?? Format ???? ?????? ????? ???? ??? ?? ?? Computer ?? C Drive ?? Directly Format ??? ?? ???? ???? ??? ???? ??? Boot Menue ?? Format ???? ???? ??'
???? ??? ???? ?? Boot Disc ????? ???????? ?? Format ???? ?? ??? ???? ??? Windows Operating System ?? CD (Bootable DVD) ???? ????? ???? ???? ?? ???? ?????? ?? Format ??? ?? ????'
???? ???: Facebook Par Kisi Ko Block Or Unblock Kaise Kare - Facebook ?? ????? ?? ??????? ???? ?? 4 ???? ?????!
???? ??? ???? Windows Operating System ?? File ?? ?????? ???? ??? ???? ??? Windows Operating System ?? File ?? ?? ?? ???? ???? ?? Help ?? ???? System ?? Format ?? ???? ??? ?? ?? ??? ??? Bootable CD/File ??? ?? ?? ?? ??? ??????? ?? Download ?? ???? ???
???? Laptop ?? ???????? ?? Format ???? ?? ???? ???? ???????? ??? Save ??? ?????? Data ?? ???? Pendrive ?? ???? ???? Device ??? ??? ?? ?????? '
??? ?? ?? ???? Data ?? ??? ?? ??? ??? ???? ?? ?? ???? Data Delete ?? ???? ?? ?? ???? ????? ?? ?? Pc Format Kaise Karte Hai ?? ???? ??? ???? ?? ??? Steps ?? Follow ????
Step 1: Boot Key ????? ???
???? ???? ???? ???????? ?? Restart ???? Open ??? ?? Boot Key (F12) ?? Continuously ????? ???? ????
Step 2: Bootable Disc Insert ?? ??
?? ???? ????? ???????? ?? Screen ?? ?? Message Show ???? ?? ???? ???? Boot Device CD/DVD Rom Select ???? ???? CD Rom ?? Select ???? ?? ?? Window 7, 8 ?? Bootable Disc CD Drive ??? Insert ?? ???
Step 3: Press Any Key
???? ?? ?? Cd Rom Select ?????? ?? ???? ???????? ??? ?? Restart ???? ?? ?????? ?? ???? Screen Black ?? ????? ???? ?? ???? Press Any Key To Boot From Cd/Dvd ?? ???? ????? ?? ??? ?? Key ?? Press ???? ???
Step 4: Windows ??????? ???
?? ???? Window10 ( ?? ??? Windows ?? ???? ???????? ?? Format ???? ????? ?? ??? Select ??? ???? ???? ?? Windows 10 Bootable Disc Select ?? ?? ) Disc ??? 2 Minute ?? Read ????'
???? End ???? ?? ??? Installation Window Open ???? ?? ?? Installation Window Button ?? ????? ???? Installation Process ?? ???? ?? ???? ???
Step 5: Install Now ?? ????? ???
Install Now Button ?? Click ???? ?? ???? Windows10 Setup File ?? Copy ????? ???? Window ?? 2 Minute ?? ???? ?????'
???? ???: ATM Kya Hai? ATM Kaise Use Kare? ATM ?? ???? ???? ??????? - ATM ?? ???? ???? ???????!
?? Windows Setup Files ?? ???? ??? ?? Copy ?? ???? ?? ???? ?? ?? Window Open ???? ???? ???? Update Install ???? ?? ??? ?????? ????? ?? Online Update ?? Select ???? Manually Update Select ????
Step 6: Windows Bit Select ???
???? ?? ?? Manually Update ?? Select ?????? ?? ?? ?? Installation Window Open ???? ???? ?? ???? X80 ?? X60 Type ?? Windows BIT Select ???? ?? ?? ?? ?? BIT Select ???? ???? ?? ?? ???? ?? ?? Next Button ?? Click ????
Step 7: Drive ??????? ???
?? ?? ?? Installation Window Open ???? ???? ???? ???? Drives Open ?? ????? ????? ???? C Drive ?? ??? ??? ?? Windows ?? Format ???? ????? ?? ?? Drive Option ??? Click ?????? ?? C Drive ?? Format ?? ???
Drive ????? ??? ???? Drive Manage ???? ?? Option ?? ?????? ????? ?? Drive C,D,E ?? Format ?? New Partition Disc ?? ??? ???? ???
Step 8: Next Button ?? ????? ???
C Drive ?? Format ???? ?? ??? ???? Windows10 ?? Install ???? ?? ?? ?? ??? ?? C Drive ?? Select ???? Next Window ?? ????? ?? ?? ???? ?? ?? Next Button ?? ????? ???? ?? ?? Windows10 Installation Process Start ?? ???? ???
?? Windows10 ?? Installation Process ???? ?? ???? ?? ???? ???? ???????? 1 ?? 4 ??? Auto Restart ???? ?? ??? ???? ???????? ??? ??? ???? ????? ?? ?? ?? Windows10 Bootable Disc ?? Eject ????
?? ??????? ?? Laptop Format Kaise Kare ??? ?? ??? ????? ???? ???? ??? ???? ??? ???? ???? ??? ????? ?? ????? ?? ????? ?? ???? ????????, Laptop ?? Format ?? ???? ???
Boot with press f1
to do a format you must boot the pc with the disc in the drive, and set pc to boot from dvd, in boot options, then when it comes to install options press options and format, this will do a wipe/format and you should be ok from then.
2answers
I put new harddisk in toshiba libretto l2/060tnml and i want to try format from usb drive but boot device not suporting how can i make format then ?
Check the BIOS, the boot start up configuration to see if there is an option to boot up with a USB device. If not then it is not possible with your laptop because there is no boot USB driver.
You can format your hard disk by booting up with Windows CD installation and follow the steps to delete the partition, then creat a new partition, then format the partition.
OR
Download the Hiren's Boot CD and burn it onto a CD, then insert it into the laptop and get the laptop to boot up on the Hiren's CD.
One of the options on Hiren is DOS utilities - it contains a format program.
This is a very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program.
Click on one of these links to download HIREN’S BOOTCD :-
http://www.hirensbootcd.net/
http://67.20.82.163/
2answers
Had vista i removed with a boot disk and formated the harddrive now wont see hard drive
If the hard drive has been formatted it will not boot unless you install an operating system. If you had wanted to format and leave the disk able to boot the correct command is Format "Disk Letter":/S
My old gateway won't boot up
your partition is in raw file system, so windows will not be able to format/delete. you have to delete it using a non windows tool. get hiren boot cd or paragon partition manager. born it to a cd. boot from it and select format from the file menu to format the harddisk. this time format it in ntfs file system format
Does not boot from SATA drive.
Hi Grumpy
It sounds like your mainboard is not set up to allow for a SATA boot drive.
Have a look in your bios and ensure the boot order is set to the SATA drive first
Then, make sure the SATA drive is formatted and has an operating system installed.
Alternatively, boot the system from a boot disk ( your XP or Vista disk will allow this) and check to see if the board can see the drive and can read the drive if it is already formatted.
If not, format it and install the O/S onto it and make sure you answer YES to the question " do you wish to boot from this drive?"
Both my systems use SATA drives and I only had a boot fault because the "pre-formatted drive" I bought was not formatted and formatting under windows during O/S installation solved this issue..
Swoop...
Rca mp3 opal
your boot file is corrupt so it wont boot u will need to use a computer to format it. plug the mp3 player into ur computer go to my computer right click the mp3 player and select format. Format will wipe everything off ur mp3 player
7helpful
8answers
Boot Error please format unit
my rca mp3 player started saying boot error please format unit how do i fix this so i can hear my music again
2answers
How can i format my computer
what do you want to format your hard drive so you can install a fresh windows install? if so you need to go into your bios and set the computer to boot from cd rom and then you can boot from your windows cd an format your computer from there
4answers
PC halts while formatting hard drive
make sure your hard disk is error free Try formating the disk with FAT first ,if it doesn't work out the try disk utilities .
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
