Question about Amana Heating & Cooling
AMANA ACB087R, reading E1 on display and none of the buttons work at this time. Someone please help me solve this problem. Thanks.
  • Amana Master
  • 43,501 Answers
Here is a tip that gives a further explanation of that E-1 code. The causes of the E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening with your window air conditioning unit and give you some things to try to help you get your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Posted on Sep 07, 2010
How do I reset the amana PTH093B35AM to default settings?
you must read your instr. manual how to reset to default setting
go to www. fitness.manualsonline.com
God bless you
Oct 08, 2012 | Amana PTH093B35AM Thru-Wall/Window Air...
What does E1 F1 mean? can't set clock or use oven
Hello & Welcome to FixYa
Error code F1-E1 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Sorry for the bad news but hope you understand... Please get back to me if you have any other questions.
Kevin
Apr 12, 2011 | Whirlpool Accubake RF362LXTT Electric...
The read out says E1 and the unit doesn't work
http://www.fixya.com/support/r5620902-e_1_code_window_air_conditioning_units
heatman101
Aug 22, 2010 | Amana ACB087R Air Conditioner
Display screen reads E1 F5.
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(*&^
Feb 04, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
LED display on Janome Sewing Machine reads SP
SP means Spool Pin. It is currently in position to wind a bobbin. Move the bobbin winder pin to the left and SP should disappear.
May 12, 2008 | Janome 8080 Computerized Sewing Machine
How to code radio for suzuki ignis
press the disp button and hold for 2 seconds and then enter the code using the preset radio buttons 1 for position 1 and 2 for position 2 ect ect
Apr 05, 2008 | Car Audio & Video
Haier E!
E1 means one of the buttons on the touchpad is pressed in. The remote will still operate the unit. You might have to pull the panel of, and check all the buttons. If all seems fine replace the control board. might not be worth it thou..
Aug 08, 2007 | Haier HWC08XC1 Wall/Window Air Conditioner
F2:E1
This has happens to us regularly. Today when it happened I unplugged the oven and let the it cool hoping that would help. It didn't. I did that several times over a couple of hours to no avail. When it powers up, there are a sequence of different readings on the screen before the error code comes up. In my final effort, just before the code F2:E1 appeared, and it read PF, I quickly turned on the oven and that interrupted the sequence. It is now working. Lucky. I hope this helps someone.
Apr 03, 2007 | KitchenAid KGRC707 Stainless Steel Gas...
Heating & Cooling Logo
470 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
