Question about Pentair 1.0 Hp Whisperflo Pump
My Whisperflo was making a buzzing noise while pumping. I turned it off to clean the strainers and now when I turn it on it makes a loud buzzing noise and the motor does not spin. The impeller moves freely when I spin it manually. Thanks for the help.
  • 366 Answers
It's a bad start/run capacitor. It's under the hump on top of the motor. DO NOT touch the terminals with your bare hands in case the capacitor is charged. You can replace it with an exact match.
Posted on Sep 07, 2010
Why is my AY McDonald 21050K well pump making noise when it turns on?
Um, you may start planning on either having it repaired or replaced. This could be an indication that it is on the way to failing.
May 20, 2016 | Ay Mcdonald 21050k Sub Pump End Only
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
My pool pump is suddenly making loud noise at times
It sounds like you either have a bad bearing or a broken impeller. This will not get better wioth time. You need to get it repaired.
Sep 02, 2015 | Pentair WHISPERFLO PUMP .75 HP FR EE...
Samsung dishwasher makes a loud buzzing sound when the water is filling. It pulses a couple times to start then is constant. It pulses again right before the wash cycle. Comes from the bottom left.
This is common. The noise is coming from the water pump. If it bothers you, you can try UNPLUGGING the washer or turn off the Circuit breaker first. Then you can remove the bottom kickplate on the front of the washer and clean around the pump. If there is a water filter scree, clean it out. Make sure there is nothing rubbing against the pump which could cause a buzz. Tighten all fittings and screws to eliminate vibration noise.
Aug 30, 2015 | Samsung Dishwashers
When I turn on the self cleaning oven, it makes a loud buzzing noise. Is this normal? If not, what needs to be fixed and how do I do it?
The buzzing sound comes from the relays located on the control board. Remember, the oven gets very hot during self clean, so the control works at full speed to get all the elements working.
Jan 03, 2015 | Kenmore 30 in. Electric Self-Clean Single...
Singer Touch-tronic 2000 makes loud humming/buzzing noise, stitch selector lights quit working, needle bar stopped moving.
Sounds like you've got a thread jam going on in the bobbin case area. Good cleaning and a new needle will probably fix it. See: https://answers.yahoo.com/question/index?qid=20091202121550AAHxN8y
Apr 20, 2014 | Sewing Machines
Whirlpool duet sport makes very loud noises when it expells water through all cycles
How old is the unit?
I would venture to say that your drain pump is failing. Some will make a more louder than usual noise near the end of life. Have you checked the pump strainer yet? If it's clear, go ahead and replace the pump. It's a very easy DIY fix.
btw: remove the lower access panel to the washer. The strainer is located in the pump and will twist out w/a few turns. put something down on the floor (pan, towel, ect) before you remove the strainer for it will empty out whatever is left in the lower tub.
Jul 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Pump motor makes loud noise when pump comes on
If this is a high pitched sound, then this sounds like you have bearings that are starting to go out.  There is not much that you can do to prevent eventual failure.
The only other option that I see is that there is something causing friction inside the pump between the impeller and diffuser.
Dec 28, 2008 | Pentair 1.0 Hp Whisperflo Pump
Pentair 1.0 Hp Whisperflo Pump Logo
507 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
