Question about Whirlpool GU2400XTP Built-in Dishwasher
The lock button light is on, cant get it to go off or use the dishwasher
  • sabre07 Sep 06, 2010
    Solution worked awsome! Thanks
  • 8,197 Answers
To turn on the lock
Press and hold HEATED DRY for 4 seconds. The lock glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times and the selection is ignored.
To turn off the lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
Good Luck and please accept the answer and rate 4 thumbs up
Posted on Sep 06, 2010
The CHILD LOCK light came on and I cant get it off. Pressing CANCEL does nothing. How do I fix it?
Usually you need to press and hold a button or a pair of buttons to toggle the Child Lock function. Without the model number of your dishwasher, I can't be sure if this will work on your machine. It did work on the old Kitchenaid I had. Press and hold the Energy Saver/Dry button for 4+ seconds. If the light goes out, you have released the front panel lock.
On some models, you needed to press and hold the Air Dry button. However, you may need to look for writing in a small font that will indicate the correct button/key combination to release the front panel lock.
If pressing the appropriate button for an extended time doesn't work, then your keypad may need to be replaced. The signal isn't being received by the control of the dishwasher. (Alternatively, the wiring between the keypad and control unit or control unit, itself, may have an issue.)
I hope this helps.
Feb 26, 2016 | KitchenAid Dishwashers
Child lock is on and I cant get it off
To turn on Lock, press and hold CONTROL LOCK button for 3 seconds.
The Control Lock light will stay on for a short time, indicating that it is activated, and all buttons are disabled.
If you press any button while your dishwasher is locked, the light flashes 3 times and an audible tone will sound.
The dishwasher door can still be opened/closed while the controls are locked.
To turn off Lock, press and hold for 3 seconds. The light turns off.
If this was at all helpful please click on the 4 Thumbs Up helpfulness rating icon you see on this page.
Thank you very much and good luck.
Mar 18, 2011 | KitchenAid Dishwashers
The lock symbol is lighted up and i cant start it. its locked down?
Press and hold the air dry button for about 5 seconds when turning on the dishwasher.
Sep 06, 2010 | Frigidaire Dishwashers
Need to unlock
May I get the make and model # to help you more
Apr 11, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore 15912 Built-in Dishwasher
I have a maytag quiet series 100 dishwasher and it will not run a lock light comes on and i have replace a broken handle assembly but light stays on
the control panel is locked. dont know your model number to tell you what buttons you hold to unlock it, but some models have a lock button you hold down for 3-5 seconds. other models just have a lock light, and have a line indicating 2 buttons that you hold down for 3-5 seconds. if you cant find which buttons to hold down, refer to your owners manual. once the control panel is unlocked, it will run again. shane
Sep 01, 2009 | Dishwashers
Lock light is on
The lock only locks the buttons (childproof), hold it 3 seconds and it will go out.
Jan 18, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Lock Light Blinking
silly question but did you try holding the control lock button(perhaps its the heated dry button) in for 3 secs???? sonds as if the CONTROL LOCK has benn activated( child lockout)
Jan 14, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwasher is locked somehow and i cant get it back to unlock!
one of your buttons acts as a button or key lock.
on the elite it is the airdry button. there is probably a lock icon by the correct one. hold this button for several seconds and the lock lite will go out and buttons will work.
Dec 25, 2008 | Kenmore Dishwashers
Whirlpool Quiet Partner II dishwasher
I held down the heated dry button & it worked!
Aug 26, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
291 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
