Question about Whirlpool Upright Freezer EV161NZRQ
We have a Whirlpool upright freezer model # EEV161 F Having problems with door alignment. I do not have a proper user guide for this model. There are several EEV161 F**** models, but not any I have found W/this specific # EEV161 F. I need a user guide w/full explanation on how to adjust the hinges for proper alignment, and proper care of our freezer. I was able to obtain a new door seal & installed it, but some areas have not expanded fully???????????
textonor
  • 130 Answers
SOURCE: Whirlpool upright freezer AFG823NF-Thermostat not working properly
JennyT just trying to help with this. I assume this is a self defrost model. If so then is there an ice build up on the back wall? If so then the unit isn't defrosting. That is why pushing the Fast Freeze button is no longer working. You can get by however. Remove all the food from the freezer, put a vacumn in the freezer and shut the door. Turn on the vacumn, this will pull the warm air thru the freezer and in 30 minutes to an hour it will be defrosted enough to work until you can get someone to replace the 1 of 3 parts that the defrost system uses. The vacumn is what I use to defrost my nonself defrosting freezer. Sorry I couldn't be of more help.
Posted on Feb 03, 2008
  • 82 Answers
SOURCE: small patch of ice if frost free freezer
Frost free does not mean no frost ever anywhere. It just means that there is a mechanism to defrost the evaporator on a regular basis. If there is a spot where frost is forming in the box it may just mean that a little bit of moisture that is not collected on the coil may be finding another cold spot to stick. The area where the fan blows into the cabinet is bound to be the coldest spot in the freezer therefore an ideal place to collect frost. Check the level of the unit and your door gasket to be sure the door is closing tight and true.
Posted on Jun 29, 2009
  • 3 Answers
SOURCE: whirlpool upright 2 door freezer
I suspect your door is distorted and the seal is leaking.
Posted on Mar 18, 2010
  • 389 Answers
SOURCE: whirlpool upright freezer evl209nbtq making noise
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Posted on Apr 21, 2010
  • 122 Answers
SOURCE: I have a Whirlpool Model EV 200N Upright Freezer
If there is frost forming at the bottom to the door, your door gasket is leaking at that location. You may be able to relax gasket back in place with hair dryer, be carefull you can melt gasket. If it is sheets of ice, your defrost drain may be frozen
Posted on Aug 28, 2010
Frigidaire upright freezer door will not seal
Hi Chris, this is AP! Thank you for your post.
I understand you are having trouble with the door sealing on your upright freezer. Many times this can be caused by the freezer not being leveled. If the freezer is not leveled during installation, the door may be misaligned and not close or seal properly, causing cooling, frost, or moisture problems. To level your upright freezer use a carpenter's level to level the freezer from front-to-back. Adjust the plastic leveling feet in front, 1/2 bubble higher, so that the door closes easily when left halfway open. I hope this information has been helpful.
Mar 02, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Drain tube opening clogs with ice inside freezer.
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com and provide your full name, phone number, address and the model and serial number for your freezer.
Apr 01, 2017 | Whirlpool Freezers
Someone left the door open on the freezer and all the meat went to waste. The problem I'm having is the freezer only gets cold and will not freeze anything? I have no Manuel, and the unit is only...
Same thing happened to me, turns out the compressor when bad at the same time the door was left open, it was pure coincidentally, had nothing to do with the door being left open.
Jan 29, 2011 | Whirlpool 15.2 cu. ft. / 430 liter Upright...
I have 20 cf Whirlpool model #evl202nxtn freezer,I can feel cold air from the top of the door seal.Anyway to stop this with out replacing the seal.The freezer 18 mth old.Thanks
oh wow . i have the same freezer with same exact problem. i bought it brand new. i can definately see the seal on top is not installed properly. i always thought it was only my freezer but i guess its a manufacturing issue.
Sep 24, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
I have a Whirlpool Model EV 200N Upright Freezer which is having ice freeze on the bottom of the freezer. What can I do?
Aug 28, 2010 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
Our upright freezer door will not seal tight with a vacuum anymore. The freezer fills up with snow from the air drawn in. I have defrosted it and cleaned the seal. What should I do now?
That could be one of two things, one the door is not aligned properly and more important the gasket has failed and needs replacement. The snow as you call it is ice condensed from the atmospheric air that is getting by the gasket. You may want to check the door gasket and sealing surfaces especially in the area of the "snow".
Good luck,
Gilshultz
Dec 01, 2009 | Woods 201 cu. ft. Upright Freezer V2003RW3
How do I defrost my whirlpool ARC 5070 fridge/freezer? (I lost the guide when I moved) Thanks to anyone who can help me
My whirlpool Fridge/freezer powers up but both fridge and freezer notworking,have defrosted the freezer but noluck,have turned on foran hourand then back again,as per user guide still no luck.
Jul 27, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Whirlpool Freezer
your defrost drain is frozen remove the rear bottom panel on the freezer at the back insede the freezer and clear the defrost drain there will be a hole under the ice you just need to clear the drain not buy a new freezer
May 19, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Feb 03, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Whirlpool Upright Freezer EV161NZRQ Logo
101 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
