Question about Craftsman Drills
9" 1/3 h.p. model 137.219090 drill press right out of the box today. Motor hums, won't turn with belt on. With belt off, will spin, but can easily be stopped instantly by a bare hand grabbing the drive pulleys. No torque! This is a replacement drill press today because my older one, 8" 1/3 h.p. suddenly developed the exact same behavior while drilling wood. Power is fine-- same symptoms on multiple circuits of my home, including the one that drives the well pump. It would seem both motors are defective in absolutely identical ways. What could be wrong? I bought this from Craigs List-- the guy got it last Christmas and never opened the box. All plastic bags were still sealed, and I assembled it from original factory packing. Thanks, Loren M. Williams loren@lorenlogic.com
2 Suggested Answers
Obertelli
  • 3006 Answers
SOURCE: drill press motor hums and barely turns
The motor has either got worn brushes or more likely the windings have been attacked by moisture and gotten the dreaded "green spot" (corrosion).
Worn brushes can be replaced if the commutator is still good. But failed motor windings require a new or reconditioned electric motor.
Posted on Mar 12, 2010
Washing machine fills and agitates but won't spin or drain, just hums.
When the machine beeps it is giving you a code with the 8 wash progress lights along the top. Some will be on some will be off. With OFF = Zero and On = 1 Can you give me the 8 digit code. An example is (01001001) It is normal for the pump motor to get very very warm. Make sure you can spin the pump impeller easily.
Aug 09, 2014 | Fisher Paykel EcoSmart GWL15
I have a Whirlpool Cabrio model #WED6200SW1. The control panel turns on and when I hit start the heating element heats but it will not start. There is a slight humming noise but I can't tell if it's...
The humming noise indicates the motor is either trying to run, but not doing so because of a bad motor or capacitor, or the motor IS running but cannot spin the drum because the drive belt is off/broken. If you can spin the drum easily by hand, the belt is probably the problem.
Nov 27, 2013 | Dryers
I have an old Guardian Power floor model drill press and do not know how to change belt positions to change speed. help please.
See the picture below. The small red circle shows the locking screw on the right side of the drill. There is another locking screw on the left side of the drill. Loosen them both a half turn. The larger red oval is the handle to pull the motor closer to the spindle, thereby loosening the belt. Once loosened, it is easy to move the belt. Then use the handle to push the motor back, which tightens the belt. Keep pushing on that handle with your right hand while you tighten the locking screw on the left side of the drill with your left hand. Once you have that tight then tighten the right side locking screw.
Good luck! I hope this helps.
Jul 12, 2012 | Drills
The dryer is plugged in and the circuts seem to work however the dryer is making a humming noise but it will not turn on fully.
what do you mean it won't fully turn on?do you mean the motor won't run because usually when it humms you either have a bad motor or something is jammed and stopped the motor from spinning.try this,open the door,with one hand hold the door switch in and with the other hand spin the drum,have someone else push the start button while you do this,if it starts the motor is bad,if you can't spin the drum something could be stuck in the blower wheel or the belt broke and could of jammed up the motor but it sounds like you have a bad motor.let me know what you find and next time send the brand name and model number.
May 04, 2011 | Dryers
Drill press motor hums and barely turns
Mar 12, 2010 | Delta Drills
When Turned on, drum will not spin?
if the motor is running,your belt is the problem.if all you hear is a slight humming noise,you may have a bad motor,or something caught in blower. if the drum turns easily by hand,its probably the belt
Mar 05, 2010 | Frigidaire GLER341A Electric Dryer
1/3 hp drill press motor runs hot and very slow.
Look instead at the motor and drill post bearings. Remove the belt to see if the motor runs correctly with no load. If it still hums and gets hot, check that the motor itself turns freely (when off). If the motor seems to be ok, turn the driven pulley by hand--it should also turn freely. The capacitor is usually a starting assist, not running. To test, wrap a small rope several turns (when pulled must turn in the normal direction) around the small motor pulley and pull smartly while turning the motor on. If it now comes up to speed, the capacitor has lost capacitance. Electronic parts suppliers like Jameco or Mouser have such items.
Aug 23, 2009 | Drills
Replaced motor,now won`t spin
Something is locked in the transmission--can you turn the inner tub manually? Also, try to turn the driven pulley (the motor and belt driven). The problem could be anything from a seized bearing to a broken gear. Don't keep trying the motor while things are locked up, you could burn it out.
Aug 18, 2009 | Washing Machines
10'' bench drill press model DP200 WON'T START
The belt has either come off the pulley or the belt is slipping. Open th top access hatch and check the belts . If belt is off replace and tighten , if it is just loose tighten the belt.If it is not the belt and the motor is humming but not turning you will need to replace the motor's starting capacitor.Good luck and please don't forget to rate this answer, Thanks
Apr 11, 2009 | Delta TS200LS Shopmaster 10 Inch Portable...
Fridgidaire 7 cycle - older model top loading washing machine wont drain
could be a stuck gear box. motor trying to turn it on the reverse rotation for spinning. it could be the motor that hums. or the belt could just be loose.
inspect the belt and see if it is loose and adjust it if necessary.
tnx 4 using fixya,
drcool
Oct 17, 2008 | Frigidaire CWS3600AS Top Load Washer
Drills Logo
553 people viewed this question
Top Craftsman Drills Experts
Gareth Cockram
Gareth Cockram
John Trevino
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
