Question about Dell Inspiron 1525 Notebook
Hi i have dell inspiron 1525 my screen is almost dark so i checked with external monitor says that Error code 2000-0322, LCD inverter - unable to modify brightness. i replaced lcd inverter and screen. what should i do?
    Guru:
  • 689 Answers
This is one of the worst sorts of failures darling.
Posted on Sep 06, 2010
My son's 1525 Dell laptop screen is blank. I hooked it up to a External monitor and ran diags. I received a Error Code 0326 MSG: Error Code 2000-0326 MSG: LCD inverter unable to turn lamp off....
Yep, basically what it means is the ic on the board is shot. Order a new board. Or a complete lcd as it comes with the driver , The choice is yours and its up to you..!!
Apr 27, 2011 | Computers & Internet
White screen
The white screen you are getting is it just right after turning on the computer? If yes it means that you were not able to see the Dell logo correct?
Try connecting an external monitor thru VGA. While monitor and laptop is on with white screen please do this. Hold down Fn key then press F8 at the same time. This will toggle the display from the laptop to external monitor. If laptop displays to external monitor means that laptop LCD needs to be replaced.
If you do not have an external monitor try this.
While laptop is OFF. Do this. Hold down the D key then press power button at the same time.
Check if the laptop will display colors the whole screen. If you still see white screen then LCD needs replacement.
LCD mean LCD panel or the whole screen together with LCD cable and Inverter.
Hope this helps.
Mar 25, 2011 | Dell Inspiron 1525 Notebook
The LCD on my laptop has gone out. I am having to use my desktop moniter plugged into my laptop to work. How can I find a replacement top screen for a DELL INSPIRON 1525
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen.
As for the replacement, you can search for it using the laptop model on ebay.com
Oct 07, 2010 | Dell Inspiron 1525 Notebook
Replaced Dell 1525 screen, now the brightness can't be controlled
if you replaced the screen, might be a pinched wire,or loose connection to the mobo (motherboard)
Jan 05, 2010 | Dell Inspiron 1525 Notebook
I've got a Dell Inspiron 1525. When I power on the unit, the LCD shows the Dell startup screen, then a whinning noise and the screen goes black. Sometime shortly there after the Windows screen appears but...
This sounds more like a hardware issue. Now you say that the external display output is working fine. It could possibly be a problem with the lcd display itself shorting out. If there was a problem with the video hardware then I do not think you would be able to get the external display working either. The whinning noise could be coming from the lcd inverter.
Dec 14, 2009 | Dell Inspiron 1525 Notebook
Dell D630LCD inverter error, unable to turn lamp ON/OFF.
hi,
the interal graphics adaptor is making trouble, to find aóut if it just with your screen, hook up another external monitor and boot up.
Still the problem?
then you wil have to (let) the graphics card (be) replace(d), definitely.
Good luck
Sep 07, 2009 | Dell Inspiron 6400 Notebook
My Dell Inspirion6400 screen wont come on. I attached it to an external monitor, and it came up with the error code:0326 LCD Inverter Error, unable to turn lamp on. If I replace the LCD inverter, will...
Check out http://www.ccfldirect.com. they have a wide variety of inverters and backlight tubes for LCD panels and laptops. I'd change out the tubes at the same time you replace the inverter. The cost is minimal, and will increase the likelihood that you'll be successful
Jul 13, 2009 | Dell Inspiron 6400 Notebook
Dark screen on me laptop
the LCD backlight has failed, you will need to replace the LCD assy (about $200)
Jan 18, 2009 | Dell Inspiron 5150 Notebook
Dell Inspiron 1525 Notebook Logo
713 people viewed this question
Alun Cox
