Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
The disposal turns on but the water will not drain
    Problem Solver:
  • 3 Answers
Where the drain hose connects to the unit there is a plug that either has to be knocked out or pulled out depending on the model unit.
Posted on Sep 06, 2010
Disposal is operating (turning)but not breaking up anything nor is the water draining
if the water drains normally without using the disposal sounds like the blades on the disposal are not working properly. may need to replace the disposal.
Mar 12, 2015 | Dishwashers
Water from garbage disposal backing up
Check to see if there is a loop in the drain line. The drain line coming out of the disposal has to have a loop in it that is higher than the disposal. That way water can't drain back into the dishwasher.
Dec 31, 2017 | KitchenAid Dishwashers
Will not drain...but is turning....i tried to reset by pushing the red button and did nothing...i took the L wrench and turned it from the bottom and still nothing...sink is full of water too..what can i...
1) If disposal will not drain: Clean the tubular drain under sink.
Remove 2 nuts on p-trap, and trap falls loose, then remove tailpiece on side of disposal, hand rag over opening to direct water downward, turn on water, turn on disposal and see if disposal empties, clean p-trap, and then reassemble tubular drain.
2) If disposal will not drain and will not run: Clean tubular drain, check for power to disposal.
If disposal is getting power and will not run, and reset button is not tripped out, and cutter disk rotates freely, then disposal is bad.
I wrote ez disposal replacement steps that include tips for tubular drain.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Aug 21, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My badger insinkerator only drains will the unit is running
Clean out the drain and see if that helps.
Remove both nuts on p-trap and trap falls loose.
Remove tailpiece from side of disposal.
Hang rag over disposal opening so it directs water downward.
Run water and turn on disposal.
Turn off disposal and use coat hanger to remove debris if necessary.
I wrote disposal replacement steps that include tips for reattaching tubular drain pipes:
Aug 15, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Sink only drains when garbage disposal is run. Have cleaned trap, snaked pipe and no clogs still wont drain unless disposaln is tturned on.
Sounds like a clog inside disposal.
Water should run freely through disposal.
Put bucket under tubular drain from disposal.
Turn water on to see if water runs out of disposal.
You might need a de-greaser, drain cleaner or CLR
Check following link for tips on disposal replacement
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 24, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage disposal seems to work **** water down put when you turn the swich off water come back into the sink fast
You have some type of obstruction in your drain. There is enough force to push the water in the drain, perhaps even raising the level up into the vent line. When you switch off the disposal, then it rushes back into the shink. Disconnect drain line and run a snake into the drain.
Aug 07, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water won't drain. no food in bottom of disposal
Sometimes, the dishwasher can back stuff up into your disposer drain and plug it up. Disconnect the disposer drain and make sure that it is unplugged. If it is in a bind, you can rotate the innards my applying the wrench that comes with the unit to the socket on the bottom side of the disposer. It is an allen head usually.
You can also fill the disposer with hot water and plunge it like you would a stuck drain, but this is really less preferable as there are many ways to plumb these drains, and you may wind up either just relocating the plug to something (dishwasher?) else, or pop the drain line off, making a mess.
IF it is a new disposer, and has never been used, you'll want to make sure theat the casting inside of the outlet tube is cleaned out.
best regards, --W/D--
Aug 01, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Dble sink, one with the garbage disp. won't drain standing water
It's a drain clog within the disposal. Try a drain cleaner, if no luck, you will likely need to replace it.
Feb 18, 2009 | GE 24 in. Profile PDW7800 Built-in...
Garbage disposal spouting water after turned off
Hello, turn on the disposal without water and pour hot water into disposal. Be careful not to let it splash back on you! If this doesn't help you have to remove the drain and drain trap and clean them out. If you need more help let me know. Good luck.
Jan 23, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE disposal won't drain
It sounds to me like the knock out plug leading from the disposal has never been removed. Remove the drain like and you may find that there is a thin plastic wall preventing any water from leaving the disposal. Just place a small screwdriver in the opening up against the plastic barrier and tap it out with a hammer. good luck
Jan 21, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
75 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
