Question about Sport & Outdoor - Others
Need a diagram for the bolt on a Beretta A391 Extrema 2
Pic diagram for spark plugs on a 96 Beretta 6 cylinder
Front cylinders are #2-4-6...rears are #1-3-5...try to replace one at a time to eliminate confusing the firing order...your parts dealer can confirm the firing order...I think it is 1-2-3-4-5-6...The 2.8 V-6 can be tilted forward by using the extra hole on the upper motor mounts to ease access to the rear...the 3.1 uses the same bracket...after tilting the motor forward...use the bolt in the extra hole for access...hope this helps.
Aug 06, 2015 | Cars & Trucks
.much@yahoo.comWhere is the air conditioning
Here is a copy of the serpentine diagram for your car. If you look at the second diagram it shows the location of the air conditioning compressor. The compressor will have to be one of the wheels for the serpentine belt. Not sure which engine you have. Here are the diagrams. Hope this helps.
http://www.2carpros.com/diagrams/chevrolet/beretta/1993
Aug 04, 2011 | 1993 Chevrolet Beretta
How to change an power steering pump in a 93 beretta
You'll need to remove the belt. Disconnect the high pressure line and the return line. There should be three bolts holding the pump on, you can get to them through the holes in the pulley.
Apr 26, 2010 | 1993 Chevrolet Beretta
How do I replace the thermostat in a 95 chevy Beretta 3.1 v6
you need a socket and a swivel to reach it, the bottom hole in housing is slotted so you won't need to take the bolt all the way out.
Feb 12, 2009 | 1995 Chevrolet Beretta
Sport & Outdoor - Others Logo
114 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
