Question about Maytag Dryers
When I push the start button, you can hear it try to start tumbling but it doesnt move. I have a maytag model # MDE9606AYW
  • Maytag Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to check/replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other connections.
Remove the lint filter screws and filter.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Please rate me
Posted on Sep 07, 2010
Testimonial: "Great advice! Very detailed instructions! Perfect for a do it yourself female!"
My Maytag MDE9606AYW drum randomly decides to not start. I hit the push button and there is loud noise but the drum doesn't move. When it does start the loud noise happens but it is quickly replaced by...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 02, 2011 | Maytag MDE5806AY Electric Dryer
My dryer doesnt work. the tumbler doesnt turn. when you push the start button it sounds like its going to start but it doesnt move
hi check the belt maybe broken or if you just hear humming maybe motor. dose it heat at all? jim
Oct 11, 2010 | Maytag Dryers
My maytag dryer will not start. I push the start button and can hear a low buzzing sound but it doesn't start tumbling or heating or anything.
Check the breakers. If you have a meter check power at outlet. This could be a lot of things. A broken belt, a bad motor, Not user if this is gas or electric heat if electric you could have a bad cord or not be getting the full 220-240 volts. You could have a blown fuse or a broken wire.
Mar 17, 2010 | Maytag Dryers
Maytag sde4606ayw heats up will not tumble when pushing the start button even after replacing a fryed temp. switch.
do you hear the motor trying to run? it could be a belt, or something electrical, door switch could be a option as well
Jun 23, 2009 | Maytag SDE3606A Electric Dryer
I have a Mytag Dryer MDE9606AYW The drum won't tumble
Unplug the dryer, open up the top panel. check if the belt is broken . replaced it.
Feb 24, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Gas dryer's start button doesn't stay engaged
bad start switch on motor, rare. that model # came up as maytag range not a dryer.
Jul 19, 2008 | Dryers
Maytag Dryer Squeaking noise when first turning it on
nedd to replace the rear tub rollers
Apr 21, 2008 | Dryers
Maytag electric dryer model #MDE 4916AYW
If your hearing a buzzing noise, motor.. If it sounds like the motor is running, could be a belt.
Jan 07, 2008 | Dryers
Dryers Logo
144 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
