Question about Dometic Rooftop RV Air Conditioner
Intertherm ac roof top ac fan want turn - Dometic Rooftop RV Air Conditioner
  • 674 Answers
Try turning it by hand to make sure it isn't seized up. If it won't turn replace the motor. If it will turn, check the capacitor for the fan motor and replace if necessary. You can also verify you have power going to the fan motor.
Posted on Sep 07, 2010
2 Suggested Answers
wise_jf
  • 66 Answers
SOURCE: what freon does a intertherm roof top ac use mfg date
R22
Posted on Jun 27, 2010
My coleman mah 3 roof top will not blowon fan side
Sounds like you have either a bad fan motor or a bad fan motor capacitor. When you turn the unit on with the fan not working, the compressor (the humming noise) runs and gets real hot real quick resulting in the compressor cutting off ( the nothing after) on it's inside high temp switch. This is what the compressor is designed to do so that when this happens, it does not burn the compressor out. Replace you fan capacitor, give the compressor an hour to cool, then try it. In most cases and if I'm correct, the unit will run just like you want it to. Good luck.
Please rate solution
Sep 09, 2009 | Coleman Mach III Air Conditioner
Intertherm furnace/AC, fan on the furnace won't shut off.
How old is the intertherm. The old ones have fan limit switch and sometimes they stick. The new ones have a fan baord or time delay relay. They go bad from moisture and they just go bad sometimes. It sounds like you just have a shorted relay. If you think you can replace it you can get a relay at any parts store. Need the model number of unit. If not just call a service tech for free estimate. Russ
Jul 24, 2009 | Heating & Cooling
Have a 620765 capacitor for my Intertherm ac outside unit. There are three connections on the capacitor. 1. Fan 2. Herm 3. C I have a yellow and red wire coming from the compressor. There is an orange wire...
pls connect capacitor terminal as folow
fan = connect wire come from fan
C = common -connect 1 wire from power
- connect1 to compressor term R
-connect 1 wire go to fan
herm =connect wire go to compressor term S
May 01, 2009 | Intertherm P3RC-048K Air Conditioner
Intertherm furnance chimmly icing up
it sounds like there is a restriction on top of you're flue pipe top, not allowing the air to escape in a normal way, ike bird nest, leaves or the position down on the pipe.
Jan 30, 2009 | Intertherm P3RA-048K Air Conditioner
I have a intertherm 070 an there is a fan on the kitchen roof, it is running all the time
sorry ,WE have no such animal, but check out the fan switch to see if its set to "auto" instead of on! thank-you very-much!
Aug 27, 2008 | Heating & Cooling
Intertherm model P853A5 older style AC unit fan will not start to rotate when thermostat control set to cool.I have a feeling that it might be the electric motor. I removed the screen and rotated the fan...
This is most likley the capacitor. Be very careful when changing it out!!!!! Make sure to use an insulated device to discharge it first before touching it!!!!!!! To discharge it place insulated device across the two spade connectors on top.
Aug 26, 2008 | Intertherm Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
112 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
