I have a dometic 13500 BTU Roof mount a/c. It is set up with the duo-therm analog thermostat. The system cools fine. The problem is that the a/c gets down to the right temp, then it turns off like it should but turns right back on within a few seconds. Any help would be greatly appreciated.
-   I have this problem as well, except when the compressor tries to short cycle it doesn't have the power to do so, it tries a couple of times and then eventually blows the circuit breaker.-   Guest
May 15, 2009
-   I have the same problem as Super Troop. Compressor tries to come right back on after achieving set point. If on shore power, it will groan for a few seconds, stop trying for a minute or so and then kick back on - and the cycle repeats. Dometic dealer has fixed cold air leaks, blocked off air outlets near the thermostat (analog), checked and blessed the capacitors, refrigerant levels, drains and found no icing issues. They have no clue what the problem could be and are at a loss. Anybody??-   axbow
Jan 16, 2009
-   I HAVE THE EXACT SAME PROBLEM. WHEN IT COMES BACK ON THE A/C GROANS AND IF USING GENERATOR IT OVERLOADS-   wind_32920
Jun 19, 2008
-   My problem is just the opposite. You turn it on and it runs for about 4 or 5 minutes and then shuts off completely. Will not start back up on the AC side. Will work on the fan side. I'm puzzled. Brand new unit, even went back and had the company replace the first one. Same problem. Any suggestions.-   booregard
Jun 07, 2008
-   I have that same problem, although it takes more like 1/2 minute to 1 minute. And since it was working, but then stopped with nothing else changed, the suggestion makes no logic at all.
I have more than 40 years of experience in electro-mechanical service work and while it was not on RVs I am a reasonable competant trouble shooter. I suspect that my thermostat is the problem.-   1Tree
Best Solution
posted on Jun 13, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
The thermostat usually has wire that reads the temp in the room. The wire runs through the wall and can pick up heat from the wall. Put a piece of insulation around the wire where it comes through the wall and leave only the end of the wire exposed.
Check for a heat source near the thermostat. Try adjusting the louvers so the cold air is not blowing on the location of the thermostat. Sun shining on the outside wall in the area of the thermostat on the inside wall will also affect the operation.
Air conditioner worked good yesterday, today not blowing cold air, fan runs but compressor kicks off in just a few seconds. Also probably second problem, thermostate must be set at 90 to get a 72 degree cool.
For everyone with an RV rooftop a/c install a Supco Relay & Hard Start Capacitor (cost around $15 with shipping on ebay) and you will find your a/c performs and cycles MUCH better than with the OME capacitor alone. Even if you aren't experiancing the problems some of these people are reporting, it will make your unit last longer as it takes a lot of stress off the compressor. No, I am not a salesman for these things! I had problems with my a/c cycling and shutting down my generator and this solved my problems. I don't even notice it cycle anymore on shorepower or generator.
Was this helpful?
Yes
No
Solution #7
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I discovered that the drains for the catch basin under the cooling coils were both plugged up. After I cleared them out it seems to be working properly now. I suspect that it may have been frosting up.
My RV roof top air conditioner has no power going throw the circuit board needing to replace the...
(More)
My RV roof top air conditioner has no power going throw the circuit board needing to replace the circuit board .
model 59516331G9 on the comfort control center digital screen will show temp set for a short time...
(More)
model 59516331G9 on the comfort control center digital screen will show temp set for a short time the show E-4 this goes back and forth fan will come and go off. The controls come on for furnace or coll but still show the same notes
a/c and furnace wont work.I have a duo therm, model #59516.531 on my toyhauler with a 3107541.009...
(More)
a/c and furnace wont work.I have a duo therm, model #59516.531 on my toyhauler with a 3107541.009 thermistat... The a/c-furnace switch when selected does nothing..cant even hear the relay board clicking.. but the fan works fine..High and low. I have checked the fuse in the relay box and circuit breakers on panel and on onan genny.. dont know of any more?
I have removed the interior bracket and outside I have removed the shroud. What is next? This is a...
(More)
I have removed the interior bracket and outside I have removed the shroud. What is next? This is a Duo therm roof top Penguin model
had loft conversion, problem on inside of picth roof where roof meets floor gets wet and patches...
(More)
had loft conversion, problem on inside of picth roof where roof meets floor gets wet and patches above velux windows and elsewhere appear, the builders did leave a ventilation gap inside the rafters before installing celotex, we have old type felt
