I want to check the blower motor and oil it if it has oil connections. The air handler is a Rheem rbhc 17J11nfd and I don't see any access plate. It is mounted horizontal.
  • 3,361 Answers
If it is less than 15 years old it has no oil ports.
It has sealed bearings.
Posted on Sep 06, 2010
How do you clean the fan in a rheem air handler?
Pull the blower assembly...2 screws on the angle bracket holding the blower & disconnect the wiring if needed to the motor.
May 28, 2014 | Rheem Complete Split System Straight...
I just installed strip heat Rheem RXBH-1724A10J 10KW 208/240/1/60 into Rheem 14AJM36A01, RHPNHM3624JC, 3 Ton 16 SEER Air Conditioner Split System W/ GE's Variable Speed thermostat Pro 701 and it ran up...
This will help you.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Jan 20, 2011 | Heating & Cooling
I need to replace my out side heat pump my air handler is steel good it is a rheem rbhc 14j11sfd what do i need
they like the name brands to match but it dosnt matter.you need to get the model and serial#s off the coil to find out what ton it is and just get the same size out side unit.
Sep 24, 2010 | Heating & Cooling
How to adjust blowed speed on a rheem air handler
There are probably six wires coming out of your air handler blower motor. There are 2 brown wires which are capacitor wires, one white wire which is neutral, and probably red,black, and blue. Look behind the door of the air handler to see the wiring diagram. They should have the color coded speeds marked on the diagram. There is probably some sort of control board that the blower speed taps plug into. By changing these wires around on these taps you can adjust the speed of the blower motor.
Jun 05, 2010 | Heating & Cooling
Ineed to now how many ton is a rheem model number rbhc-14jo7nfd air handle
Hello, that unit is 800cfm on High speed. One ton of cooling requires 400 cfm. Thus your unit is a 2 ton capable air handler.
May 19, 2010 | Heating & Cooling
Rheem RBHC-17J14SFA elec furnace fan won't stop
sonds like u have a bad safety switch they r round and have 2 wires on them usually and u can check them by taking the wires off of them and checking continuity thru them there might be one on the blower housing also either that or ur blower relay may be bad and stuck closed
Feb 18, 2010 | Heating & Cooling
No heat. are the elements bad? or Heat Relay
Yes, The red wires to the heat kit can be jumped to the red wires, turn off the power first and identify L1 and L2 lets call black L1 its where they connect to the power board, then pull the red wire and connect the to the power board. Also set the fan at t-stat to the On position, turn on power. use the breaker to control it.
Jan 03, 2010 | Quasar HQ2052UH Air Conditioner
Air handler fan not working
Check the fan relay switch in the air handler.
Check the fan motor capacitor.
Check the fan blower wheel for binding.
May 25, 2009 | Heating & Cooling
Rheem Air Handler will not run. This is a 2006 Rheem model RHLA-HM3617JA Air Handler. I replaced both the condenser and air handler circuit boards. I replaced the motor in the air handler.. The condenser...
Have you hard wired your fan motor to verify that the motor and or the capacitor are good? If you do a continuity test of the motor leads(with electricity off of course) you can see if the motor has open or grounded windings.
Apr 11, 2009 | Ruud Handler Air Conditioner
Air handler squeals
Squealing sounds from a forced-air heat pump generally occur when the belt that connects the motor to the fan slips. If the blower is making a grinding noise, shut off the unit and call a heat pump repair technician --the motor's bearings are probably shot. In most cases, the belt is improperly aligned or worn and needs replacement. Follow the instructions in your owner?s manual (if you don?t have one, contact the manufacturer and ask for one). This job involves removing the access panel, loosening a couple of bolts that hold the blower motor at the proper tension, and realigning or adjusting the belt. In many cases, it?s a good idea to remove it and buy a replacement at the hardware store. When reinstalling the belt, be careful not to over-tighten it--this can wear out the motor bearings.
Jan 18, 2006 | Haier Energy Star ESA3183 Air Conditioner
Heating & Cooling Logo
160 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
