Question about Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher
MDB7601AWS Maytag dishwasher
What kind of tool is needed to remove old adjustable upper rack holder from the rack so I can replace it? (the front rollers on both sides have broken off) I've already bought the replacement part for the left side and now the right side has broken.
Also, will I be able to successfully remove the rear roller from the left side and install it on the right front so I don't have to purchase the right upper rack holder as well?
    Sergeant:
  • 409 Answers
go to www.whirlpooparts.ca and type in the model # under Repair Parts. it will show you the exploded view of the racks.
Posted on Sep 23, 2008
How to replace the top rollers on a GE dishwasher model # gsm1800nww
Lower Rack
  • Remove all of the dishes from the lower dishwasher rack.
  • Pull the lower rack out of the dishwasher so that it rests on the dishwasher door.
  • Lift the lower rack up and out of the dishwasher.
  • Place the new lower dishwasher rack on the dishwasher door, then push it into the dishwasher.
  • Upper Rack
  • Extend the upper rack as far as it will go.
Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
Pull the upper dishwasher rack straight of out the arms to remove.
Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
. Align the end caps with the ends of the arms, then push the end caps into place.
Upper Rack
  • Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
  • Pull the upper dishwasher rack straight of out the arms to remove.
  • Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
  • Align the end caps with the ends of the arms, then push the end caps into place.
Feb 04, 2011 | Maytag Dishwasher
I have a Maytag MDW 7600AWS, Serial 16500063CG. I need a new upper rack. What is the cost? Does it come with the revolving arm?
Go to www.repairclinic.com and enter your model number.
Then search for your part for price and availability.
Nov 27, 2010 | Maytag 24 in. MDB7601AWS Stainless Steel...
How to re-install bearings on upper rack on asko 1475
Welcome to FixYa.
Changing out the upper rack ball bearings...?
Yes there is a trick to installing new bearing & holders. Here's what works for me...
  • remove the rack stops if you haven't already and then the rack itself.
  • With the rack out of the way, remove the bumpers at the back of the rails which will allow you to perform the re-installation.
  • The trick now is to install the balls into the holders and the holders into the stationary part of the rail on the inside wall. The inside wall rail will keep the holders in place as you slide the inside rail into place...this will usually require holding the holder with one hand while pushing the sliding rail back into place. ( I should do a video of this on you-tube with how many I've done and tried to explain ).
  • Once this is done, re-install the back rail bumpers followed by the rack and then finally the front rack stoppers and that should do it.
Hope that explain it for you or gives you an idea of how it needs to be done. Thanks for visiting "FixYa" today for your repair help.
Let me know if you require further assistance. Please take a moment to rate the info provided for you here today.
    **NOTE** I should also mention you want to be sure none of the old 8 balls didn't fall down into either the drain pump or circulation/wash pump. This is something I've seen far too often on Asko dishwashers with the end result being a broken impeller in either pump...or both, yikes ! I use a telescopic magnet to fish around as it will be the only object made of metal...unless something else has fallen in the sump well area, it's good to check.
Good luck
Macmarkus :)
Aug 26, 2010 | Asko D1976 Built-in Dishwasher
How do i remove my old upper rack ?
u should be able to pull out and lift up to remove racks
May 22, 2010 | Maytag 24 in. MDB4000 Built-in Dishwasher
How to replacement the upper dish rack on Kenmore dishwasher
On the front end of the rails, there should be plastic or rubber stoppers. Remove these and the rack should roll right off as if youre pulling it out to load it.
Feb 06, 2010 | Dishwashers
Trying to replace broken upper rack adjustment arm . . .
first off check to see if there is an endcap either the front or back of the track. if so remove the cap. check for end mount screws. if no screws the endcap opens up the route for popping the plastic cover off and exposing the screws.. see diagram(may not be exact model but it gives you an idea)
May 12, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Upper rack travel sticks and jams.....
you have a bad bearing retainer. you will need to call an asko parts dealer and order 8 upper rack ball bearings, and two ball bearing guides (they are grey plastic and break over time, causing the rack to jam. To replace tham, you must take the upper rack out by turning the plastic retainers on the front of both rails 90 degrees towards the outside of the machine. The slide the whole basket out. Now look at the back of the rails inside the dishwasher. there shoul be 2 more grey plastic retainers with bumpers on them in the rear. These must be pried out wiht a screwdriver (be careful, have cut myself several times on this job till i figured out the best way to do it. cover the bottom hole in the dishwasher with a rag, as you are likely to drop the old bearings when you slide the rails out. Slide out both the rails. Put your new (or old if youve got all 8) ball bearings into the ball bearing holders, then put the holders into the rail thats attached to the dishwasher. slide the rails back in, andthen put all your retainers back in and your rack. you may have to slide the rack in and out a few times before it will center the bearings and work smoothly. Should cost you about $12 in parts. Good Luck!
Apr 17, 2007 | Asko D1716 Built-in Dishwasher
Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher Logo
347 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
