Question about Brother LS-2125 Mechanical Sewing Machine
The thread on my bobbin keeps coming out while my machine is sewing. How do I prevent this?
    Genius:
  • 1,788 Answers
I think that you have your bobbin thread coming out the wrong way, turn your bobbin over and make sure it is threaded right. Look at your manual, or go to brother-usa.com and download for free
Posted on Sep 12, 2010
The thread keeps coming out of the needle when I start to sew
Before you begin to sew, it helps to gently hold both thread tails in your left hand. Then manually, bring the bobbin thread to the top of the fabric. This eliminates the top thread pulling out of the needle and helps prevent those annoying knotted thread messes when beginning stitching.
How and Why to Bring up the Bobbin Thread
Another thing that will help (if you don't want to do the above), is make sure that the take-up lever is at its highest point before taking the first stitch.
Jun 07, 2017 | Sewing Machines
're-please I just want to know how to fix bobbin
they have to be put in the machine in the proper direction .
Feb 17, 2016 | Sewing Machines
My machine keeps clogging at the beginning of my sewing
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Dec 12, 2012 | Janome Sew Precise Mechanical Sewing...
Brother 700e
1. Change needle
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
Aug 16, 2012 | Brother SE-270D Computerized Sewing...
Brother sewing machine keeps coming unthreded
always keep a thread tail of 4 to 6 inches on top & bobbin thread & keep the top & bobbin pulled to the back if the machine, before you start sewing
Jan 20, 2012 | Sewing Machines
Bobbin thread keeps balling up
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 19, 2011 | Brother BC-1000 Computerized Sewing...
Bobbin thread tension issues
There might be a piece of thread or lint caught in the bobbin tension preventing it from functioning correctly.
Feb 24, 2010 | Janome L-344 Mechanical Sewing Machine
My sewing machine keeps getting jammed when sewing. the top stitch keeps getting tangled in with the bobbin thread and jamming up the machine.
Here are a couple of things to try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope this helps.
Sep 11, 2009 | Singer 5160 Mechanical Sewing Machine
When threading Singer 57817 sewing machine, it won't pick up the
take out the bobbin, pull some thread from it. is it coming smooth without effort?
if yes, keep some thread outside and put back the bobbin and try again.
if thread is not coming out smooth, then check if something is stuck in the bobbin.
May 30, 2009 | Singer 57817 Computerized Sewing Machine
My bobbin keeps getting tangled up when I sew
Take the thread out of the top and bottom and turn the handwheel by hand to see if the machine will rotate smoothly.
Rethread, making sure that the thread is in the bobbin tension slot and that the upper thread is in the tension and the take up lever.
Sorry for the delay in response. I just found the sight this evening.
Apr 20, 2007 | White Sewing 1740 Mechanical Sewing...
Brother LS-2125 Mechanical Sewing Machine Logo
23 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
