Question about Philips MMS171 Computer Speakers
WHere does the green audio plug from the volume control go to the sub or computer
My PSW350 has no sound
• Check AC plug and green LED onthe back; make sure outlet
is operational
• Check volume control on subwoofer
• For speaker level wire conections, check (+) on amplifier to (+) on
subwoofer and do the same for (-) to (-)
• Check that RCA line level inputs of the subwoofer are not wired from
speaker level outputs of amplifier
if problem still persist , the Sub may needs further troubleshooting
view these sample troubleshooting guide for Computer Speakers
Sep 25, 2012 | Polk Audio PSW350 Subwoofer
I plugged in power speakers (the cable green stereo plug which I plugged into the green inlet in the back of the CPU). I can see the volume level moving and I checked that it's not on volume mute) no...
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 21, 2011 | Acer Aspire™ T180 PC Desktop
Dell speaker connection color code needed
  • *Turn off your Dell laptop.
    *Connect speakers to the speaker control box. The speaker control box varies depending on the speaker system you have. Two-speaker systems will have a female jack on the back of one speaker that you plug the other into the second speaker. If your system has a sub-woofer, all of the other speakers will plug into it. The connecting cords are color-coded to the jacks on the back of the control box.
    *Plug an audio cable into the "Audio-In" port on the back of the control box. If the audio cable is color-coded, it will be green.
    *Plug the other end of the audio cable into the headphone jack on your laptop.
    *Plug the speakers' power cord into a surge protector to protect your system from power surges. *Plug the surge protector into a wall outlet.
    *Turn on your speakers and set the volume at a medium level. Be prepared to turn the volume up or down after you turn your laptop on.
    *Turn on your laptop and confirm that sound is coming from your speakers.
    Thanks for rating
    Good luck
  • Jan 25, 2011 | Dell Dimension 4600 PC Desktop
    I have installed the z 640 but I get no sound at all
    • Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
    • Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the M3D button on the controller unit (if you own a z-560 or z-540) or use the source selector switch (if you own a z-5300 or x-620). If you do not have any of the models above, you can use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
    • Try connecting the speakers to a portable sound device such as a walkman or portable CD player. Plug the speakers into the headphone jack, but make sure the volume is lowered so the speakers are not over powered. You can do this for both the front, rear, center/sub speakers to verify that they work. If the speaker system works on the walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer.
    • Check the system Volume Control located in the System tray. Make sure that the volumes are at a reasonable level and are not checked for Muting.
    Post back!
    Oct 03, 2010 | Logitech Z-640 Computer Speakers
    Speakers don't Work on HP Pavilion f1903 desktop
    Just match the color of the male and female on each end. Plug the audio cable (mini stereo phone plugs) to the PC audio line out (green miniphone jack) to the Powered speaker mini stereo phone audio line input jack (green color jack). You will have to set the volume controls of the speaker control knob and at the PC on screen volume control panel.
    Mar 29, 2010 | HP Pavilion F1903 19" LCD Monitor
    My volume is not working correctly. I have it turned up to 100 - the highest and I can barely hear it.
    Monitor volume is affected by TWO volume controls (or even three...)
    1: Volume on the monitor can be set to 80%
    2: Main Volume on the COMPUTER can be set to your liking.
    3: Wave volume on the computer mixer settings should be set for 80% (See Sound on your control panel or right click your volume control near the clock)
    If all these are right and the volume is still low, check that the audio is not set for surround 5 or 7 channel and the monitor audio connector is plugged into the REAR green connection on the computer.
    Still problems, the audio driver in the monitor is shot.
    Dec 05, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
    Green light on speakers and sub. No sound - only hissing noise
    open volume control & remove check from mute button.
    start-program-acessories-entertainment-volume control.
    Sep 17, 2009 | Audio Players & Recorders
    Sound won't work without the earphones being plugged in
    Make sure the speaker volume is turned up and also go into Control Panel, Sounds and make sure nothing is muted and all volumes are turned up. Also make sure the speakers are plugged into the sound jack in the back of the pc. The speakers also need power but since the light is on, it sounds like they are plugged in.
    Apr 14, 2009 | E-Machines eMachines Desktop PC
    I lost paper work
    Simple enough,
    everythink connects to the sub, so the 2 speakers the volume controll and the computer cable, then the computer cable comes out the sub into the green audio port on your computer :)
    Feb 16, 2009 | Bose Companion 3 Computer Speakers
    Speaker wiring
    the audio out cable (green ended wire sometimes) goes into the audio out socket of your pc. (both are green some in cases with older computers then it will be the middle on of the 3 sockets) if you have more than 3 audio sockets then they will indefinetly be colour coded. if you have a sub and/or remote, plug the left speaker jack into the white socket and the right speaker jack into the red socket of either the remote or sometimes the sub. then just plug it into the wall and adjust the volume control via the start menu and the remote if you have one.
    hope this helps
    kev
    Dec 01, 2008 | Compaq MV 540 15" CRT Monitor
    Philips MMS171 Computer Speakers Logo
    22 people viewed this question
    Top Philips Audio Players & Recorders Experts
    Gyula Lacz
    Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
