Question about Samsung UN46B7000 46 in. LCD TV
Why are the people shorter & fatter on my screen?
  • 11,361 Answers
If the original program was made for Standard display (4:3 old TV format) and you set the aspect ratio of your TV to fill in the 16:9 screen, that is what you will get. If you read your manual, it will explain the effect of the screen aspect ratio setting and what you will see on your screen.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Posted on Sep 07, 2010
  • Samsung Master
  • 8,457 Answers
Find the remote contol button said as P.mode or view mode changes it to normal.The people should back to normal,not shorter or fatter anymore.
Posted on Sep 06, 2010
Avi video is squashed when rotated in windows movie maker
Mac users who have a DVD collection may interest in this tutorial about DVD to MOV Mac ...
Jun 18, 2012 | Microsoft Computers & Internet
Calgary.cacannot find the right starter bolt for 93 gmc k2500 6.5 turbo diesel truck first one broke shop fixed it with different bolt shorter and fatter they said something about a rivet too that one is...
You will probably have to drill and tap the hole. Before you do this ... consider a helicoil repair. http://www.noblefix.com/helicoil.htm
Your mechanic should be familiar with this or similar product.
Thanks for your question today.
Mar 02, 2011 | 1993 GMC Sierra K3500
Greetings, I get a perfectly good picture for about 20 minutes & then it clicks & turns off. I hit the power again & it will go on for less time and shorter and shorter time on until it stays...
Sounds like a component or 2 overheating and probably in the frame stage of the set. You would need the service manual to fix it and someone who is capable. The manual should be obtainable from sites such as www.mauritron.com The make and model would be needed to obtain it.
Feb 08, 2011 | Televison & Video
Having trouble with the full picture
If your television is having an image with funny looks, either the images are looking shorter or fatter or the images are in halves, then you need to understand that the lamp is faulty and need to be replaced.
To replace the lamp, you need to unplug the television for a while, then you unscrew the screws that are behind the television to remove the back cover of the television, then you unscrew the metallic sheet that covers the panels, then you lift them up also you lift the panel. you will have direct access to the lamp, then assess it to see if it is looking bad, so you replace the lamp and the television will be in good condition once again.
Take care and good luck
Oct 30, 2010 | Televison & Video
Where is the oil filter located? Where does the oil drain from?
The oil filter is Almost always on the passenger side lower half of the engine. If it is external ( on the outside of the engine) it should be the size of a pop can only a little shorter and a little fatter. The oil drain plug is located at the bottom of your oil pan. It's the pan on the bottom of the engine.
Sep 06, 2010 | 1993 Nissan Pathfinder
Where is the low pressure valve for the AC on 2005 nissan altima
you have two lines going to your compressor one is fatter than the other. follow the fatter line till you find the fittlng. it may be on your compressor but it will be at the fatter line.
Jun 07, 2010 | 2005 Nissan Altima
Darker fatter letters every 2 inches apart from top to bottom
it is called phase you can attempt to let the lcd monitor auto set or you can disconnect the power over night then plug in and then do not auto set this default usually seems best some times
Nov 29, 2008 | Proview PL926WBi 19" LCD Monitor
Streaks make letters fatter every 2 inches apart across screen
this is called phase it can be set auto by the button or you can disconnect the power and next day reconnect and leave it in default which can be better than letting the monitor try to set the phase.
Toshiba big screen tv
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
Jan 05, 2008 | Toshiba 57H82 57" Rear Projection...
Samsung UN46B7000 46 in. LCD TV Logo
57 people viewed this question
Jerry Greenberg
Jerry Greenberg
