Question about ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
Which type of memory?
  • 1,031 Answers
What type of motherboard?you have to specify the type of mother that you are using for you the one that is compatible,you can use the same type of memory onthe first slot on the second slot too
Posted on May 13, 2008
  • 21 Answers
Not required to put the same memory. Any card will do as long as it fits right :)
  • 2,712 Answers
Better choose two memory modules of same make and value to avoid conflicts and problems later on with compatibilty.
In other words, use same brand and memory type (DDR,DDR2,SD, etc) and capacit.y
Posted on May 14, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
Gt5082 what is the best sticks for gateway gt5082
Memory Upgrade for Gateway GT5082 Computer, the Gateway GT5082
Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory
Type, and comes installed with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) of Memory. You can upgrade your
Gateway GT5082 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) standard Memory installed.
For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Gateway GT5082 Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
hope it helps
Apr 14, 2012 | A-Data Technology 1GB kit (512MBX2)...
I am trying to expand memory by inserting 2 PC3200 (DDR400) but total amont of memory size does not changed (still 512 MB) First slot (DDR1) APACER-512 MB Second slot (DDR2) LG Electronics - 1GB
Take the stick of 512 out of the motherboard and insert the 1GB stick in DIMM 1 slot and switch the machine on. If it comes on check whether it has registered it as 1GB. If it has turn the machine off and just put in the 512 stick.
If the machine won't boot up with the 1GB stick then it could be faulty or the motherboard doesn't support 400MHz (which it should).
Oct 20, 2010 | Asrock 775VM800 Motherboard
I have a 512 mb 667mhz sdram on D102Ggc2 i decided to up grade memory. Can i upgrade system memory without lose this 512 mb.
Yes you can. but make sure that you buy the exact same type of RAM stick that you have and put it in the other RAM slot so the Dual Channel feature will be active (dual channel makes data transmission/processing faster) and making your systems memory 1GB. However, your motherboard can utilize or handle up to 2GB or RAM so you can put also a 1GB RAM stick which will make your systems memory a total of 1.5GB (that will be the case if you really dont want to lose the 512MB that you currently have,
Hope this helps.
Jul 09, 2010 | Intel D102GGC2 Motherboard
Two 1GB 400MHz RAM's or two 1GB 333MHz RAM's??
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot
So, yes, you can put two 400MHz modules in the slots.
Jul 05, 2009 | MSI 915GLM-V Motherboard
Memory installation
Most likely, it is a limitation of your motherboard. Not all motherboards or computers can physically read all types of memory or they may have memory limitations. For instance, I was working on an older Gateway this week. It had 2 memory slots but the maximum amount of memory the computer would recognize is 512 MB. Therefore, if I had put to 1 GB sticks in, provided the computer could use it, the maximum the computer would be able to see or use is 512 MB. In this instance, that is most likely the scenario. The best thing to do is to go to and run the system scanner. It will tell you how many slots you have, what the maximum per slot capacity and the total capacity of your computer is.
Thanks and please take a moment to rate as fixya.
Nov 06, 2008 | Intel Motherboard
Problem upgrading RAM to Intel D845GLLY
Most likely the memory is incompatible or in the wrong configuration. Check here to see the proper configuration for this motherboard.
Jul 16, 2008 | Intel D845GLLY Motherboard
Toshiba l45-7423 laptop has two memory slots. With 512 in each, runs ok. With 2 gig in top slot, 512 in bottom slot, runs ok. with 2 gig in bottom slot, says it has memory errors. this limits me to 2.5 gig...
HI embreelynn,
just want to check, did you left the top slot open when you put the 2gig in the bottom slot, if you do, I suggest you try it with the 512 in the top slot and the 2gig in the bottom, the reason is that some mobo implements "banking" which means that you'll have to fill in the 1 mem slot before the using 2nd, 3rd and so on.
hope this helps, regards.
Jul 12, 2008 | Toshiba Computers & Internet
OS won't work with RAM upgrade
Hi !
if u wanna upgrade RAM ,ur RAM should be of same capacity in both slot. i mean to say if u wanna use 1 GB....then put 512 & 512 or else put single 1 GB. But u cant use 512 in one slot & 1 GB in another slot at a time. if u do the combination like that ,it will never work.
--APARNA (Mumbai)
Jan 12, 2008 | Foxconn WinFast K7S741MG Motherboard for...
To extend RAM memory
No its isnt sorry :(
Only sdram will fit in the slots. Best place for getting it is 2nd hand off ebay.
Hope that helps?
Jan 05, 2008 | Intel 845GE Motherboard
Must I use the 2 memory slots for this dual channel DDR motherboard?
Are you sure the stick of RAM you are using isnt made by Rambus? If it is it will have to be paired with another stick of the same type. Also try using the other slot.
Nov 16, 2007 | PC Chips A21G Motherboard
ASUS A8V-VM SE (MB-A8VVMSE) Motherboard Logo
112 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
