Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
Its making a clicking noise from the control board in the back of the fridge. It wont stay cool any advise would be nice ty.
  • GE Master
  • 3,361 Answers
When the GE control boards start clicking they have gone bad and must be replaced.
Board cost approximately $150.00.
Posted on Sep 06, 2010
Testimonial: "ty for the help now its time to find a board"
KitchenAid Superba Fridge beeping and clicking on and off
next to the compressor is a relay called a klickson
You can get engineer to replace for about $120 or buy one for about $20
Apr 08, 2014 | KitchenAid Refrigerators
Our fridge is making a clicking sound. The freezer and the fridge part are not cooling, however the lights stay on. There is no running from the motor either. The clicking sound is comming from the back of...
there is mother board in the back the noise is the interlock that clicking... most of the time it happen the board is dead and need to be change.
if you poll the unit out you will see the bracket that cover the board...
let me knoe if you need more help
Jan 04, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Model GSH25JSRF SS is clicking non stop, the click comes from a small panel on the back right of the fridge. Started out that the water and ice dispenser didn't dispense. Then the clicking just came...
Is it still cooling? I had an issue where there was a clicking noise from the back panel and the fridge did not cool. Pulling off the panel the noise seemed to from a box on the circuit board. Turns out there was a problem with the controler board and after some research I found that the board was covered under a recall. GE ended up sending a guy out to replace the board at no charge. Pretty cool being that if was after the warranty had expired; but I guess it makes sence since there was a recall. Good luck.
Dec 10, 2009 | GE GSH25JFR Side by Side Refrigerator
Ge freezer works fine but the fridge wont cool.you
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 14, 2009 | Refrigerators
My fridge is making a clicking noise (like a car turn-signal) and the digital display in the fridge is out
The clicking is from the main control board relays clicking off and on . The part number you need is WR55X10656 . This board is located on the back , behind an 9X10 inch aluminum panel . It controls the digital display along with all other operational parts of the fridge .
Aug 21, 2009 | Refrigerators
GE fridge has loud clicking noise; model freezer on bottom.
The problem is the main control board on back of refrig . Relay bad and clicking . Have to replace the complete board .
Jul 23, 2009 | GE GBS18KBM Bottom Freezer Refrigerator
Servis frost free fridge freezer makin crackin noise afew tyms a day
this is not unusual on any make. the cracking noise is the cabinet creaking with change in temperatue. don't worry about it
Oct 18, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Clicking
This unit, I believe is a piezo electric cooling/warming unit. It's possible that after or during your defrost, the control board was exposed to excess moisture... whether by condensation (sweating), evaporation or direct contact with the melted water. In this case, if you plugged the unit in before allowing sufficient dry time, it would have shorted your control board. Possibly allow the unit to dry (unplugged) for 24-48 hours and retry. If the same symptom occurs, replace the control board.
Jul 27, 2007 | Max-Fridge STC55926 / STC55927 / STC55928...
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
290 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
