Question about Breadman TR845 Bread Maker
The whole unit where the paddle is attached to came off. I put it back together but now it is leaking. Do I need like a rubber gasket
  • 433 Answers
There is no repair for the sealed bearing. You will need a new bread pan. Sorry. Hank
Posted on Sep 08, 2010
How do I stop a leak on flush valve and actuating unit I just installed?
There is a rubber gasket between thaa toilet and bowl,or well known as the water closet.,check it if you put it on place.,or maybe you had put it flip top..?
if you are sure that you had been put it correct but still leaking,try to clean the faceof toilet and water closet where the rubber gasket will be placed on,also clean the rubber gasket itself,it must be free of dust, or sand...then place it on place and tighten the plastic bolts and nuts to fit the joints...
Sep 13, 2014 | Home
How do i get my bissell to stop leaking water?
The rubber gasket on the bottom of the 2-in-1 tank is probably lodged in the base of the unit. It should be connected to the nozzle on the bottom of the 2-in-1 tank. You can pull it out of the base and reattach it to the tank. This should stop it from leaking. The formula tank on the back has the same gasket so you can pull that out and see how it should fit on. Hope that helps.
Apr 05, 2012 | Bissell 2X Proheat 9200 rug cleaner
Oil leak 2000 alero, just replaced plug, not it, leaked out all the oil after I drove it 20 miles, please help, could it be a gasket or what
Check the oil filter. The old gasket might be stuck on the engine (two gaskets stuck together), or the new gasket might be defective, misaligned or missing.
Nov 05, 2011 | 2000 Oldsmobile Alero
I was changing the front disc brake pads on my 2008 Suzuki Boulevard S50. I took the two bolts out that hold the calipers together which caused the fluid to leak out and a small rubber gasket fell out ....
You will need to buy a new rubber gasket kit for caliper from suzuki shop
It is not usual to pull caliper apart for pad replacement, normally unbolt caliper off fork leg and lift of the disk
Jul 08, 2011 | 2008 Suzuki Boulevard
My Waring Pro Coffee maker leaks water out of the bottom. In the morning when I get in I have to clean up the leak. Is this repairable?
When you pour water into the screen area it travels toward the back of the unit and drops through a rubber gasket/cup to be heated/processed. I have the same problem and while I bought another WC1000 I took my old one apart. By turning it over and removing 4 recessed screws you can carefully lift the top off (carefully because wiring is attached). However, you can now access the rubber gasket/cup. Doing this I found that mine was torn which I must assume is the cause of the leaking problem. Now if anyone knows where I can get a replacement rubber gasket/cup or a part number I would appreciate it.
Aug 22, 2010 | Waring Pro WC1000 Coffee Maker
Putting glass and washer together
  1. Place glass container upside down on safe working area.
  2. Place rubber gasket/ring on top of opening first.
  3. Place stirring or mixing blade on top of rubber gasket/ring.
  4. Take the plastic retainer and screw it on over everything previously assemble.
  5. Hand tighten only enough that you can reverse the whole operation when comes cleaning and disassemble time.
Feb 13, 2010 | Elite 072-04-1198 Blender
Tank leaks
Call Hamilton Beach customer support at 1-800-851-8900. You need a whole new tank. For $5.00 shipping, they will send you a new one. They did me. The gasket that prevents this fell out of my model 47665 brew station. The tiny part that held it in broke and I called them to ask how to fix it. It can't be fixed but for five bucks, they sent me a whole new tank PROBLEM SOLVED!!!! I love hamilton beach. 1-800-851-8900 customer service. Good Luck to ya Katherine
Jun 10, 2009 | Hamilton Beach BrewStation 47224 Coffee...
Water leaking from Door and Draw from Hotpoint Aquarius Extra
Had the same problem. I unplugged the machine from the mains. pulled it out from the unit and removed the lid. checked the black rubber hose which leads from the drawer to the drum. it was full of water. i carefully squeezed the pipe and tried to clean it out with warm water to see if it was clogged. still leaking. i then Removed the green paddle on the inside and turned the drum to line up with the black rubber hose that leads from the drawer. I very carefully used a wire coat hanger to put through the gap in the drum left by the paddle. Moved left and right, oh look.... A sock! I manipulated it out of the gap, checked the hose. Water had gone. Put everything back together. No leak. All done in under an hour :-)
Mar 02, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Waring blender - new blade
I just figured it out. The key is you need to think in terms of keeping the blades and the large washers separate. Here's what you do.
Thread the blade through the glass and use the white rubber gaskets against the glass and the stainless gaskets against the hardware. Then tighten the whole enchilada to the blender with the main nut (that goes on the bottom outside of the blender). Then once that's nice and tight tighten the flange that catches the blender teeth to the remaining portion of the protruding threads. Make sure you use the copper colored gasket first then the stainless washer then the stainless flange. Tighten that real good and you should be good to go.
To check if you've done it right spin the flange. If the blades spin independent of everything else you're good to blend away!
Feb 23, 2008 | Blenders
Leaks when dispensing
get out the phillips head screwsdriver and take it apart a bit.... search online for more details, but i've seen several posts for several models where people had to go 'in' and tighten up some screws. either that, or they discovered cracked plastic pieces (which you'd then have to have replaced, or return the entire unit).
sorry, i have no further solution, but thought perhaps this might point you in a direction??? good luck.
Oct 31, 2007 | Hamilton Beach BrewStation 47214 Coffee...
Breadman TR845 Bread Maker Logo
97 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
