Question about LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive
I have a lacie had drive that i've been using on my mac. My mac died and I bought a PC instead. How can I retrieve the data I stored on my Lacie?
    President:
  • 547 Answers
The easiest way that I know is to purchase a program called MacDrive from Mediafour.com
This will let your PC (Windows XP, Vista or Windows7) read the mac formatted HD directly
They do have a trial version, so you can make sure it'll work for your HD before you pay for it.
Posted on Sep 06, 2010
My mac does not recognize it. It was working last night and then not this morning. It did not fall and was in perfect working condition yesterday. I only bought it about 3 wks ago so i'm terribly confused...
There are several things that could have gone wrong. The least worrisome is a software glitch. Please shut your Mac completely off, then unplug the Lacie and turn your Mac back on. Leave the Lacie drive disconnected for about 5 mins then reconnect it and see if it re-appears.
If it does keep your data on both the Lacie and the Mac for the next few weeks and if it does it again get it replaced. If it does not, you should be fine.
If the Lacie drive doesn't reappear then it may have failed. I can suggest a simple program to check if it's dead or just lost it's formatting. In the latter case the program can retrieve files from it before reformatting, in the former you will need the help of a pro to repair the drive before any files could be retrieved from it.
The program I'm suggesting was recently reviewed here Once you get to that page just click on the picture at the top and it will take you to the download area where you can get a copy. It's free to download and scan but you will have to pay them before it will recover files.
Of course if there's nothing important on it yet and it's dead, I would suggest simply having it replaced.
Hope this helps FixYa,
Chris
Sep 21, 2010 | LaCie (300728U) 250 GB Hard Drive
No Power!
Hi, A couple of possibilities: 1. The drive is at fault; 2. The USB cable is at fault; 3. The USB port of your Mac is at fault. Things you can try: 1. Test the drive in another Mac; 2. Replace the USB cable. Things you can do to try and retrieve the data: 1. Use Data Recovery software compatible with Mac; 2. Check with Lacie website and find out if there are any utilities that can be used to repair/retrieve your Big Disk http://www.lacie.com/us/support/drivers/index.htm?id=10007 Hope you get an idea and things work out for you. Good luck and kind regards.
Aug 24, 2007 | LaCie 640GB Big Disk USB2.0 640 GB IDE...
My lacie external drive wont transfer my data from a mac to a pc
Basic Troubleshooting:
-Check all connections (Ethernet, Power, USB, etc)
-Install the appropriate driver for the device, usually included on a CD
-Double Check compatibility with your system (system requirements usually on packaging of product)
-If you haven't rebooted since you set it up, then reboot, this fixes a lot of things
-Try the product on another computer
-Try different cables/ports on the comptuer.
If nothing works, then send it in if it's under warranty or contact a professional service.
Feb 13, 2010 | LaCie Hard Disk 750GB with Hi-Speed USB2.0...
Lacie 300790 that my Mac won't recognize
the Mac may not recognize it if it is formatted with NTFS. I believ most Macs can read FAT32 and other formats but not NTFS. You could hook the drive up to a modern PC, transfer the files there for a while, format the external drive to FAT32 and copy the files back to the drive. The Mac shold read them now,
Sep 21, 2009 | LaCie d2 Extreme (300790U) 250 GB Hard...
Can an older Lacie drive (2005?) work with an HP tablet?
The native file system for Macs is HFS. If the drive was originally used with a Mac, the current file system on the drive is HFS. Windows uses NTFS and is not compatible with HFS; which is why Windows doesn't recognize the drive as valid.
You can download a data retrieval tool called MacDrive that will give Windows the ability to speak Mac. There is a free trial available and it should be able to help you grab the files off of the drive.
Aug 06, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie RUGGED 250GB not recognized by my PC
I think the migration assistant (in the utilities file in your application folder) can transfer files direct via USB.
Jan 23, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Data disappears from hard drive
nope...retrieve is always more expensive..i recommend an online backup, like mozy dot com to keep this from being an annual event for you.
Oct 13, 2008 | LaCie F.A. Porsche (301177) Hard Drive
Lacie drive won't mount
I solved the problem. It was a power supply problem. It seems after searching boards on the net, this is a common problem with the lacie hard drives. Just replace the power if your hard drive is clicking and not mounting. I think many people must be throwing the drives away thinking they are lost when it is just the power supply. Try this first before trashing it or spending a lot of money on data recovery programs/
Nov 13, 2007 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
Lacie 250GB External Hardive to be used between a PC and a MAC
Be carefull when moving data from Macs to Windows etc. Your best bet would be to start again. It should work if you get your friend to put the data on the drive & copy it directly to your Mac. From there, you can safely copy data to the PC, but may have trouble accessing that same data after the PC has had it.
Jul 31, 2007 | LaCie Silverscreen 80GB USB 2.0 - Portable...
Hard Drive won't accept data
Some LaCie drives ship out formatted FAT32 so they will be ready to use on either a Mac or a PC. If you are getting error -50 when copying to a LaCie drive, or any drive formatted for PC, it is because of the following: Certain characters that can be used in a Mac OS X filename are not allowed in MS-DOS filenames. This can prevent the file from being copied, and can occur when a filename contains non-printing ASCII characters, or any of these characters: ? / \ < > " | > *. Either copy the data off of the drive and use Apple's Disk Utility to erase the drive in Mac OS Extended format, or change the filenames of the documents that cannot be copied. Hope that helps http://www.lacie.com/us/support/index.htm?rid=10033 I also noticed there are some patches for LaCie drives. You may check out the patches before the format. Let me know what happens. Tim
Mar 14, 2007 | LaCie Design by F. A. Porsche 160 GB Hard...
LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive Logo
104 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
