Question about Dell Dimension 1100 PC Desktop
I need to open my system unit to change the hard disc but I dont know. I have a dimension 1100.
  • 8,197 Answers
On the link below will tell you how to replace the hard drive.
http://support.dell.com/support/edocs/systems/dim1100/en/sm/parts.htm#wp1088567
Good Luck and please rate 4 thumbs up for the free answer
Posted on Sep 06, 2010
Dell dimension 1100 b110 drives audio e rede
Hello download the driver here at dell:
http://www.dell.com/support/troubleshooting/us/en/19/Product/dimension-1100
Open the audio folder, and download the driver.
Run the exe program, and reboot after the install is done.
Good luck
Mar 04, 2013 | Dell WF887 - Dell Dimension 1100, B110...
I need to do a system restore on my Dell Dimension DE051. I do not have any of the discs and looking for HELP!!!!!
Hello pamnwillie,
To perform a "System Restore.
" Follow these instructions carefully, and you will have no problem at all.
The first thing you want to do is click on the "Start Button,paul7of9_50.jpg" from the Desktop.
Next, click on "All Programs," scroll to find "Accessories," next select the "System Tools.
" You will see in the next window that open, "System Restore!
"Now this is very important!
Once you click on the System Restore "shortcut" it will start to look for the last known time of a change in your computer.
The System restore can take as long as a 1/2 an hour to run, so be patient
"Do not try to do any type of work, don't even touch the keyboard for any reason,
just let it run!"
Once the System Restore finds the correct "Date and Time"of the event;
choose the Date closest to the time of the occurrence.
Now once again, there will be a message telling you not to do anything with the computer,
and please don't.
The System Restore will "run" for a while, so once again be patient.
The computer will then "Shutdown and Restart."
Lo-gin if you have to; but!
Do not touch the Keyboard once the Desktop window open, because System Restore is still running.
Wait! Until there is a message letting you know the Restore of your System was successful! Take your time.
"I hope all goes well, please let me know if you need further assistant.
Best Regards.
Thanks for using Fix'Ya."
Jun 20, 2011 | Computers & Internet
I have a Dell Dimension 1100 P4 that I can't shutdown.
Could be a driver that has incorrect power management (ACPI), or a program that has a resident module that does not behave well when closing down.
Especially if you have a lot of software installed, it is probably some program causing this.
Only option to really find out is to uninstall programs and see if it improves. If not you can reinstall them. That way you can narrow it down.
Disk cleanup and defrag are always good ideas for computer performance, but generally not the solution to such problems.
May 21, 2010 | Dell Dimension 1100 PC Desktop
Dimension 1100 not booting. In Boot sequence screen, says "Hard drive not installed"
Your hard drive is probably toast and needs to be replaced and Windows reloaded.
Make sure to check your BIOS settings first and make sure the drive is showing up in there and it's not deactivated.
Sep 10, 2009 | Dell Dimension 1100 power supply ** FREE...
Getting blue screen of death on dell dimension
Probably it is getting HOT, cool it with another household fan, defragment the drive.
do a scan disk of the hard drive. eliminate some files that you dont need, disconect the norton security for a while or symantec, are you getting a burnt ruber smell if you do it is time to change the power unit.
Vitally
Sep 09, 2009 | Dell Dimension 1100 PC Desktop
I took out my old hdd, and put a new one in with double the GBs.....but now when I turn on my PC, all I get is a blank screen? Won't let me load the OS....
First set your harddisk as master which has operating system.
And set slave as your new added hdd.
You can ser master and slave with jumper settings.
Read diagram on HDD.
Then check .
Also check in bios that your first boot device is your hdd which has os.
Let me know if you need more assistanse.
Thanks.
Aug 28, 2009 | Dell Dimension™ B110 PC Desktop
Multiple viruses on a Dell Dimension 1100
Formatting your hard-drive is the easiest way to eliminate anything on that hard-drive. Follow my steps below to do just that.
Start your computer so you can open the CD-ROM drive. Insert the Windows Installer into the CD-ROM drive. Close your CD-ROM Drive. Shut down your computer.
Now start your computer and while your system starts up look for an option for the, "Boot Menu" or, "Boot Device." It will have a key associated with it that you have to press continually for you to enter the menu. For instance:
(F8) Boot Menu.
Here's a hint to help you out. If you see the loading screen of your operating system, you've missed your window. Restart and try again.
Now just to clarify, we're not out to change the boot sequence, we're trying to boot from a specific device. Once you find that menu select your CD-ROM drive and press enter. It might ask you to, "Press any key to boot from CD-ROM drive." As it mentioned, press any key. Afterward the Windows Installer will launch.
Follow the directions on the screen to set up Windows. Yeah, it will warn you that there is another OS installed on your primary Hard Drive and that it might be better for you to, "Repair" your system. Ignore that and continue with the process to Install Windows. Before the final step to install Windows there is a screen that allows you to partition your hard-drive. In this are, erase ALL partitions. Afterward create a new one which will be your C:\ drive. If you want to partition your drive further, go ahead. However, at this point you can continue the Windows Installation and the Installer will ask you if you want to format with the NTFS or FAT32 type. Format with the NTFS type.
Now the Windows Installer will erase EVERYTHING on your hard-drive and proceed to install Windows XP.
Feb 06, 2009 | Dell Dimension 1100 PC Desktop
CD ROM not reading discs. Can not locate D Drive after right click explore.
Try this.
Click the Start button, click Run, type regedit in the Open box, and then click OK.
click the + sign next to HKEY_LOCAL_MACHINE
click the + sign next to  SYSTEM
click the + sign next to  CurrentControlSet
click the + sign next to  Control
click the + sign next to  Class
Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}
Delete upper or lower filters. if you see them both delete them both.
Oct 11, 2007 | Dell Dimension 1100 PC Desktop
Dell Dimension 1100 PC Desktop Logo
32 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
