Question about Sport & Outdoor - Others
ATV won't start, getting fuel. Turns over, but won't start. Thanks for you help. Frank
  • 2,299 Answers
This could be a fouled spark plug. Have you checked the spark on the plug? Could be many things wrong. Try spraying starting fluid in the air cleaner. It could be getting gas to the carb. But not to the cylinder. If the jets are clogged you will get gas to the float bowl in the carb. but not to the cylinder. It could be many things if no spark. Could be a bad coil, bad ignition switch, bad points, or bad plug wire.
Posted on Sep 06, 2010
My 2007 450 sportsman won.t start but she backfires
Remove the seat, and take the cover off the air filter container. Place your hand over the end to aid in fuel flow to the carburator. You might not be getting enough fuel which is causing it to backfire and not start completely.
Attempt to start the ATV once you get fuel flowing you should be all set. Clean that filter as well.
Jan 31, 2015 | Polaris 2007 Sportsman 450
Problem with fuel injection
Check the attached links,Manuals and guides, Good luck with your Bike .
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
ATV TROUBLESHOOTING AND MAINTENANCE
ATV Service and Repair Manuals
Service Manuals for Download in PDF
Oct 14, 2014 | Polaris 2006 Sportsman 500 HO EFI
I have an atv that won't start.
Could be your starter, solenoid, or even a fuel pump/clogged lines or filters
Jun 04, 2013 | RTO Quads 125cc Full Size Adult 4 Wheelers...
Ares 110cc four wheeler won't start gas not getting to carb
chk your tank and lines for trash blockage, when you get fuel to the carb go from there, the overflowing is caused by the needle valve in the carb sticking open, usually caused by trash in the fuel, make sure you are getting fire to the plug as well, I know for a fact the wiring systems on these things are not quality systems.
Oct 25, 2012 | RTO 110cc Basic Manual ATV # ATD-125C
Cobra 50 fourwheeler wont start cleaned carb and new plug
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
Kasea 50cc won start engin turns but no firing at all Off Road Forums...
ATV Connection
Aeon Scooter Parts Racing Planet USA https://www.thomasmorecollegebookstore.com/panther-110-atv-manual.pdf
Tips and Tricks for Motorcyclists
Apr 09, 2012 | Cobra Panther 50 Motorcycles
When battery is at full charge motor turns over but won`t start. battery has been dead for over a week but still have lights,horn and turn signals. fuel filter is fine. what should i check next. thanks for...
Hi, if your motor turns over ok & appears to be getting fuel, I'd probably check for spark by putting a spare plug in one of the leads & turning the engine over to see if it sparks, if it doesn't spark maybe it's your crank angle sensor/coil etc.
Jan 11, 2010 | 1990 Oldsmobile Silhouette
20000 grand am won;t start turns over but won;t
Well then if no pressure at fuel rail then go to pump and in line filter as the in line filter might be the main problem but the pump pressure can also be faulty if filter is bad so check it out and let me know how you get on. Ron
Nov 02, 2009 | 2000 Pontiac Grand Am GT
Replace battery on 2007 arctic cat 500 with 84 miles on it. Now
is there a fuel delivery problem? and as well the batter may not be charging id start there
Jun 15, 2009 | Swisher Atv Tru Plow
Gasoline in the airbox, muffler (2006 Suzuki Vinson ATV)
usually when the needle and seat are stuck, the gas will run out of an overflow on the side of the carb, unless those are plugged for some reason, then obviously the gas will flow where ever it can. is the machine 2 or 4 stroke?,
May 31, 2009 | Swisher Atv Tru Plow
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
