I have a GE Hydroheater washing machine. For the past few months I have had to restart it atleast once or twice during a wash cycle because it would stop in the middle of a cycle for no apparant reason. Today, it will spin twice, then shut off (it says Door Unlocked), and it won't let me restart it. It only does the same thing. It goes around twice, once in each direction, then stops and says the door is open. Please help! What do I do? I even took the laundry out and tried to make it work with nothing in it, thinking the blanket was too heavy, but still does the same thing while it's empty. Your help would be greatly appreciated. Thank you. Joyce
I have the same machine and it is having the same problem, just as you described. The lock button did no good. Any luck finding a solution.
Posted on Feb 18, 2011
Try locking your settings by pressing your locking button for 3 or 4 secs till the red lock shows.and see what happens..it might work..good luck
Posted on Oct 23, 2010
GE Washer stuck in wash cycle and not draining.
humming is usually the result of bad motor windings , are u saying it washes for 20 minutes or just stays on that cycle without doing any washing? a non moving drum can be a bad motor coupler or belt if belt driven.
Mar 30, 2015 | GE Washing Machines
Washing Machine grinding, now doesn't spin
Check with an appliance parts supplier for a replacement.
Feb 25, 2014 | GE Washing Machines
After working well for six months, my washer now expels water at random points during the wash and rinse cycles.
Check inside the fill hose for debris. There is a screen designed to block debris from getting inside the machine valve. If the screen builds up with debris the water slows down. Sounds like the water is filling too slow. Also the unit and/or the load may not be balanced causing it to stop and drain out. If it's okay then see what lights are blinking when these events occur and post here.
Jun 06, 2013 | Haier HLP21E Top Load Washer
I have a GE HydroHeater front loading washing machine and it is leaking water from the bottom of the door. I havecleaned the gaskets but I dont know what else to do??
To support Jahn's step by step instructions, I found a YouTube video that shows step by step. I hope this helps!
www.youtube.com/watch?v=3-c1nMWa00Q
Mar 13, 2010 | GE Washing Machines
GE Frontloader - will spin @ beginning of cycle, but never again
Check the switch on the door where clothes are loaded. I may be failing intermittently.
May 23, 2009 | GE WSXH208A Front Load Washer
GE Adora Frontload Washer shredding clothes
We were having the same problems with ripped clothing and longer cycles. Our rubber seal by the door has ripped twice now causing massive amounts of water to run out. I learned through other threads that many people are having these problems and was told that zipping up zippers and turning jackets and clothing with big heavy stuff on them in side out to protect from ripping the clothing and the rubber seal. I removed the panel on the front bottom of the machince and there is a small gray cover that housed the coin trap. Mine was clogged and once I cleared that out, my cycle times got better. I hope this was somewhat helpful. We definitely won't be purchasing another GE front loader!!
Mar 29, 2009 | GE WSXH208A Front Load Washer
Washer pauses at various times during the cycle
Did you find a solution? Mine just started doing the same thing.
Jan 30, 2009 | GE WWSE5200B Top Load Washer
Bleach Dispenser not relaesing bleach during cycle
I have the same model # and same problem!!!
Worked fine for few months and then it started.
Sears technicians came twice but couldn't fix the problem. Now they have ordered a new dispenser door. Sears said they changed the design. Will see if the new door will work. Hope that helps.
Jan 12, 2009 | LG WM2455 Front Load Washer
Debris being released from washing machine
This is from the drum seal or bearing. Check/replace.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jan 11, 2009 | Washing Machines
Problem with our washer/dryer
sump/filter is blocked instead of flushing on dry cycle is filling as not pumping well. ring hotpoint to reorder pts cheaper then anyone
Jan 06, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
345 people viewed this question
Top Washing Machines Experts
